01-09-2018, 19:37 | #2 (permalink) |
Freak Poster Join Date: Jan 2015 Location: egypt
Member: 2329289 Status: Offline Sonork: www.sonork.com Thanks Meter: 3 | EasyJtag Suite Classic ver.: 2.9.0.0 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 10 (build 16299), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.24 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.11.3 QUALCOMM Direct ver:1.0.6306.57125 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.16299.15, are OK Z3X Card Serial : AAF0-BBF7 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0E00A00DDF38A564, ,FW Ver.: 01.62 CMD Pullup Level:794 mV CMD Active Level:2237 mV Box IO Level:2800 mV CLK Rate:3000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 0E00A00DDF38A564, ,FW Ver.: 01.62 CMD Pullup Level:732 mV CMD Active Level:1577 mV Box IO Level:1800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0E00A00DDF38A564, ,FW Ver.: 01.62 CMD Pullup Level:742 mV CMD Active Level:11830 mV Box IO Level:1850 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD CRC Error Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0E00A00DDF38A564, ,FW Ver.: 01.62 CMD Pullup Level:783 mV CMD Active Level:2248 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
