12-08-2017, 17:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | How to fix GPT in eMMC I've received 2 M9 with boot problems. One was not powering on and another one I f...d it myself )))) this are now the info's from it: Code: EMMC CID : 90014A48424734650507CDB511352254 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 3451195701 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _3451195701_20171208_1712.extcsd Partition table scan: GPT: not present Done. Not even be able to flash it with ruu. From the begining there was 3 errors at starting to flash. I directly wrote in it the rom1 from support area and there was NO change. I wrote again via emmc qc flasher the same file with "erase" option checked and now the phone is in the same qcomm condition like the other one. GPT is not present and there is no partition table in it. Someone has read a full dump in ADB from an working unit and I wrote it in this phone but without succes and also there was some errors somewhere: Code: eMMC_tool Suite ver. 1.4.8.0 Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 2.8V Setting frequence to 21 Mhz HiPower mode is OFF EasyJTAG Box Serial = xxx Card Serial = AA62-xxxx EasyJTAG Box Firmware = 01.60 Changelog: 08.08.2017 (ver 1.4.8.0) Fix: Bugs that have been found through your crash report Fix: Saving VCF for contacts Add: Multiple file selection for Samsung firmware Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button) Add: Intel vendor (for easy read/write ROM2/ROM3/GP1) Add: "Pinouts" tab (taken from the catalog of classic software) Add: Checker for Sony TrimArea Add: Speed graph for "Random verify emmc" Add: Fat16/Fat32/exFat support (Explorer) HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 1691 mV CMD Active Level: 2248 mV EMMC Device Information : EMMC CID: 90014A48424734650507CDB511352254 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: HBG4e , S/N: CDB51135 , rev. 07 EMMC NAME (HEX): 484247346505 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Backup saved: HBG4e_CDB51135_20171208_103202.extcsd EMMC Init completed. Opening file: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin Analyzing Image: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin Vendor: Qualcomm Searching GPT ... GPT header is found and is valid GPT header successfully parsed HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 1722 mV CMD Active Level: 2485 mV EMMC Device Information : EMMC CID: 90014A48424734650507CDB511352254 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: HBG4e , S/N: CDB51135 , rev. 07 EMMC NAME (HEX): 484247346505 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Backup saved: HBG4e_CDB51135_20171208_103438.extcsd EMMC Init completed. Opening file: HTC_HTC One M9_msm8994_mmcblk0p67_.bin Analyzing Image: HTC_HTC One M9_msm8994_mmcblk0p67_.bin Vendor: Qualcomm Searching GPT ... GPT header is not found Searching MBR ... MBR header is not found Partition table not found HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 1711 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 90014A48424734650507CDB511352254 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: HBG4e , S/N: CDB51135 , rev. 07 EMMC NAME (HEX): 484247346505 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Backup saved: HBG4e_CDB51135_20171208_103447.extcsd EMMC Init completed. Opening file: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin Analyzing Image: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin Vendor: Qualcomm Searching GPT ... GPT header is found and is valid GPT header successfully parsed HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 1722 mV CMD Active Level: 2475 mV EMMC Device Information : EMMC CID: 90014A48424734650507CDB511352254 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: HBG4e , S/N: CDB51135 , rev. 07 EMMC NAME (HEX): 484247346505 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Backup saved: HBG4e_CDB51135_20171208_103519.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon) Partition name: GPT Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000000000000 , filesize: 17408 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Done writing partition. Write speed: 12,35 Kb/s Partition name: board_info Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000000004400 , filesize: 16384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 373,17 Kb/s Partition name: pg1fs Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000000008400 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1221,57 Kb/s Partition name: sbl1 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000000408400 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1236,98 Kb/s Partition name: pmic Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000000508400 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1233,91 Kb/s Partition name: dummy Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000000608400 , filesize: 41943040 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1160,41 Kb/s Partition name: reserve_1 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000002E08400 , filesize: 2063360 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1232,69 Kb/s Partition name: mfg Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000003000000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1137,59 Kb/s Partition name: pg2fs Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000003040000 , filesize: 24837120 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1228,74 Kb/s Partition name: rpm Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000047EFC00 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,65 Kb/s Partition name: tz Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000486FC00 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1230,87 Kb/s Partition name: sdi Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000004A6FC00 , filesize: 98304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 932,54 Kb/s Partition name: hyp Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000004A87C00 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1223,30 Kb/s Partition name: aboot Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000004C87C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1234,08 Kb/s Partition name: tool_diag Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000004D87C00 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1195,53 Kb/s Partition name: sp1 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000005787C00 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1200,88 Kb/s Partition name: ddr Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006187C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1232,00 Kb/s Partition name: rfg_0 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006287C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1233,96 Kb/s Partition name: rfg_1 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006387C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1230,53 Kb/s Partition name: rfg_2 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006487C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 218,93 Kb/s Partition name: rfg_3 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006587C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 234,93 Kb/s Partition name: rfg_4 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006687C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1090,20 Kb/s Partition name: rfg_5 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006787C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1227,64 Kb/s Partition name: rfg_6 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006887C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1228,67 Kb/s Partition name: rfg_7 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006987C00 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1226,35 Kb/s Partition name: fsg Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006A87C00 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1225,99 Kb/s Partition name: radio Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000006C07C00 , filesize: 61867008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1189,62 Kb/s Partition name: adsp Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000A708000 , filesize: 20971520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,40 Kb/s Partition name: limits Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000BB08000 , filesize: 1024 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 29,87 Kb/s Partition name: reserve_2 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000BB08400 , filesize: 5209088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,93 Kb/s Partition name: persist Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000C000000 , filesize: 23068672 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1229,82 Kb/s Partition name: ramdump Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000D600000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,86 Kb/s Partition name: misc Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000E000000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1237,06 Kb/s Partition name: modem_st1 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000E100000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1232,60 Kb/s Partition name: modem_st2 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000E280000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1201,34 Kb/s Partition name: fataldevlog Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000E400000 , filesize: 20971520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1230,87 Kb/s Partition name: devlog Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00000F800000 , filesize: 31457280 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,18 Kb/s Partition name: pdata Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011600000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1151,31 Kb/s Partition name: control Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011640000 , filesize: 16384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 378,57 Kb/s Partition name: extra Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011644000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 813,75 Kb/s Partition name: cdma_record Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011654000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1234,17 Kb/s Partition name: fsc Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011754000 , filesize: 1024 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 30,67 Kb/s Partition name: ssd Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011754400 , filesize: 8192 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 212,36 Kb/s Partition name: sensor_hub Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011756400 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1233,66 Kb/s Partition name: sec Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000117D6400 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1017,56 Kb/s Partition name: abootbak Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000117F6400 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1227,35 Kb/s Partition name: cir_img Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000118F6400 , filesize: 10240 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 251,22 Kb/s Partition name: local Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000118F8C00 , filesize: 1311744 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1207,82 Kb/s Partition name: frp Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011A39000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,83 Kb/s Partition name: cpe Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011AB9000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1228,57 Kb/s Partition name: carrier Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000011CB9000 , filesize: 20971520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,53 Kb/s Partition name: skylink Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000130B9000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1152,34 Kb/s Partition name: rfg_8 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000130F9000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1020,03 Kb/s Partition name: rfg_9 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000013119000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1023,61 Kb/s Partition name: rfg_10 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000013139000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1018,18 Kb/s Partition name: rfg_11 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000013159000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1017,49 Kb/s Partition name: rfg_12 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000013179000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1023,19 Kb/s Partition name: rfg_13 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000013199000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1019,39 Kb/s Partition name: rfg_14 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000131B9000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1015,62 Kb/s Partition name: rfg_15 Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000131D9000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1017,79 Kb/s Partition name: absolute Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000131F9000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,23 Kb/s Partition name: reserve Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 0000141F9000 , filesize: 14708736 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1228,29 Kb/s Partition name: hosd Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000015000000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1230,68 Kb/s Partition name: boot Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000019000000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1230,68 Kb/s Partition name: recovery Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 00001D000000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1231,55 Kb/s Partition name: cache Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000021000000 , filesize: 335544320 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1115,05 Kb/s Partition name: system Filename: HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin , Offset: 000035000000 , filesize: 4697620480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 0000E9780000 ... Retry #1 Error writing at address: 0000EAC00000 ... Retry #1 Error writing at address: 0000EB380000 ... Retry #1 Error writing at address: 0000EBE00000 ... Retry #1 Error writing at address: 0000EC800000 ... Retry #1 Error writing at address: 0000ED300000 ... Retry #1 Error writing at address: 0000EDF00000 ... Retry #1 Error writing at address: 0000EEA00000 ... Retry #1 Error writing at address: 0000EF580000 ... Retry #1 Error writing at address: 0000F0080000 ... Retry #1 Error writing at address: 0000F0B80000 ... Retry #1 Error writing at address: 000105280000 ... Retry #1 Error writing at address: 000107D00000 ... Retry #1 Error writing at address: 00010B280000 ... Retry #1 Done writing partition. Write speed: 1015,22 Kb/s Check BOOT_PARTITION_EN for the selected vendor All done Has anyone the possibilty to upload from a working unit the rom1, rom2, rom3 and extcsd files? As I've read someone has powered on another phone with thos 4 files. Thank you very much! |
12-08-2017, 18:34 | #3 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | I've already did universal format. I forgot to mention. In this log you can see that is not able to write it with easy jtag tool. I can write dump only with easy jtag plus and emmc qcomm flasher. Code: EMMC CID : 90014A48424734650507CDB511352254 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 3451195701 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _3451195701_20171208_1827.extcsd Partition table scan: GPT: not present Done. Running:eMMC: Factory Format... Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1711 mV CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:21000 khz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. Checking NAND Image : D:\dsk3\HTC_M9_BGND3R_ROM1_OK\Desktop\HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Detected LINUX(Android) SYSTEM : 0x0035000000 (4.375GB) Unable to mount SYSTEM , code : 95 File successefuly loaded! Real (Hardware) Disk/Image size: 1D1EFFF sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 3A1BFDD sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 60932095 Processing file...D:\dsk3\HTC_M9_BGND3R_ROM1_OK\Desktop\HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin Writing as RAW data Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1711 mV CMD Active Level:2217 mV Input file : D:\dsk3\HTC_M9_BGND3R_ROM1_OK\Desktop\HTC_HTC One M9_msm8994_mmcblk0_ROM1.bin Writing 03A3E00000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) |
12-08-2017, 18:43 | #4 (permalink) |
No Life Poster Join Date: Jan 2003 Location: GMT +5 Age: 49
Member: 19737 Status: Offline Thanks Meter: 133 | Is rom1 is writeable? If yes then easy jtag not able to repair it. Check after write rom1. |
The Following User Says Thank You to Jani-Jan For This Useful Post: |
12-08-2017, 19:05 | #6 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | This is what I get with easy jtag plus (emmc tool suite): Code: HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 1722 mV CMD Active Level: 2237 mV EMMC Device Information : EMMC CID: 90014A48424734650507CDB511352254 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: HBG4e , S/N: CDB51135 , rev. 07 EMMC NAME (HEX): 484247346505 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Backup saved: HBG4e_CDB51135_20171208_190202.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version Firmware info not found |
12-08-2017, 19:27 | #7 (permalink) |
Member: 19737 Status: Offline Thanks Meter: 133 | Ok. The only fault is your dump. Dump is not good. You need to find a good dump for this phone i mean rom1. Or you can try one more thing first write rom1 with easyjtag classic. And see if partitions are shown? |
12-09-2017, 07:04 | #10 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Quote:
http://forum.gsmhosting.com/vbb/f672...again-2273566/ http://forum.gsmhosting.com/vbb/f672...epair-2266263/ | |
The Following User Says Thank You to ALI_MAFIA For This Useful Post: |
12-09-2017, 15:02 | #11 (permalink) | |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote: as I see in your posts the GPT area is damaged: Code: Partition table scan: GPT: damaged Code: Partition table scan: GPT: not present Code: Input file : D:\dsk3\HTC_M9_BGND3R_ROM1_OK\HTC_M9_BGND3R_ROM1_OK.bin Writing 004D800000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Thank you very much! | |
