11-24-2018, 11:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Bangalore
Member: 391038 Status: Offline Thanks Meter: 81 | how to hardreset via z3x jtag usb connection broken kindly help to hardreset J701F as the usb connectons are broken. problem - password lock. Setting frequence to 14 Mhz CMD Pullup Level: 1165 mV CMD Active Level: 2196 mV EMMC Device Information : EMMC CID: 150100414A5444345200E525B85B4524 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: AJTD4R , HEX: 414A54443452 , S/N: E525B85B , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJTD4R_E525B85B_20181124_153923.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: CARRIER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: OTA, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: RADIO, [000008B00000 - 00000E300000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E300000 - 00000E400000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E400000 - 00000E480000], size: 000000080000 (512. KB) Partition: STEADY, [00000E480000 - 00000E880000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000E880000 - 00000F000000], size: 000000780000 (7.50 MB) Partition: SYSTEM, [00000F000000 - 0000CF000000], size: 0000C0000000 (3.00 GB) Partition: CACHE, [0000CF000000 - 0000DB800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000DB800000 - 0000E1C00000], size: 000006400000 (100. MB) Partition: CP_DEBUG, [0000E1C00000 - 0000E2100000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000E2100000 - 0000E3500000], size: 000001400000 (20.0 MB) Partition: NAD_REFER, [0000E3500000 - 0000E3600000], size: 000000100000 (1.00 MB) Partition: USERDATA, [0000E3600000 - 0003AAE00000], size: 0002C7800000 (11.1 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J701F Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 7.0 Firmware version = NRD90M.J701FDDU3ARB1 Firmware date = Fri Feb 2 19:30:47 KST 2018 |
