Old 03-12-2020, 08:52   #1 (permalink)
Member: 2253249
Thanks Meter: 29
Need help suport team
SET NOT ON ONLY VIBRATE
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 MHz
EMMC Device Information :
EMMC CID: 150100514536334D4203B2EB9AD7A529
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: B2EB9AD7 , rev. 0x03
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2018
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 42740 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_B2EB9AD7_20200312_131821.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB)
Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB)
Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB)
Partition: expdb, [000004188000 - 000005588000], size: 000001400000 (20.0 MB)
Partition: frp, [000005588000 - 000005688000], size: 000000100000 (1.00 MB)
Partition: nvcfg, [000005688000 - 000007688000], size: 000002000000 (32.0 MB)
Partition: nvdata, [000007688000 - 00000B688000], size: 000004000000 (64.0 MB)
Partition: metadata, [00000B688000 - 00000D688000], size: 000002000000 (32.0 MB)
Partition: protect1, [00000D688000 - 00000DE88000], size: 000000800000 (8.00 MB)
Partition: protect2, [00000DE88000 - 00000E800000], size: 000000978000 (9.47 MB)
Partition: seccfg, [00000E800000 - 00000F000000], size: 000000800000 (8.00 MB)
Partition: persist, [00000F000000 - 000013000000], size: 000004000000 (64.0 MB)
Partition: sec1, [000013000000 - 000013200000], size: 000000200000 (2.00 MB)
Partition: proinfo, [000013200000 - 000013500000], size: 000000300000 (3.00 MB)
Partition: efuse, [000013500000 - 000013580000], size: 000000080000 (512. KB)
Partition: md1img, [000013580000 - 000019980000], size: 000006400000 (100. MB)
Partition: spmfw, [000019980000 - 000019A80000], size: 000000100000 (1.00 MB)
Partition: scp1, [000019A80000 - 000019B80000], size: 000000100000 (1.00 MB)
Partition: scp2, [000019B80000 - 000019C80000], size: 000000100000 (1.00 MB)
Partition: sspm_1, [000019C80000 - 000019D80000], size: 000000100000 (1.00 MB)
Partition: sspm_2, [000019D80000 - 000019E80000], size: 000000100000 (1.00 MB)
Partition: gz1, [000019E80000 - 00001AE80000], size: 000001000000 (16.0 MB)
Partition: gz2, [00001AE80000 - 00001BE80000], size: 000001000000 (16.0 MB)
Partition: nvram, [00001BE80000 - 00001FE80000], size: 000004000000 (64.0 MB)
Partition: vbmeta, [00001FE80000 - 000020680000], size: 000000800000 (8.00 MB)
Partition: lk, [000020680000 - 000020780000], size: 000000100000 (1.00 MB)
Partition: lk2, [000020780000 - 000020880000], size: 000000100000 (1.00 MB)
Partition: boot, [000020880000 - 000024880000], size: 000004000000 (64.0 MB)
Partition: logo, [000024880000 - 000028880000], size: 000004000000 (64.0 MB)
Partition: odmdtbo, [000028880000 - 000029880000], size: 000001000000 (16.0 MB)
Partition: cust, [000029880000 - 000049880000], size: 000020000000 (512. MB)
Partition: tee1, [000049880000 - 000049D80000], size: 000000500000 (5.00 MB)
Partition: tee2, [000049D80000 - 00004A280000], size: 000000500000 (5.00 MB)
Partition: pad, [00004A280000 - 00004A800000], size: 000000580000 (5.50 MB)
Partition: vendor, [00004A800000 - 00007A800000], size: 000030000000 (768. MB)
Partition: system, [00007A800000 - 00011A800000], size: 0000A0000000 (2.50 GB)
Partition: devinfo, [00011A800000 - 00011B000000], size: 000000800000 (8.00 MB)
Partition: cache, [00011B000000 - 00012B000000], size: 000010000000 (256. MB)
Partition: userdata, [00012B000000 - 0003A02FBE00], size: 0002752FBE00 (9.83 GB)
Partition: otp, [0003A02FBE00 - 0003A2DFBE00], size: 000002B00000 (43.0 MB)
Partition: flashinfo, [0003A2DFBE00 - 0003A3DFBE00], size: 000001000000 (16.0 MB)
GPT header successfully parsed
Get firmware version
Brand = xiaomi
Manufacturer = Xiaomi
Device = cactus
Model = Redmi 6A
CPU Abi = armeabi-v7a
Android release = 8.1.0
Firmware version = O11019
Miui Version = V9.6.2.0.OCBMIFD
Firmware date = Tue Jun 12 00:34:23 WIB 2018
Old 03-13-2020, 15:50   #2 (permalink)
Member: 2253249
Thanks Meter: 29
no reply easy jteg team
Old 03-13-2020, 16:17   #3 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
to get answer you need
1) describe problem
2) ask question
3) write info about you do to solve problem
Old 03-15-2020, 19:46   #4 (permalink)
Member: 2253249
Thanks Meter: 29
1- mi 6a set only vibrate after full flash via easy jtag vender
2..... Log avlabhle in first post .any mistake for flashing
3. You sajess me how to repair dead sat 6a no dump avelable
Old 03-15-2020, 19:48   #5 (permalink)
Member: 2253249
Thanks Meter: 29
1) describe problem
2) ask question
Sir mobile is vibrate only
Old 03-15-2020, 20:21   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
and what?
take it to a repair firm
or do you think that I from another country on the Internet should determine what is specifically faulty with you?
it's may be harwdare problem
use search and read forum, how other people do same or simular device
I can't work with this device, i can't help you with it
Old 03-17-2020, 10:07   #7 (permalink)
Member: 2253249
Thanks Meter: 29
sir not ahardwear prob set dead after flash via vender
Old 03-17-2020, 12:20   #8 (permalink)
Member: 1698085
Sonork: cataljn
Hello! i need firmware for an allview p9 energy lite please, or a full backup system...??
Old 03-18-2020, 15:01   #9 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
start by search botton
read this thread, it will help you
http://forum.gsmhosting.com/vbb/f672...endor-2745250/
regards
Page generated in 0.20712 seconds with 8 queries
