Old 03-18-2020, 13:00   #1 (permalink)
Member: 2630755
Thanks Meter: 63
how to remove a305f mdm lock
Setting interface to EasyJtag2/ISP
Setting bus width to 4 Bit
Setting frequence to 6 MHz
CMD Pullup Level: 477 mV
CMD Active Level: 2460 mV
EMMC Device Information :
EMMC CID: 150100435554413432003D39CC3F56A9
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: 3D39CC3F , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Maybe not clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: CUTA42_3D39CC3F_20200318_170830.extcsd
EMMC Init completed.
Warning: BusWidth is automatically set to 1 Bit
Scanning soft partitions
GPT header is found and is valid
Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB)
Partition: bota1, [000000800000 - 000001000000], size: 000000800000 (8.00 MB)
Partition: efs, [000001000000 - 000002400000], size: 000001400000 (20.0 MB)
Partition: sec_efs, [000002400000 - 000003800000], size: 000001400000 (20.0 MB)
Partition: cpefs, [000003800000 - 000004000000], size: 000000800000 (8.00 MB)
Partition: bota2, [000004000000 - 000004800000], size: 000000800000 (8.00 MB)
Partition: cm, [000004800000 - 000005000000], size: 000000800000 (8.00 MB)
Partition: m9kefs1, [000005000000 - 000005400000], size: 000000400000 (4.00 MB)
Partition: m9kefs2, [000005400000 - 000005800000], size: 000000400000 (4.00 MB)
Partition: m9kefs3, [000005800000 - 000005C00000], size: 000000400000 (4.00 MB)
Partition: nad_refer, [000005C00000 - 000005D00000], size: 000000100000 (1.00 MB)
Partition: param, [000005D00000 - 000006500000], size: 000000800000 (8.00 MB)
Partition: up_param, [000006500000 - 000006D00000], size: 000000800000 (8.00 MB)
Partition: misc, [000006D00000 - 000006F00000], size: 000000200000 (2.00 MB)
Partition: boot, [000006F00000 - 000009300000], size: 000002400000 (36.0 MB)
Partition: recovery, [000009300000 - 00000C800000], size: 000003500000 (53.0 MB)
Partition: dtb, [00000C800000 - 00000D000000], size: 000000800000 (8.00 MB)
Partition: dtbo, [00000D000000 - 00000D800000], size: 000000800000 (8.00 MB)
Partition: radio, [00000D800000 - 000010500000], size: 000002D00000 (45.0 MB)
Partition: persistent, [000010500000 - 000010580000], size: 000000080000 (512. KB)
Partition: steady, [000010580000 - 000010980000], size: 000000400000 (4.00 MB)
Partition: vbmeta, [000010980000 - 000010A00000], size: 000000080000 (512. KB)
Partition: bota3, [000010A00000 - 000010A80000], size: 000000080000 (512. KB)
Partition: reserved2, [000010A80000 - 000011000000], size: 000000580000 (5.50 MB)
Partition: system, [000011000000 - 00013D000000], size: 00012C000000 (4.69 GB)
Partition: vendor, [00013D000000 - 000160800000], size: 000023800000 (568. MB)
Partition: product, [000160800000 - 000179800000], size: 000019000000 (400. MB)
Partition: cache, [000179800000 - 000192800000], size: 000019000000 (400. MB)
Partition: omr, [000192800000 - 000195A00000], size: 000003200000 (50.0 MB)
Partition: cp_debug, [000195A00000 - 000195F00000], size: 000000500000 (5.00 MB)
Partition: nad_fw, [000195F00000 - 000197300000], size: 000001400000 (20.0 MB)
Partition: userdata, [000197300000 - 000E8F300000], size: 000CF8000000 (51.8 GB)
GPT header successfully parsed
Get firmware version
Error: Mount [data] failed PartType: LINUX
Error: Except: Unmount [data/] failed
Page generated in 0.16963 seconds with 8 queries
