how to remove mdm lock on j415f use easy jtag+ https://i.imgur.com/STfgok9.png MDM does not allow factoryReset use easy jtag plus for read and factory reset link full https://www.youtube.com/watch?v=78KShSh9mHQ&t=515s |
bro i was can not see format on easy jtag+ you only read video........ |
I have done many mdm phones via easy jtag 1. flash the combination firmware via easyjtag plus / write by vendor 2. Disconnect the phone 3. Now you will have the download mode 4. Put your in download mode connect usb, Flash the latest firmware ( but do not complete the setup process, it will relock ) 5. Now just root your phone. ( once knox is tripped, mdm will not relock and it will be removed. |
http://i101.fastpic.ru/big/2018/0118...fbccb1cf1c.png |
what if oem and frp lock on ? |
U Still Can..After Write Combination Remove FRP N Disable OEM 1st Then Follow Rest...:);) |
After watch video one doubt! You read by vender, only this? Maybe you have cutoff the part shows us hou remove MDM! Can you explain here? Thanks. Quote:
but do not complete the setup process, it will relock so wat files shouldnt flash ? |
