Xiaomi Mi account How can i remove Xiaomi Mi account? With Easy Jtag? |
To remove Mi account you need remove record from Xiaomi servers |
but for example, with UMT box I can do a bypass of that account, I just do not have to reset it or update it because the block would reappear, with Easy jtag there must be some option to do that bypass and I have seen that they do it with easy jtag, but I do not know what partition to delete |
not for bypass brand online sevices For some deviced where are found "patched" firmwares with "cutted" Mi services |
The only workaround is to remove programs (Mi services), which connected to the Internet, connect to servers and check locks. These are solutions from the discharge of the firmware patch. We do not work in this direction. Making changes to device firmware is not our business. Among other things, many users require for Mi services to remain working. |
yes you r right i dont no this thing but i want to know why dose not work persist file in new mi model plese peply |
al stop frm here this is not xiaomi section but all in all just knw easyjtag's goals are in different direction whereas we are talking about somn else its like doing im** repair jtag has the capacity to but thats not there intrest "if u can dig as deep as the rpmb sector on the emmc chip " what of modem or fsg or somn else |
new models is check lock at Xiaomi servers olny way - create firmwares with removed "Mi" service (need Unlocked boot) or remove lock via Xiaomi service center (remove from servers) |
Please add mi account reset Dear product supporter please add mi account reset option . Thanks in advance |
Mi akk is stored at Xiaomi servers, as Apple How we can removed it? |
Sent from my iPhone using Tapatalk |
1. If you erase the persist on a device with a fingerprint sensor, the device will not be able to use wifi and sensors, some time phone lost internal memory. 2. Disabling finddevice(delete or do some thing with finddevice.apk) on devices running miui 10 or later may cause continuous crashes, with devices running miui 11 after connecting the wifi the phone will automatically download finddevice.apk and install it after reboot. you can only install custom fw on your phone to hide mi services but that requires unlocking the device bootloader. |
