Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-26-2019, 05:29   #16 (permalink)
Member: 704044
Thanks Meter: 181
Originally Posted by duythangvn View Post
1. If you erase the persist on a device with a fingerprint sensor, the device will not be able to use wifi and sensors, some time phone lost internal memory.
2. Disabling finddevice(delete or do some thing with finddevice.apk) on devices running miui 10 or later may cause continuous crashes, with devices running miui 11 after connecting the wifi the phone will automatically download finddevice.apk and install it after reboot. you can only install custom fw on your phone to hide mi services but that requires unlocking the device bootloader.
OK BRO BUT IN OTHER BOX( u box) they add mi reset and their customers doing reset mi account in Redmi 6A and other mi login
auth need mobiles easily by other box
Sent from my iPhone using Tapatalk
Old 11-26-2019, 10:45   #17 (permalink)
Member: 13148
Thanks Meter: 1,501
you can erase any partition or format it at our software (at EasyJTAG Classic at "Partition" tab) and at EasyJTAG Plus software at "Write by vendor" tab
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 01-17-2020, 18:48   #18 (permalink)
Member: 1584617
Thanks Meter: 2
How to remove mi account easyjtag
The Following User Says Thank You to mamuntelecom2 For This Useful Post:
Old 01-17-2020, 19:02   #19 (permalink)
Member: 704044
Thanks Meter: 181
Dear supporter please add one click to remove mi account option
Old 01-17-2020, 22:07   #20 (permalink)
Member: 13148
Thanks Meter: 1,501
How is Z3x team have access to Xiaomi online servers?
You will use Google to find some services, who has access to Xiaomo online services and can edit records at it via you money
The Following User Says Thank You to layder For This Useful Post:
Old 01-20-2020, 08:36   #21 (permalink)
Member: 575256
Thanks Meter: 31
How to Unlock account Mi by easy jtag
Hello Guyss Iam don't known,,, Ho is unlock Mi account , step by step With Easy jtag / easy jtag plusss??? please share Here orr show me with video, or tutor with pictureeeee,,,,
Best regard Manggolo yudho
Old 01-20-2020, 10:00   #22 (permalink)
Member: 13148
Thanks Meter: 1,501
More letter size, use CAPS LETTERS.....
No need use search!!!!! ONLY I CAN BIG AND NEED INDIVIDUAL ANSWER!!!!!
Old 01-23-2020, 05:54   #23 (permalink)
Member: 1797183
Thanks Meter: 38
Friends please do not be so raw, understand one thing, that service has nothing to do with the EMMC-UFS- program, if you want to do something like that you need to learn to read, understand, analyze and when you learn you will not ask stupidities like that .. .
The Following 2 Users Say Thank You to Clinphone For This Useful Post:
Old 01-23-2020, 14:09   #24 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 270
Redmi 6 & 6a mi account possible ?
redmi 6 & 6a mi account removing possible via Easy jtag ? i did mi 6pro(Qualcomm) mi account done easy jtag but i dont know about mtk chip's thank's.
Old 01-23-2020, 14:43   #25 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 890
Can you please explain how you did for Qualcomm
Old 01-23-2020, 15:13   #26 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 270
write persist file select erase before writing option on write by vendor ...untick repartition option
The Following User Says Thank You to ChandruChiyyan For This Useful Post:
Old 01-24-2020, 07:30   #27 (permalink)
Member: 2684136
Thanks Meter: 82
[QUOTE=ChandruChiyyan;13984454]write persist file select erase before writing option on write by vendor ...untick repartition option [/QUOT
persist file which comes in stock rom or need any modified persist file?
Old 01-24-2020, 10:58   #28 (permalink)
Member: 13148
Thanks Meter: 1,501
[QUOTE=Vijay1555;13985053]
persist file from original firmware.
but after you phone connect to internet - it check lock at xiaomi servers automatic
Old 02-01-2020, 19:17   #29 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,289
[QUOTE=layder;13985301]
Yeah But User Can Avoid This By Disable MI Cloud Service Apps Via ADB...
For Users Who Is Looking For Temp Or Bypass Solution Can Follow This
#Do ISP Or Chip OFF
#Open Easy Plus Module
#Open Write By Vendor Option N DO Detect
#Erase Persist N Write Persist From Factory Firmware
Note:-Make Sure U Untick Erase N Reparation Option...
Now Disconnect N Reinstall Chip Or Remove ISP Jumpers N Check If Account Byass Then Ok If Not Do Reset Via Recovery Using Any Box Which Support Recovery Reset...
After Power On Phone Now Enable ADB N Disable MI Cloud Apps To Avoid Relock...
The Following 2 Users Say Thank You to hitech care For This Useful Post:
Page generated in 0.42570 seconds with 7 queries
