07-18-2014, 17:52 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | How to repair EMMC LG P765 ???/ file on support not bin but like this mmcblk0 where rom 1/2 and csd file Z3X EasyJtag Software ver. 1.5.6.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: , ,FW Ver.: 01.50 CMD Pullup Level:1742 mV CMD Active Level:1866 mV eMMC Device Information EMMC CID : 65646F4D204D4F524E460001000000F0 EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0065 , OEM ID: 646F EMMC Date: 00/2013 Rev.0x46 EMMC NAME: M MORN , S/N: 65536 EMMC ROM1 (Main User Data) Capacity: 2097152 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: M MORN_ 65536_20140605_2350.extcsd Done. |
09-22-2014, 16:57 | #3 (permalink) |
Junior Member Join Date: Apr 2008
Member: 757215 Status: Offline Thanks Meter: 8 | hello...i need help to ..what should i do if log like this Z3X EasyJtag Software ver. 1.6.1.1 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0500E013EA335155, ,FW Ver.: 01.50 CMD Pullup Level:1732 mV CMD Active Level:1825 mV eMMC Device Information EMMC CID : 90014A2058494E594812A10011F8AF8A EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 10/2012 Rev.0x12 EMMC NAME: XINYH , S/N: 2701136376 EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x40] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x40. Backup saved: XINYH_2701136376_20140801_2352.extcsd Searching for partition tables... Partitioning not detected... Done. |
09-24-2014, 21:11 | #4 (permalink) |
Freak Poster Join Date: May 2010
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 36 | Z3X EasyJtag Software ver. 1.6.1.4 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0800B006F662B313, ,FW Ver.: 01.50 CMD Pullup Level:1773 mV CMD Active Level:1825 mV eMMC Device Information EMMC CID : 65646F4D204D4F524E460002000000FA EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0065 , OEM ID: 646F EMMC Date: 00/2013 Rev.0x46 EMMC NAME: M MORN , S/N: 131072 EMMC ROM1 (Main User Data) Capacity: 2097152 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: M MORN_ 131072_20140804_0308.extcsd Done. How to repair?? |
09-26-2014, 09:44 | #5 (permalink) | |
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Quote:
09-26-2014, 09:45 | #6 (permalink) | |
06-08-2015, 10:59 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | READ INFO AND READ FLASH OK... BUT WRITING ERROR. ------------------------------------------------------- Z3X EasyJtag Software ver. 2.0.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: ................., ,FW Ver.: 01.52 CMD Pullup Level:1619 mV CMD Active Level:1608 mV eMMC Device Information EMMC CID : 90014A2058494E594813A1001429308C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2013 Rev.0x13 EMMC NAME: XINYH , S/N: 2701136937 EMMC NAME (HEX): 2058494E594800 EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x40] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x40. Backup saved: XINYH_2701136937_20150501_1526.extcsd Done. ------------------------------------------------------------- Z3X EasyJtag Software ver. 2.0.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1619 mV CMD Active Level:1608 mV Output file :C:\Documents and Settings\1\My Documents\Downloads\Compressed\P765_mmcblk0_rom1_b y_z3x_team_ok\EMMC_ROM1_00000000_40000000.bin Reading 0x000040000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) --------------------------------------------------------------------------- Checking NAND Image : C:\Documents and Settings\1\My Documents\Downloads\Compressed\P765_mmcblk0_rom1_b y_z3x_team_ok\P765_mmcblk0_rom1_by_z3x_team_ok.bin File successefuly loaded! Processing file...C:\Documents and Settings\1\My Documents\Downloads\Compressed\P765_mmcblk0_rom1_b y_z3x_team_ok\P765_mmcblk0_rom1_by_z3x_team_ok.bin Z3X EasyJtag Software ver. 2.0.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1619 mV CMD Active Level:1608 mV Input file : C:\Documents and Settings\1\My Documents\Downloads\Compressed\P765_mmcblk0_rom1_b y_z3x_team_ok\P765_mmcblk0_rom1_by_z3x_team_ok.bin Writing 0040000000 bytes to 00000000 ...ROM1 (USER ROM) Retry writing adress 0x00000000 (Attempt #1)... Retry Fail! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail! Write Block Failed, Reason: DATA SND CRC Error Done. |
06-08-2015, 11:01 | #8 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Quote:
The Following User Says Thank You to ALI_MAFIA For This Useful Post: |
03-15-2017, 21:50 | #9 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Chin
Member: 1531030 Status: Offline Sonork: Yahoo_Akm Thanks Meter: 118 | LG-P765 Need Halp Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 0xxxxxxxxxx, ,FW Ver.: 01.58 CMD Pullup Level:1701 mV CMD Active Level:1794 mV Box IO Level:1800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 65646F4D204D4F524E460001000000F0 EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0065 , OEM ID: 646F EMMC Date: 00/2013 Rev.0x46 EMMC NAME: M MORN , S/N: 65536 EMMC NAME (HEX): 4D204D4F524E00 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. |
