Old 07-23-2019, 11:44   #1 (permalink)
Member: 1095362
Thanks Meter: 70
Oppo A3s (Cph1803) Dead
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 06009012EE2027F8
Card Serial = AACBB1DC
EasyJTAG Box Firmware = 1.63
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting frequence to 21 MHz
CMD Pullup Level: 1670 mV
CMD Active Level: 1722 mV
EMMC Device Information :
EMMC CID: 150100514536334D420607E00685A5BC
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 07E00685 , rev. 0x06
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 26109 , Response: Not Clean
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Backup saved: QE63MB_07E00685_20190723_160255.extcsd
EMMC Init completed.
Get firmware version
Firmware info not found
Hello Team,
any Help.
Phone was pattern lock After reset only qualcomm mode showing.
I Tried to flash userdata and cache but same problem..
Made clk jumper
any other ideas??
Old 07-23-2019, 11:46   #2 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
Changelog:
Hello Team,
any Help.
Made clk jumper
any other ideas??
i have success with remove clk and make jumper.
The Following User Says Thank You to Deni's For This Useful Post:
Old 07-23-2019, 11:54   #3 (permalink)
Member: 1095362
Thanks Meter: 70
I too removed Clk And Make Jumper.
But any idea about this
It should show firmware info or not?
Do I need To full Flash Device if yes then what version Should i choose?
Old 07-23-2019, 14:02   #4 (permalink)
Member: 1095362
Thanks Meter: 70
After Writing userdata and Cache
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D420607E00685A5BC
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 10/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 132122245
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 26109 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_ 132122245_20190723_1829.extcsd
Warning! Disk size is smaller than the main header indicates!
Warning! Main and backup partition tables differ!
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
Unable to read gesture.key , code 2
Done.
Old 07-24-2019, 03:27   #5 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
Done.
you have 16gb emmc on this log, yet userdata is 32gb emmc, how is that possible?
Old 07-24-2019, 10:08   #6 (permalink)
Member: 1095362
Thanks Meter: 70
Maybe i just flashed wrong userdata or something.
so what to do now?
Any help is greatly appreciated.
Old 07-24-2019, 13:11   #7 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
flash with latest 1803 firmware, CPH1803EX_11_A.18 i think is the latest
Old 07-28-2019, 05:40   #8 (permalink)
Member: 2748979
Sonork: 100.1678676
Thanks Meter: 4
cph 1853 dump file need
Old 07-28-2019, 05:43   #9 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
you don't need dump file, download latest 1853 ofp and extract it by easy jtag plus software then write via vendor
The Following 2 Users Say Thank You to rico_deep For This Useful Post:
Old 11-22-2019, 16:25   #10 (permalink)
Member: 2920844
after flash write by vendor now imei problem
Old 11-23-2019, 01:43   #11 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
u can repaire imei by other tool
Old 11-23-2019, 01:54   #12 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
download this
https://www.4shared.com/rar/uXG1T1jB...cham-gsm.html?
passowrd : hicham-gsm
write by vendor
oppodycnvbk + oppostanvbk + modemst1 + modemst2 + fsg + sec + modem
you will restor original imei
tested by me
The Following 2 Users Say Thank You to elpring For This Useful Post:
Old 11-26-2019, 05:36   #13 (permalink)
Registered User
Member: 1129019
Sonork: first aider
Thanks Meter: 19
hi sir do you remove only.?then after you flashed ,did you return it or not ?thank you sir
Old 12-02-2019, 22:43   #14 (permalink)
Member: 1418143
Thanks Meter: 353
I need that file to fix mine QE63MB.extcsd
Old 12-02-2019, 23:55   #15 (permalink)
sifou474's Avatar
Member: 60699
Thanks Meter: 189
I upload the file read by other tool
File Type: rar ext_csd.rar (212 Bytes, 417 views)
The Following User Says Thank You to sifou474 For This Useful Post:
Page generated in 0.25383 seconds with 9 queries
