12-22-2017, 05:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | HTC 820 A51 UL hang in logo-tried to flash-now boot dead-need procedure-help me new easy jtag user-htc d820n which jtag tool repair? need procedure also help me-urgent |
01-02-2018, 14:44 | #9 (permalink) |
No Life Poster Join Date: Nov 2005 Location: morrocco
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | 02/01/2018 12:47:10> eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) 02/01/2018 12:47:10> Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385) 02/01/2018 12:47:10> 02/01/2018 12:47:10> Looking for EasyJTAG box... 02/01/2018 12:47:10> EasyJTAG API ver. 2022 02/01/2018 12:47:12> OpenUSB returned = 0 02/01/2018 12:47:13> EasyJTAG Box Serial = 0F00E00C0D23EDA9 02/01/2018 12:47:17> Card Serial = AACC-AFB4 02/01/2018 12:47:17> CardAttr = 3B7D95000080318065B0831148C883009000 02/01/2018 12:47:17> EasyJTAG Box Firmware = 1.62 02/01/2018 12:47:17> 02/01/2018 12:47:25> Looking for EasyJTAG box... 02/01/2018 12:47:26> EasyJTAG API ver. 2022 02/01/2018 12:47:26> Setting IO Levels to 2.8V 02/01/2018 12:47:26> Setting frequence to 14 Mhz 02/01/2018 12:47:26> EasyJTAG Box Serial = 0F00E00C0D23EDA9 02/01/2018 12:47:26> EasyJTAG Box Firmware = 1.62 02/01/2018 12:47:27> Setting frequence to 14 Mhz 02/01/2018 12:47:27> CMD Pullup Level: 1907 mV 02/01/2018 12:47:27> CMD Active Level: 2258 mV 02/01/2018 12:47:27> eMMC Init returned = 0 02/01/2018 12:47:27> EMMC Device Information : 02/01/2018 12:47:27> EMMC CID: 90014A484147326505078150E0544262 02/01/2018 12:47:27> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 02/01/2018 12:47:27> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 8150E054 , rev. 0x07 02/01/2018 12:47:27> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015 02/01/2018 12:47:27> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) 02/01/2018 12:47:27> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 02/01/2018 12:47:27> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 02/01/2018 12:47:27> EMMC Permanent Write Protection: No 02/01/2018 12:47:27> EMMC Temporary Write Protection: No 02/01/2018 12:47:27> Extended CSD Information : 02/01/2018 12:47:27> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 02/01/2018 12:47:27> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 02/01/2018 12:47:27> Boot Bus Config: 0x00 , width 1bit 02/01/2018 12:47:27> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 02/01/2018 12:47:27> Supported partition features [PARTITIONING_SUPPORT]: 0x07 02/01/2018 12:47:27> Device supports partitioning features 02/01/2018 12:47:27> Device can have enhanced technological features in partitions and user data area 02/01/2018 12:47:27> Device can have extended partitions attribute 02/01/2018 12:47:27> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 02/01/2018 12:47:27> Backup saved: HAG2e_8150E054_20180102_124727.extcsd 02/01/2018 12:47:27> EMMC Init completed. 02/01/2018 12:47:27> 02/01/2018 12:47:27> Warning: Health report is very BAD 02/01/2018 12:47:27> 02/01/2018 12:47:27> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 02/01/2018 12:47:27> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 02/01/2018 12:47:27> Pre EOL information [267]: 0x03 Urgent 02/01/2018 12:47:27> 02/01/2018 12:47:27> Scanning soft partitions 02/01/2018 12:47:44> Partition table not found 02/01/2018 12:47:44> 02/01/2018 12:47:44> Get firmware version 02/01/2018 12:49:17> Firmware info not found 02/01/2018 12:49:20> 02/01/2018 12:49:20> Looking for EasyJTAG box... 02/01/2018 12:49:20> EasyJTAG API ver. 2022 02/01/2018 12:49:20> Setting IO Levels to 2.8V 02/01/2018 12:49:20> Setting frequence to 14 Mhz 02/01/2018 12:49:20> EasyJTAG Box Serial = 0F00E00C0D23EDA9 02/01/2018 12:49:20> EasyJTAG Box Firmware = 1.62 02/01/2018 12:49:22> Setting frequence to 14 Mhz 02/01/2018 12:49:22> CMD Pullup Level: 1907 mV 02/01/2018 12:49:22> CMD Active Level: 2258 mV 02/01/2018 12:49:22> eMMC Init returned = 0 02/01/2018 12:49:22> EMMC Device Information : 02/01/2018 12:49:22> EMMC CID: 90014A484147326505078150E0544262 02/01/2018 12:49:22> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 02/01/2018 12:49:22> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 8150E054 , rev. 0x07 02/01/2018 12:49:22> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015 02/01/2018 12:49:22> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) 02/01/2018 12:49:22> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 02/01/2018 12:49:22> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 02/01/2018 12:49:22> EMMC Permanent Write Protection: No 02/01/2018 12:49:22> EMMC Temporary Write Protection: No 02/01/2018 12:49:22> Extended CSD Information : 02/01/2018 12:49:22> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 02/01/2018 12:49:22> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 02/01/2018 12:49:22> Boot Bus Config: 0x00 , width 1bit 02/01/2018 12:49:22> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 02/01/2018 12:49:22> Supported partition features [PARTITIONING_SUPPORT]: 0x07 02/01/2018 12:49:22> Device supports partitioning features 02/01/2018 12:49:22> Device can have enhanced technological features in partitions and user data area 02/01/2018 12:49:22> Device can have extended partitions attribute 02/01/2018 12:49:22> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 02/01/2018 12:49:22> Backup saved: HAG2e_8150E054_20180102_124922.extcsd 02/01/2018 12:49:22> EMMC Init completed. 02/01/2018 12:49:22> 02/01/2018 12:49:22> Warning: Health report is very BAD 02/01/2018 12:49:22> 02/01/2018 12:49:22> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 02/01/2018 12:49:22> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 02/01/2018 12:49:22> Pre EOL information [267]: 0x03 Urgent 02/01/2018 12:49:22> 02/01/2018 12:49:32> Looking for EasyJTAG box... 02/01/2018 12:49:32> EasyJTAG API ver. 2022 02/01/2018 12:49:32> Setting IO Levels to 2.8V 02/01/2018 12:49:32> Setting frequence to 14 Mhz 02/01/2018 12:49:32> EasyJTAG Box Serial = 0F00E00C0D23EDA9 02/01/2018 12:49:32> EasyJTAG Box Firmware = 1.62 02/01/2018 12:49:33> Setting frequence to 14 Mhz 02/01/2018 12:49:33> CMD Pullup Level: 1938 mV 02/01/2018 12:49:33> CMD Active Level: 2248 mV 02/01/2018 12:49:33> eMMC Init returned = 0 02/01/2018 12:49:33> EMMC Device Information : 02/01/2018 12:49:33> EMMC CID: 90014A484147326505078150E0544262 02/01/2018 12:49:33> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 02/01/2018 12:49:33> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 8150E054 , rev. 0x07 02/01/2018 12:49:33> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015 02/01/2018 12:49:33> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) 02/01/2018 12:49:33> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 02/01/2018 12:49:33> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 02/01/2018 12:49:33> EMMC Permanent Write Protection: No 02/01/2018 12:49:33> EMMC Temporary Write Protection: No 02/01/2018 12:49:33> Extended CSD Information : 02/01/2018 12:49:33> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 02/01/2018 12:49:33> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 02/01/2018 12:49:33> Boot Bus Config: 0x00 , width 1bit 02/01/2018 12:49:33> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 02/01/2018 12:49:33> Supported partition features [PARTITIONING_SUPPORT]: 0x07 02/01/2018 12:49:33> Device supports partitioning features 02/01/2018 12:49:33> Device can have enhanced technological features in partitions and user data area 02/01/2018 12:49:33> Device can have extended partitions attribute 02/01/2018 12:49:33> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 02/01/2018 12:49:33> Backup saved: HAG2e_8150E054_20180102_124933.extcsd 02/01/2018 12:49:33> EMMC Init completed. 02/01/2018 12:49:33> 02/01/2018 12:49:33> Warning: Health report is very BAD 02/01/2018 12:49:33> 02/01/2018 12:49:33> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 02/01/2018 12:49:33> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 02/01/2018 12:49:33> Pre EOL information [267]: 0x03 Urgent 02/01/2018 12:49:33> 02/01/2018 12:49:33> Operation: Write Dump 02/01/2018 12:49:33> 02/01/2018 12:49:33> The size has been corrected for the file size 02/01/2018 12:49:33> 02/01/2018 12:49:33> Writing to: ROM1 , start: 0x000000000000 , size: 0x0003A3E00000 02/01/2018 12:49:33> Input file: C:\Users\chrif\Downloads\HTC_Desire_820(KTU84P_rel ease-keys-4.4.4-KTU84P)[KLMAG2WEMB-B031]\HTC_Desire_820(KTU84P_release-keys-4.4.4-KTU84P)[KLMAG2WEMB-B031]\userarea.bin 02/01/2018 12:49:33> eMMC switching to ROM1 02/01/2018 12:49:34> Writing partition... 02/01/2018 12:49:34> Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #1 02/01/2018 12:49:35> Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #2 02/01/2018 12:49:36> Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #3 02/01/2018 12:50:47> 02/01/2018 12:50:47> Stopped by User request... 02/01/2018 12:50:47> 02/01/2018 12:51:06> Looking for EasyJTAG box... 02/01/2018 12:51:06> EasyJTAG API ver. 2022 02/01/2018 12:51:06> Setting IO Levels to 2.8V 02/01/2018 12:51:06> Setting frequence to 21 Mhz 02/01/2018 12:51:06> EasyJTAG Box Serial = 0F00E00C0D23EDA9 02/01/2018 12:51:06> EasyJTAG Box Firmware = 1.62 02/01/2018 12:51:08> Setting frequence to 21 Mhz 02/01/2018 12:51:08> CMD Pullup Level: 1907 mV 02/01/2018 12:51:08> CMD Active Level: 2248 mV 02/01/2018 12:51:08> eMMC Init returned = 0 02/01/2018 12:51:08> EMMC Device Information : 02/01/2018 12:51:08> EMMC CID: 90014A484147326505078150E0544262 02/01/2018 12:51:08> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 02/01/2018 12:51:08> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 8150E054 , rev. 0x07 02/01/2018 12:51:08> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015 02/01/2018 12:51:08> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) 02/01/2018 12:51:08> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 02/01/2018 12:51:08> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 02/01/2018 12:51:08> EMMC Permanent Write Protection: No 02/01/2018 12:51:08> EMMC Temporary Write Protection: No 02/01/2018 12:51:08> Extended CSD Information : 02/01/2018 12:51:08> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 02/01/2018 12:51:08> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 02/01/2018 12:51:08> Boot Bus Config: 0x00 , width 1bit 02/01/2018 12:51:08> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 02/01/2018 12:51:08> Supported partition features [PARTITIONING_SUPPORT]: 0x07 02/01/2018 12:51:08> Device supports partitioning features 02/01/2018 12:51:08> Device can have enhanced technological features in partitions and user data area 02/01/2018 12:51:08> Device can have extended partitions attribute 02/01/2018 12:51:08> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 02/01/2018 12:51:08> Backup saved: HAG2e_8150E054_20180102_125108.extcsd 02/01/2018 12:51:08> EMMC Init completed. 02/01/2018 12:51:08> 02/01/2018 12:51:08> Warning: Health report is very BAD 02/01/2018 12:51:08> 02/01/2018 12:51:08> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 02/01/2018 12:51:08> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 02/01/2018 12:51:08> Pre EOL information [267]: 0x03 Urgent 02/01/2018 12:51:08> 02/01/2018 12:51:08> Operation: Write Dump 02/01/2018 12:51:08> 02/01/2018 12:51:08> Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 02/01/2018 12:51:08> Input file: C:\Users\chrif\Downloads\HTC_Desire_820(KTU84P_rel ease-keys-4.4.4-KTU84P)[KLMAG2WEMB-B031]\HTC_Desire_820(KTU84P_release-keys-4.4.4-KTU84P)[KLMAG2WEMB-B031]\userarea.bin 02/01/2018 12:51:08> eMMC switching to ROM1 02/01/2018 12:51:08> Writing partition... 02/01/2018 12:51:09> Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #1 02/01/2018 12:51:10> Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #2 02/01/2018 12:51:11> Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #3 02/01/2018 13:25:12> Done writing partition. Write speed: 512,98 KB/s 02/01/2018 13:25:12> 02/01/2018 13:25:12> All done time: [00:34:04:438] 02/01/2018 13:25:17> 02/01/2018 13:25:17> Looking for EasyJTAG box... 02/01/2018 13:25:17> EasyJTAG API ver. 2022 02/01/2018 13:25:17> Setting IO Levels to 2.8V 02/01/2018 13:25:17> Setting frequence to 21 Mhz 02/01/2018 13:25:17> EasyJTAG Box Serial = 0F00E00C0D23EDA9 02/01/2018 13:25:17> EasyJTAG Box Firmware = 1.62 02/01/2018 13:25:18> Setting frequence to 21 Mhz 02/01/2018 13:25:18> CMD Pullup Level: 1918 mV 02/01/2018 13:25:18> CMD Active Level: 2237 mV 02/01/2018 13:25:18> eMMC Init returned = 0 02/01/2018 13:25:18> EMMC Device Information : 02/01/2018 13:25:18> EMMC CID: 90014A484147326505078150E0544262 02/01/2018 13:25:18> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 02/01/2018 13:25:18> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 8150E054 , rev. 0x07 02/01/2018 13:25:18> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015 02/01/2018 13:25:18> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) 02/01/2018 13:25:18> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 02/01/2018 13:25:18> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 02/01/2018 13:25:18> EMMC Permanent Write Protection: No 02/01/2018 13:25:18> EMMC Temporary Write Protection: No 02/01/2018 13:25:18> Extended CSD Information : 02/01/2018 13:25:18> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 02/01/2018 13:25:18> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 02/01/2018 13:25:18> Boot Bus Config: 0x00 , width 1bit 02/01/2018 13:25:18> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 02/01/2018 13:25:18> Supported partition features [PARTITIONING_SUPPORT]: 0x07 02/01/2018 13:25:18> Device supports partitioning features 02/01/2018 13:25:18> Device can have enhanced technological features in partitions and user data area 02/01/2018 13:25:18> Device can have extended partitions attribute 02/01/2018 13:25:18> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 02/01/2018 13:25:18> Backup saved: HAG2e_8150E054_20180102_132518.extcsd 02/01/2018 13:25:18> EMMC Init completed. 02/01/2018 13:25:18> 02/01/2018 13:25:18> Warning: Health report is very BAD 02/01/2018 13:25:18> 02/01/2018 13:25:18> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 02/01/2018 13:25:18> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 02/01/2018 13:25:18> Pre EOL information [267]: 0x03 Urgent 02/01/2018 13:25:18> 02/01/2018 13:25:39> Looking for EasyJTAG box... 02/01/2018 13:25:39> EasyJTAG API ver. 2022 02/01/2018 13:25:39> Setting IO Levels to 2.8V 02/01/2018 13:25:39> Setting frequence to 21 Mhz 02/01/2018 13:25:39> EasyJTAG Box Serial = 0F00E00C0D23EDA9 02/01/2018 13:25:39> EasyJTAG Box Firmware = 1.62 02/01/2018 13:25:40> Setting frequence to 21 Mhz 02/01/2018 13:25:40> CMD Pullup Level: 1918 mV 02/01/2018 13:25:40> CMD Active Level: 2248 mV 02/01/2018 13:25:40> eMMC Init returned = 0 02/01/2018 13:25:40> EMMC Device Information : 02/01/2018 13:25:40> EMMC CID: 90014A484147326505078150E0544262 02/01/2018 13:25:40> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 02/01/2018 13:25:40> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 8150E054 , rev. 0x07 02/01/2018 13:25:40> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015 02/01/2018 13:25:40> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) 02/01/2018 13:25:40> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 02/01/2018 13:25:40> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 02/01/2018 13:25:40> EMMC Permanent Write Protection: No 02/01/2018 13:25:40> EMMC Temporary Write Protection: No 02/01/2018 13:25:40> Extended CSD Information : 02/01/2018 13:25:40> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 02/01/2018 13:25:40> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 02/01/2018 13:25:40> Boot Bus Config: 0x00 , width 1bit 02/01/2018 13:25:40> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 02/01/2018 13:25:40> Supported partition features [PARTITIONING_SUPPORT]: 0x07 02/01/2018 13:25:40> Device supports partitioning features 02/01/2018 13:25:40> Device can have enhanced technological features in partitions and user data area 02/01/2018 13:25:40> Device can have extended partitions attribute 02/01/2018 13:25:40> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 02/01/2018 13:25:40> Backup saved: HAG2e_8150E054_20180102_132540.extcsd 02/01/2018 13:25:40> EMMC Init completed. 02/01/2018 13:25:40> 02/01/2018 13:25:40> Warning: Health report is very BAD 02/01/2018 13:25:40> 02/01/2018 13:25:40> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 02/01/2018 13:25:40> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 02/01/2018 13:25:40> Pre EOL information [267]: 0x03 Urgent 02/01/2018 13:25:40> STILL DEAD NOT SOLVED |
01-05-2018, 23:49 | #11 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | HTC 820 A51 UL hang in logo-tried to flash-now boot dead-need procedure-help me “Warning: Health report is very BAD” You need to replace emmc with a new one. VTU00M is working fine with that model. Use the posted dump from post #6. If you want to write your own IMEI in the dump, open “userarea.bin” with HEX editor (010 Editor is really good) and find this offset “0004400” and there you’ll find BOARD-INFO values which contains CID and IMEI. Simply replace the IMEI with yours then write the dump. 0004400 offset is at the first 512MB, so you can just write the first 512MB and you should be fine. Sent from my iPhone using Tapatalk Last edited by MiRoOo; 01-05-2018 at 23:58. |
The Following 4 Users Say Thank You to MiRoOo For This Useful Post: |
01-14-2018, 06:56 | #13 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
help me for any good online store for emmc ic | |
