Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-10-2018, 16:37   #1 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 377
Thumbs up htc 826 dead boot repair done
8/10/2018 7:29:53 PM> EasyJTAG API ver. 2022
8/10/2018 7:29:53 PM> Setting IO Levels to 2.8V
8/10/2018 7:29:53 PM> Setting frequence to 24 Mhz
8/10/2018 7:29:53 PM> EasyJTAG Box Serial =
8/10/2018 7:29:53 PM> EasyJTAG Box Firmware = 2.21
8/10/2018 7:29:53 PM> Setting interface to EasyJtag2/ISP
8/10/2018 7:29:53 PM> Setting bus width to 1 Bit
8/10/2018 7:29:54 PM> Setting frequence to 24 Mhz
8/10/2018 7:29:54 PM> CMD Pullup Level: 155 mV
8/10/2018 7:29:54 PM> CMD Active Level: 2426 mV
8/10/2018 7:29:54 PM> eMMC Init returned = 0
8/10/2018 7:29:54 PM> EMMC Device Information :
8/10/2018 7:29:54 PM> EMMC CID: 90014A48414732650507CA306A04523F
8/10/2018 7:29:54 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3
8/10/2018 7:29:54 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: CA306A04 , rev. 0x07
8/10/2018 7:29:54 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015
8/10/2018 7:29:54 PM> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000)
8/10/2018 7:29:54 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
8/10/2018 7:29:54 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
8/10/2018 7:29:54 PM> EMMC Permanent Write Protection: No
8/10/2018 7:29:54 PM> EMMC Temporary Write Protection: No
8/10/2018 7:29:54 PM> Extended CSD Information :
8/10/2018 7:29:54 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
8/10/2018 7:29:54 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
8/10/2018 7:29:54 PM> Boot Bus Config: 0x00 , width 1bit
8/10/2018 7:29:54 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
8/10/2018 7:29:54 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
8/10/2018 7:29:54 PM> Device supports partitioning features
8/10/2018 7:29:54 PM> Device can have enhanced technological features in partitions and user data area
8/10/2018 7:29:54 PM> Device can have extended partitions attribute
8/10/2018 7:29:54 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
8/10/2018 7:29:54 PM> Backup saved: HAG2e_CA306A04_20180810_192954.extcsd
8/10/2018 7:29:54 PM> EMMC Init completed.
8/10/2018 7:29:54 PM> Warning: Health report is very BAD
8/10/2018 7:29:54 PM> Device Life Time Estimation (MLC) [269]: 0x07 60% - 70% device life time used
8/10/2018 7:29:54 PM> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used
8/10/2018 7:29:54 PM> Pre EOL information [267]: 0x01 Normal
8/10/2018 7:29:54 PM> Operation: Write by vendor (Qualcomm/HiSilicon)
8/10/2018 7:29:54 PM> Creating GPT-partitioninig
8/10/2018 7:29:54 PM> GPT-partitioning done
8/10/2018 7:29:55 PM> Partition name: board_info
8/10/2018 7:29:55 PM> Filename: board_info.bin , Offset: 000000004400 , filesize: 16384 bytes
8/10/2018 7:29:55 PM> eMMC switching to ROM1
8/10/2018 7:29:55 PM> Erasing partition...
8/10/2018 7:29:56 PM> Writing partition...
8/10/2018 7:29:56 PM> Done writing partition. Write speed: 574.75 KB/s
8/10/2018 7:29:56 PM> Partition name: pg1fs
8/10/2018 7:29:56 PM> Filename: pg1fs.bin , Offset: 000000008400 , filesize: 4194304 bytes
8/10/2018 7:29:56 PM> eMMC switching to ROM1
8/10/2018 7:29:56 PM> Erasing partition...
8/10/2018 7:29:57 PM> Writing partition...
8/10/2018 7:29:59 PM> Done writing partition. Write speed: 2563.87 KB/s
8/10/2018 7:29:59 PM> Partition name: sbl1
8/10/2018 7:29:59 PM> Filename: sbl1.bin , Offset: 000000408400 , filesize: 1048576 bytes
8/10/2018 7:29:59 PM> eMMC switching to ROM1
8/10/2018 7:29:59 PM> Erasing partition...
8/10/2018 7:30:00 PM> Writing partition...
8/10/2018 7:30:00 PM> Done writing partition. Write speed: 2451.47 KB/s
8/10/2018 7:30:00 PM> Partition name: reserve_1
8/10/2018 7:30:00 PM> Filename: reserve_1.bin , Offset: 000000508400 , filesize: 11500544 bytes
8/10/2018 7:30:00 PM> eMMC switching to ROM1
8/10/2018 7:30:00 PM> Erasing partition...
8/10/2018 7:30:01 PM> Writing partition...
8/10/2018 7:30:06 PM> Done writing partition. Write speed: 2596.93 KB/s
8/10/2018 7:30:06 PM> Partition name: mfg
8/10/2018 7:30:06 PM> Filename: mfg.bin , Offset: 000001000000 , filesize: 262144 bytes
8/10/2018 7:30:06 PM> eMMC switching to ROM1
8/10/2018 7:30:06 PM> Erasing partition...
8/10/2018 7:30:07 PM> Writing partition...
8/10/2018 7:30:07 PM> Done writing partition. Write speed: 1947.90 KB/s
8/10/2018 7:30:07 PM> Partition name: pg2fs
8/10/2018 7:30:07 PM> Filename: pg2fs.bin , Offset: 000001040000 , filesize: 24837120 bytes
8/10/2018 7:30:07 PM> eMMC switching to ROM1
8/10/2018 7:30:07 PM> Erasing partition...
8/10/2018 7:30:08 PM> Writing partition...
8/10/2018 7:30:17 PM> Done writing partition. Write speed: 2638.13 KB/s
8/10/2018 7:30:17 PM> Partition name: rpm
8/10/2018 7:30:17 PM> Filename: rpm.bin , Offset: 0000027EFC00 , filesize: 524288 bytes
8/10/2018 7:30:17 PM> eMMC switching to ROM1
8/10/2018 7:30:18 PM> Erasing partition...
8/10/2018 7:30:18 PM> Writing partition...
8/10/2018 7:30:18 PM> Done writing partition. Write speed: 2286.92 KB/s
8/10/2018 7:30:18 PM> Partition name: tz
8/10/2018 7:30:19 PM> Filename: tz.bin , Offset: 00000286FC00 , filesize: 2097152 bytes
8/10/2018 7:30:19 PM> eMMC switching to ROM1
8/10/2018 7:30:19 PM> Erasing partition...
8/10/2018 7:30:19 PM> Writing partition...
8/10/2018 7:30:20 PM> Done writing partition. Write speed: 2543.75 KB/s
8/10/2018 7:30:20 PM> Partition name: hyp
8/10/2018 7:30:20 PM> Filename: hyp.bin , Offset: 000002A6FC00 , filesize: 2097152 bytes
8/10/2018 7:30:20 PM> eMMC switching to ROM1
8/10/2018 7:30:20 PM> Erasing partition...
8/10/2018 7:30:21 PM> Writing partition...
8/10/2018 7:30:22 PM> Done writing partition. Write speed: 2516.67 KB/s
8/10/2018 7:30:22 PM> Partition name: hboot
8/10/2018 7:30:22 PM> Filename: hboot.bin , Offset: 000002C6FC00 , filesize: 4194304 bytes
8/10/2018 7:30:22 PM> eMMC switching to ROM1
8/10/2018 7:30:22 PM> Erasing partition...
8/10/2018 7:30:23 PM> Writing partition...
8/10/2018 7:30:24 PM> Done writing partition. Write speed: 2559.32 KB/s
8/10/2018 7:30:24 PM> Partition name: tool_diag
8/10/2018 7:30:24 PM> Filename: tool_diag.bin , Offset: 00000306FC00 , filesize: 4194304 bytes
8/10/2018 7:30:24 PM> eMMC switching to ROM1
8/10/2018 7:30:25 PM> Erasing partition...
8/10/2018 7:30:25 PM> Writing partition...
8/10/2018 7:30:27 PM> Done writing partition. Write speed: 2571.00 KB/s
8/10/2018 7:30:27 PM> Partition name: sp1
8/10/2018 7:30:27 PM> Filename: sp1.bin , Offset: 00000346FC00 , filesize: 5242880 bytes
8/10/2018 7:30:27 PM> eMMC switching to ROM1
8/10/2018 7:30:27 PM> Erasing partition...
8/10/2018 7:30:28 PM> Writing partition...
8/10/2018 7:30:30 PM> Done writing partition. Write speed: 2601.01 KB/s
8/10/2018 7:30:30 PM> Partition name: ddr
8/10/2018 7:30:30 PM> Filename: ddr.bin , Offset: 00000396FC00 , filesize: 32768 bytes
8/10/2018 7:30:30 PM> eMMC switching to ROM1
8/10/2018 7:30:30 PM> Erasing partition...
8/10/2018 7:30:31 PM> Writing partition...
8/10/2018 7:30:31 PM> Done writing partition. Write speed: 1179.64 KB/s
8/10/2018 7:30:31 PM> Partition name: wcnss
8/10/2018 7:30:31 PM> Filename: wcnss.bin , Offset: 000003977C00 , filesize: 5242880 bytes
8/10/2018 7:30:31 PM> eMMC switching to ROM1
8/10/2018 7:30:31 PM> Erasing partition...
8/10/2018 7:30:33 PM> Done writing partition. Write speed: 2569.63 KB/s
8/10/2018 7:30:33 PM> Partition name: rfg_0
8/10/2018 7:30:33 PM> Filename: rfg_0.bin , Offset: 000003E77C00 , filesize: 1048576 bytes
8/10/2018 7:30:33 PM> eMMC switching to ROM1
8/10/2018 7:30:34 PM> Erasing partition...
8/10/2018 7:30:34 PM> Writing partition...
8/10/2018 7:30:35 PM> Done writing partition. Write speed: 2452.14 KB/s
8/10/2018 7:30:35 PM> Partition name: rfg_1
8/10/2018 7:30:35 PM> Filename: rfg_1.bin , Offset: 000003F77C00 , filesize: 1048576 bytes
8/10/2018 7:30:35 PM> eMMC switching to ROM1
8/10/2018 7:30:35 PM> Erasing partition...
8/10/2018 7:30:35 PM> Writing partition...
8/10/2018 7:30:36 PM> Done writing partition. Write speed: 2409.96 KB/s
8/10/2018 7:30:36 PM> Partition name: rfg_2
8/10/2018 7:30:36 PM> Filename: rfg_2.bin , Offset: 000004077C00 , filesize: 1048576 bytes
8/10/2018 7:30:36 PM> eMMC switching to ROM1
8/10/2018 7:30:36 PM> Erasing partition...
8/10/2018 7:30:37 PM> Writing partition...
8/10/2018 7:30:37 PM> Done writing partition. Write speed: 2408.20 KB/s
8/10/2018 7:30:37 PM> Partition name: rfg_3
8/10/2018 7:30:37 PM> Filename: rfg_3.bin , Offset: 000004177C00 , filesize: 1048576 bytes
8/10/2018 7:30:37 PM> eMMC switching to ROM1
8/10/2018 7:30:37 PM> Erasing partition...
8/10/2018 7:30:38 PM> Writing partition...
8/10/2018 7:30:38 PM> Done writing partition. Write speed: 2376.33 KB/s
8/10/2018 7:30:38 PM> Partition name: rfg_4
8/10/2018 7:30:38 PM> Filename: rfg_4.bin , Offset: 000004277C00 , filesize: 1048576 bytes
8/10/2018 7:30:38 PM> eMMC switching to ROM1
8/10/2018 7:30:39 PM> Erasing partition...
8/10/2018 7:30:39 PM> Writing partition...
8/10/2018 7:30:40 PM> Done writing partition. Write speed: 2380.37 KB/s
8/10/2018 7:30:40 PM> Partition name: rfg_5
8/10/2018 7:30:40 PM> Filename: rfg_5.bin , Offset: 000004377C00 , filesize: 1048576 bytes
8/10/2018 7:30:40 PM> eMMC switching to ROM1
8/10/2018 7:30:40 PM> Erasing partition...
8/10/2018 7:30:41 PM> Writing partition...
8/10/2018 7:30:41 PM> Done writing partition. Write speed: 2358.05 KB/s
8/10/2018 7:30:41 PM> Partition name: rfg_6
8/10/2018 7:30:41 PM> Filename: rfg_6.bin , Offset: 000004477C00 , filesize: 1048576 bytes
8/10/2018 7:30:41 PM> eMMC switching to ROM1
8/10/2018 7:30:41 PM> Erasing partition...
8/10/2018 7:30:42 PM> Writing partition...
8/10/2018 7:30:42 PM> Done writing partition. Write speed: 2397.73 KB/s
8/10/2018 7:30:42 PM> Partition name: rfg_7
8/10/2018 7:30:42 PM> Filename: rfg_7.bin , Offset: 000004577C00 , filesize: 1048576 bytes
8/10/2018 7:30:42 PM> eMMC switching to ROM1
8/10/2018 7:30:42 PM> Erasing partition...
8/10/2018 7:30:43 PM> Writing partition...
8/10/2018 7:30:43 PM> Done writing partition. Write speed: 2393.61 KB/s
8/10/2018 7:30:43 PM> Partition name: fsg
8/10/2018 7:30:43 PM> Filename: fsg.bin , Offset: 000004677C00 , filesize: 1572864 bytes
8/10/2018 7:30:44 PM> eMMC switching to ROM1
8/10/2018 7:30:44 PM> Erasing partition...
8/10/2018 7:30:44 PM> Writing partition...
8/10/2018 7:30:45 PM> Done writing partition. Write speed: 2499.15 KB/s
8/10/2018 7:30:45 PM> Partition name: radio
8/10/2018 7:30:45 PM> Filename: radio.bin , Offset: 0000047F7C00 , filesize: 61867008 bytes
8/10/2018 7:30:45 PM> eMMC switching to ROM1
8/10/2018 7:30:45 PM> Erasing partition...
8/10/2018 7:30:48 PM> Writing partition...
8/10/2018 7:31:11 PM> Done writing partition. Write speed: 2618.10 KB/s
8/10/2018 7:31:11 PM> Partition name: reserve_2
8/10/2018 7:31:11 PM> Filename: reserve_2.bin , Offset: 0000082F8000 , filesize: 13664256 bytes
8/10/2018 7:31:11 PM> eMMC switching to ROM1
8/10/2018 7:31:11 PM> Erasing partition...
8/10/2018 7:31:12 PM> Writing partition...
8/10/2018 7:31:17 PM> Done writing partition. Write speed: 2631.87 KB/s
8/10/2018 7:31:17 PM> Partition name: misc
8/10/2018 7:31:17 PM> Filename: misc.bin , Offset: 000009000000 , filesize: 1048576 bytes
8/10/2018 7:31:17 PM> eMMC switching to ROM1
8/10/2018 7:31:17 PM> Erasing partition...
8/10/2018 7:31:18 PM> Writing partition...
8/10/2018 7:31:18 PM> Done writing partition. Write speed: 2396.40 KB/s
8/10/2018 7:31:18 PM> Partition name: modem_st1
8/10/2018 7:31:18 PM> Filename: modem_st1.bin , Offset: 000009100000 , filesize: 1572864 bytes
8/10/2018 7:31:18 PM> eMMC switching to ROM1
8/10/2018 7:31:18 PM> Erasing partition...
8/10/2018 7:31:19 PM> Writing partition...
8/10/2018 7:31:20 PM> Done writing partition. Write speed: 2443.11 KB/s
8/10/2018 7:31:20 PM> Partition name: modem_st2
8/10/2018 7:31:20 PM> Filename: modem_st2.bin , Offset: 000009280000 , filesize: 1572864 bytes
8/10/2018 7:31:20 PM> eMMC switching to ROM1
8/10/2018 7:31:20 PM> Erasing partition...
8/10/2018 7:31:20 PM> Writing partition...
8/10/2018 7:31:21 PM> Done writing partition. Write speed: 2449.76 KB/s
8/10/2018 7:31:21 PM> Partition name: fataldevlog
8/10/2018 7:31:21 PM> Filename: fataldevlog.bin , Offset: 000009400000 , filesize: 20971520 bytes
8/10/2018 7:31:21 PM> eMMC switching to ROM1
8/10/2018 7:31:21 PM> Erasing partition...
8/10/2018 7:31:22 PM> Writing partition...
8/10/2018 7:31:30 PM> Done writing partition. Write speed: 2642.01 KB/s
8/10/2018 7:31:30 PM> Partition name: devlog
8/10/2018 7:31:30 PM> Filename: devlog.bin , Offset: 00000A800000 , filesize: 31457280 bytes
8/10/2018 7:31:30 PM> eMMC switching to ROM1
8/10/2018 7:31:30 PM> Erasing partition...
8/10/2018 7:31:31 PM> Writing partition...
8/10/2018 7:31:43 PM> Done writing partition. Write speed: 2647.63 KB/s
8/10/2018 7:31:43 PM> Partition name: pdata
8/10/2018 7:31:43 PM> Filename: pdata.bin , Offset: 00000C600000 , filesize: 262144 bytes
8/10/2018 7:31:43 PM> eMMC switching to ROM1
8/10/2018 7:31:43 PM> Erasing partition...
8/10/2018 7:31:44 PM> Writing partition...
8/10/2018 7:31:44 PM> Done writing partition. Write speed: 977.82 KB/s
8/10/2018 7:31:44 PM> Partition name: control
8/10/2018 7:31:44 PM> Filename: control.bin , Offset: 00000C640000 , filesize: 16384 bytes
8/10/2018 7:31:44 PM> eMMC switching to ROM1
8/10/2018 7:31:44 PM> Erasing partition...
8/10/2018 7:31:45 PM> Writing partition...
8/10/2018 7:31:45 PM> Done writing partition. Write speed: 697.31 KB/s
8/10/2018 7:31:45 PM> Partition name: local
8/10/2018 7:31:45 PM> Filename: local.bin , Offset: 00000C644000 , filesize: 1311744 bytes
8/10/2018 7:31:45 PM> eMMC switching to ROM1
8/10/2018 7:31:45 PM> Erasing partition...
8/10/2018 7:31:46 PM> Writing partition...
8/10/2018 7:31:46 PM> Done writing partition. Write speed: 2277.07 KB/s
8/10/2018 7:31:46 PM> Partition name: extra
8/10/2018 7:31:46 PM> Filename: extra.bin , Offset: 00000C784400 , filesize: 65536 bytes
8/10/2018 7:31:46 PM> eMMC switching to ROM1
8/10/2018 7:31:47 PM> Erasing partition...
8/10/2018 7:31:47 PM> Writing partition...
8/10/2018 7:31:47 PM> Done writing partition. Write speed: 2189.05 KB/s
8/10/2018 7:31:47 PM> Partition name: cdma_record
8/10/2018 7:31:47 PM> Filename: cdma_record.bin , Offset: 00000C794400 , filesize: 1048576 bytes
8/10/2018 7:31:47 PM> eMMC switching to ROM1
8/10/2018 7:31:48 PM> Writing partition...
8/10/2018 7:31:48 PM> Done writing partition. Write speed: 2375.96 KB/s
8/10/2018 7:31:48 PM> Partition name: fsc
8/10/2018 7:31:48 PM> Filename: fsc.bin , Offset: 00000C894400 , filesize: 1024 bytes
8/10/2018 7:31:48 PM> eMMC switching to ROM1
8/10/2018 7:31:49 PM> Erasing partition...
8/10/2018 7:31:49 PM> Writing partition...
8/10/2018 7:31:49 PM> Done writing partition. Write speed: 49.20 KB/s
8/10/2018 7:31:49 PM> Partition name: ssd
8/10/2018 7:31:49 PM> Filename: ssd.bin , Offset: 00000C894800 , filesize: 8192 bytes
8/10/2018 7:31:49 PM> eMMC switching to ROM1
8/10/2018 7:31:50 PM> Writing partition...
8/10/2018 7:31:50 PM> Done writing partition. Write speed: 440.37 KB/s
8/10/2018 7:31:50 PM> Partition name: sensor_hub
8/10/2018 7:31:50 PM> Filename: sensor_hub.bin , Offset: 00000C896800 , filesize: 262144 bytes
8/10/2018 7:31:50 PM> eMMC switching to ROM1
8/10/2018 7:31:50 PM> Erasing partition...
8/10/2018 7:31:51 PM> Writing partition...
8/10/2018 7:31:51 PM> Done writing partition. Write speed: 1342.04 KB/s
8/10/2018 7:31:51 PM> Partition name: backup_hboot
8/10/2018 7:31:51 PM> Filename: backup_hboot.bin , Offset: 00000C8D6800 , filesize: 5242880 bytes
8/10/2018 7:31:51 PM> eMMC switching to ROM1
8/10/2018 7:31:51 PM> Erasing partition...
8/10/2018 7:31:52 PM> Writing partition...
8/10/2018 7:31:54 PM> Done writing partition. Write speed: 2103.32 KB/s
8/10/2018 7:31:54 PM> Partition name: reserve
8/10/2018 7:31:54 PM> Filename: reserve.bin , Offset: 00000CDD6800 , filesize: 2267136 bytes
8/10/2018 7:31:54 PM> eMMC switching to ROM1
8/10/2018 7:31:55 PM> Erasing partition...
8/10/2018 7:31:55 PM> Writing partition...
8/10/2018 7:31:56 PM> Done writing partition. Write speed: 2521.09 KB/s
8/10/2018 7:31:56 PM> Partition name: cache
8/10/2018 7:31:56 PM> Filename: cache.bin , Offset: 00000D000000 , filesize: 268435456 bytes
8/10/2018 7:31:56 PM> eMMC switching to ROM1
8/10/2018 7:31:56 PM> Erasing partition...
8/10/2018 7:32:03 PM> Writing partition...
8/10/2018 7:33:47 PM> Done writing partition. Write speed: 2532.90 KB/s
8/10/2018 7:33:47 PM> Partition name: boot
8/10/2018 7:33:47 PM> Filename: boot.bin , Offset: 00001D000000 , filesize: 33554432 bytes
8/10/2018 7:33:47 PM> eMMC switching to ROM1
8/10/2018 7:33:47 PM> Erasing partition...
8/10/2018 7:33:48 PM> Writing partition...
8/10/2018 7:34:01 PM> Done writing partition. Write speed: 2617.23 KB/s
8/10/2018 7:34:01 PM> Partition name: recovery
8/10/2018 7:34:01 PM> Filename: recovery.bin , Offset: 00001F000000 , filesize: 33554432 bytes
8/10/2018 7:34:01 PM> eMMC switching to ROM1
8/10/2018 7:34:01 PM> Erasing partition...
8/10/2018 7:34:02 PM> Writing partition...
8/10/2018 7:34:15 PM> Done writing partition. Write speed: 2636.35 KB/s
8/10/2018 7:34:15 PM> Partition name: carrier
8/10/2018 7:34:15 PM> Filename: carrier.bin , Offset: 000389000000 , filesize: 26214400 bytes
8/10/2018 7:34:15 PM> eMMC switching to ROM1
8/10/2018 7:34:15 PM> Erasing partition...
8/10/2018 7:34:16 PM> Writing partition...
8/10/2018 7:34:26 PM> Done writing partition. Write speed: 2619.25 KB/s
8/10/2018 7:34:26 PM> Partition name: battery
8/10/2018 7:34:26 PM> Filename: battery.bin , Offset: 00038A900000 , filesize: 10485760 bytes
8/10/2018 7:34:26 PM> eMMC switching to ROM1
8/10/2018 7:34:26 PM> Erasing partition...
8/10/2018 7:34:27 PM> Writing partition...
8/10/2018 7:34:30 PM> Done writing partition. Write speed: 2625.10 KB/s
8/10/2018 7:34:30 PM> Partition name: apppreload
8/10/2018 7:34:30 PM> Filename: apppreload.bin , Offset: 00038B300000 , filesize: 304087040 bytes
8/10/2018 7:34:30 PM> eMMC switching to ROM1
8/10/2018 7:34:31 PM> Erasing partition...
8/10/2018 7:34:37 PM> Writing partition...
8/10/2018 7:36:30 PM> Done writing partition. Write speed: 2638.37 KB/s
8/10/2018 7:36:30 PM> Partition name: cota
8/10/2018 7:36:30 PM> Filename: cota.bin , Offset: 00039D500000 , filesize: 62914560 bytes
8/10/2018 7:36:30 PM> eMMC switching to ROM1
8/10/2018 7:36:30 PM> Erasing partition...
8/10/2018 7:36:35 PM> Writing partition...
8/10/2018 7:36:59 PM> Done writing partition. Write speed: 2638.34 KB/s
8/10/2018 7:36:59 PM> Check BOOT_PARTITION_EN for the selected vendor
8/10/2018 7:36:59 PM> All done time: [00:07:03:821]
8/10/2018 7:37:02 PM> Looking for EasyJTAG box...
8/10/2018 7:37:03 PM> EasyJTAG API ver. 2022
8/10/2018 7:37:03 PM> Setting IO Levels to 2.8V
8/10/2018 7:37:03 PM> Setting frequence to 24 Mhz
8/10/2018 7:37:03 PM> EasyJTAG Box Serial =
8/10/2018 7:37:03 PM> EasyJTAG Box Firmware = 2.21
8/10/2018 7:37:03 PM> Setting interface to EasyJtag2/ISP
8/10/2018 7:37:03 PM> Setting bus width to 1 Bit
8/10/2018 7:37:03 PM> CMD Pullup Level: 152 mV
8/10/2018 7:37:03 PM> CMD Active Level: 2427 mV
8/10/2018 7:37:03 PM> eMMC Init returned = 0
8/10/2018 7:37:03 PM> EMMC Device Information :
8/10/2018 7:37:03 PM> EMMC CID: 90014A48414732650507CA306A04523F
8/10/2018 7:37:03 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3
8/10/2018 7:37:03 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: CA306A04 , rev. 0x07
8/10/2018 7:37:03 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015
8/10/2018 7:37:03 PM> EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000)
8/10/2018 7:37:03 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
8/10/2018 7:37:03 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
8/10/2018 7:37:03 PM> EMMC Permanent Write Protection: No
8/10/2018 7:37:03 PM> EMMC Temporary Write Protection: No
8/10/2018 7:37:03 PM> Extended CSD Information :
8/10/2018 7:37:03 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
8/10/2018 7:37:03 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
8/10/2018 7:37:03 PM> Boot Bus Config: 0x00 , width 1bit
8/10/2018 7:37:03 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
8/10/2018 7:37:03 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
8/10/2018 7:37:03 PM> Device supports partitioning features
8/10/2018 7:37:03 PM> Device can have enhanced technological features in partitions and user data area
8/10/2018 7:37:03 PM> Device can have extended partitions attribute
8/10/2018 7:37:03 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
8/10/2018 7:37:03 PM> Backup saved: HAG2e_CA306A04_20180810_193703.extcsd
8/10/2018 7:37:03 PM> EMMC Init completed.
8/10/2018 7:37:04 PM> Warning: Health report is very BAD
8/10/2018 7:37:04 PM> Device Life Time Estimation (MLC) [269]: 0x07 60% - 70% device life time used
8/10/2018 7:37:04 PM> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used
8/10/2018 7:37:04 PM> Pre EOL information [267]: 0x01 Normal
8/10/2018 7:37:04 PM> Scanning soft partitions
8/10/2018 7:37:04 PM> GPT header is found and is valid
8/10/2018 7:37:04 PM> Partition: board_info, [000000004400 - 000000008400], size: 000000004000
8/10/2018 7:37:04 PM> Partition: pg1fs, [000000008400 - 000000408400], size: 000000400000
8/10/2018 7:37:04 PM> Partition: sbl1, [000000408400 - 000000508400], size: 000000100000
8/10/2018 7:37:04 PM> Partition: reserve_1, [000000508400 - 000001000000], size: 000000AF7C00
8/10/2018 7:37:04 PM> Partition: mfg, [000001000000 - 000001040000], size: 000000040000
8/10/2018 7:37:04 PM> Partition: pg2fs, [000001040000 - 0000027EFC00], size: 0000017AFC00
8/10/2018 7:37:04 PM> Partition: rpm, [0000027EFC00 - 00000286FC00], size: 000000080000
8/10/2018 7:37:04 PM> Partition: tz, [00000286FC00 - 000002A6FC00], size: 000000200000
8/10/2018 7:37:04 PM> Partition: hyp, [000002A6FC00 - 000002C6FC00], size: 000000200000
8/10/2018 7:37:04 PM> Partition: hboot, [000002C6FC00 - 00000306FC00], size: 000000400000
8/10/2018 7:37:04 PM> Partition: tool_diag, [00000306FC00 - 00000346FC00], size: 000000400000
8/10/2018 7:37:04 PM> Partition: sp1, [00000346FC00 - 00000396FC00], size: 000000500000
8/10/2018 7:37:04 PM> Partition: ddr, [00000396FC00 - 000003977C00], size: 000000008000
8/10/2018 7:37:04 PM> Partition: wcnss, [000003977C00 - 000003E77C00], size: 000000500000
8/10/2018 7:37:04 PM> Partition: rfg_0, [000003E77C00 - 000003F77C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: rfg_1, [000003F77C00 - 000004077C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: rfg_2, [000004077C00 - 000004177C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: rfg_3, [000004177C00 - 000004277C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: rfg_4, [000004277C00 - 000004377C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: rfg_5, [000004377C00 - 000004477C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: rfg_6, [000004477C00 - 000004577C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: rfg_7, [000004577C00 - 000004677C00], size: 000000100000
8/10/2018 7:37:04 PM> Partition: fsg, [000004677C00 - 0000047F7C00], size: 000000180000
8/10/2018 7:37:04 PM> Partition: radio, [0000047F7C00 - 0000082F8000], size: 000003B00400
8/10/2018 7:37:04 PM> Partition: reserve_2, [0000082F8000 - 000009000000], size: 000000D08000
8/10/2018 7:37:04 PM> Partition: misc, [000009000000 - 000009100000], size: 000000100000
8/10/2018 7:37:04 PM> Partition: modem_st1, [000009100000 - 000009280000], size: 000000180000
8/10/2018 7:37:04 PM> Partition: modem_st2, [000009280000 - 000009400000], size: 000000180000
8/10/2018 7:37:04 PM> Partition: fataldevlog, [000009400000 - 00000A800000], size: 000001400000
8/10/2018 7:37:04 PM> Partition: devlog, [00000A800000 - 00000C600000], size: 000001E00000
8/10/2018 7:37:04 PM> Partition: pdata, [00000C600000 - 00000C640000], size: 000000040000
8/10/2018 7:37:04 PM> Partition: control, [00000C640000 - 00000C644000], size: 000000004000
8/10/2018 7:37:04 PM> Partition: local, [00000C644000 - 00000C784400], size: 000000140400
8/10/2018 7:37:04 PM> Partition: extra, [00000C784400 - 00000C794400], size: 000000010000
8/10/2018 7:37:04 PM> Partition: cdma_record, [00000C794400 - 00000C894400], size: 000000100000
8/10/2018 7:37:04 PM> Partition: fsc, [00000C894400 - 00000C894800], size: 000000000400
8/10/2018 7:37:04 PM> Partition: ssd, [00000C894800 - 00000C896800], size: 000000002000
8/10/2018 7:37:04 PM> Partition: sensor_hub, [00000C896800 - 00000C8D6800], size: 000000040000
8/10/2018 7:37:04 PM> Partition: backup_hboot, [00000C8D6800 - 00000CDD6800], size: 000000500000
8/10/2018 7:37:04 PM> Partition: reserve, [00000CDD6800 - 00000D000000], size: 000000229800
8/10/2018 7:37:04 PM> Partition: cache, [00000D000000 - 00001D000000], size: 000010000000
8/10/2018 7:37:04 PM> Partition: boot, [00001D000000 - 00001F000000], size: 000002000000
8/10/2018 7:37:04 PM> Partition: recovery, [00001F000000 - 000021000000], size: 000002000000
8/10/2018 7:37:05 PM> Partition: system, [000021000000 - 000121000000], size: 000100000000
8/10/2018 7:37:05 PM> Partition: userdata, [000121000000 - 000389000000], size: 000268000000
8/10/2018 7:37:05 PM> Partition: carrier, [000389000000 - 00038A900000], size: 000001900000
8/10/2018 7:37:05 PM> Partition: battery, [00038A900000 - 00038B300000], size: 000000A00000
8/10/2018 7:37:05 PM> Partition: apppreload, [00038B300000 - 00039D500000], size: 000012200000
8/10/2018 7:37:05 PM> Partition: cota, [00039D500000 - 0003AB7FBE00], size: 00000E2FBE00
8/10/2018 7:37:05 PM> GPT header successfully parsed
8/10/2018 7:37:05 PM> Get firmware version
8/10/2018 7:37:06 PM> Firmware info not found
The Following 3 Users Say Thank You to royalnasim For This Useful Post:
Old 08-18-2018, 21:58   #2 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 377
Thumbs up Emmc dump file read by vender
HERE IS FILE READ BY VENDER TESTED FILE
https://drive.google.com/open?id=1Bg...TlWfH1DVge-VKG
The Following User Says Thank You to royalnasim For This Useful Post:
Old 08-20-2018, 09:00   #3 (permalink)
Member: 579725
Sonork: 100.1675677
Thanks Meter: 60
You need permission
Your request for access has been sent.
You will receive an email if and when your request is approved.
Find out more about this topic at the Google Help Centre
Page generated in 0.31926 seconds with 7 queries
