09-26-2019, 17:22 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | htc d816h dead log Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 90014A4838473165050401A8CCB47131 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G1e , HEX: 483847316500 , S/N: 01A8CCB4 , rev. 0x04 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2014 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G1e_01A8CCB4_20190926_212313.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version Firmware info not found |
09-26-2019, 19:09 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | what help you need? how select dumps (firmware) files and write it to eMMC? it easy - download it from support, select firmware or dumps and press "Write" |
09-27-2019, 07:27 | #4 (permalink) |
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | also i am not sure about model which model have seems phone dead qcomm mode only how identify the model 816 simple 816d 816t 816w ?? i have download dump from site name file HTC_816_A5_DUG_6.0.1 emmc dump but after write this error Found 4 serial devices COM1 ACPI\PNP0501 Nuvoton Communications Port (COM1) COM2 ACPI\PNP0501 Nuvoton Communications Port (COM2) COM3 Intel(R) Active Management Technology - SOL (COM3) COM610 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM610) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 996mV pin connected ok command: 1002mV pin connected ok data0: 1004mV pin connected ok data1: 1003mV pin connected ok data2: 1004mV pin connected ok data3: 1004mV pin connected ok data4: 1007mV pin connected ok data5: 1005mV pin connected ok data6: 1003mV pin connected ok data7: 1005mV pin connected ok Box S/N: 58BCB58DC8D445E9, ,FW Ver.: 02.48 Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A4838473165050401A8CCB47131 eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 07/2014 Rev.0x4 eMMC NAME: H8G1e , S/N: 27839668 eMMC NAME (HEX): 483847316520 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: H8G1e_ 27839668_20190927_1124.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E87FDD sectors 7.3 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,15237119 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0029000000 (2.500GB) --------------------------------------------- Detected USERDATA USERDATA : 0x00C9000000 (4.125GB) Unable to mount USERDATA , code : 95 Done. ?? |
09-27-2019, 22:24 | #5 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | 1) you can write athoter dump to power on mobile and try to write original firmware over it 2) it not a error - it a warning Last edited by layder; 09-28-2019 at 10:19. |
