12-23-2017, 12:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: meerut
Member: 804463 Status: Offline Thanks Meter: 77 | htc d826x ---------- eMMC Device Information ---------- EMMC CID : 90014A484147326505079796A18342FA EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 04/2015 Rev.0x7 EMMC NAME: HAG2e , S/N: 2543231363 EMMC NAME (HEX): 48414732652000 EMMC ROM1 (Main User Data) Capacity: 15032 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HAG2e _2543231363_20171223_1649.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5C000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D087DD sectors 14.5 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30443519 Found Data areas (firmware parts) count is: 49 Partition info successfully found --------------------------------------------- P0 (BOARD_INFO) [0x4400 0x4000] Size: 16.0KB P1 (PG1FS) [0x8400 0x400000] Size: 4.0MB P2 (SBL1) [0x408400 0x100000] Size: 1.0MB P3 (RESERVE_1) [0x508400 0xaf7c00] Size: 10.967MB P4 (MFG) [0x1000000 0x40000] Size: 256.0KB P5 (PG2FS) [0x1040000 0x17afc00] Size: 23.686MB P6 (RPM) [0x27efc00 0x80000] Size: 512.0KB P7 (TZ) [0x286fc00 0x200000] Size: 2.0MB P8 (HYP) [0x2a6fc00 0x200000] Size: 2.0MB P9 (HBOOT) [0x2c6fc00 0x400000] Size: 4.0MB P10 (TOOL_DIAG) [0x306fc00 0x400000] Size: 4.0MB P11 (SP1) [0x346fc00 0x500000] Size: 5.0MB P12 (DDR) [0x396fc00 0x8000] Size: 32.0KB P13 (WCNSS) [0x3977c00 0x500000] Size: 5.0MB P14 (RFG_0) [0x3e77c00 0x100000] Size: 1.0MB P15 (RFG_1) [0x3f77c00 0x100000] Size: 1.0MB P16 (RFG_2) [0x4077c00 0x100000] Size: 1.0MB P17 (RFG_3) [0x4177c00 0x100000] Size: 1.0MB P18 (RFG_4) [0x4277c00 0x100000] Size: 1.0MB P19 (RFG_5) [0x4377c00 0x100000] Size: 1.0MB P20 (RFG_6) [0x4477c00 0x100000] Size: 1.0MB P21 (RFG_7) [0x4577c00 0x100000] Size: 1.0MB P22 (FSG) [0x4677c00 0x180000] Size: 1.500MB P23 (RADIO) [0x47f7c00 0x3b00400] Size: 59.0MB P24 (RESERVE_2) [0x82f8000 0xd08000] Size: 13.31MB P25 (MISC) [0x9000000 0x100000] Size: 1.0MB P26 (MODEM_ST1) [0x9100000 0x180000] Size: 1.500MB P27 (MODEM_ST2) [0x9280000 0x180000] Size: 1.500MB P28 (FATALDEVLOG) [0x9400000 0x1400000] Size: 20.0MB P29 (DEVLOG) [0xa800000 0x1e00000] Size: 30.0MB P30 (PDATA) [0xc600000 0x40000] Size: 256.0KB P31 (CONTROL) [0xc640000 0x4000] Size: 16.0KB P32 (LOCAL) [0xc644000 0x140400] Size: 1.250MB P33 (EXTRA) [0xc784400 0x10000] Size: 64.0KB P34 (CDMA_RECORD) [0xc794400 0x100000] Size: 1.0MB P35 (FSC) [0xc894400 0x400] Size: 1.0KB P36 (SSD) [0xc894800 0x2000] Size: 8.0KB P37 (SENSOR_HUB) [0xc896800 0x40000] Size: 256.0KB P38 (BACKUP_HBOOT) [0xc8d6800 0x500000] Size: 5.0MB P39 (RESERVE) [0xcdd6800 0x229800] Size: 2.162MB P40 (CACHE) [0xd000000 0x10000000] Size: 256.0MB P41 (BOOT) [0x1d000000 0x2000000] Size: 32.0MB P42 (RECOVERY) [0x1f000000 0x2000000] Size: 32.0MB P43 (SYSTEM) [0x21000000 0x100000000] Size: 4.0GB P44 (USERDATA) [0x121000000 0x268000000] Size: 9.625GB P45 (CARRIER) [0x389000000 0x1900000] Size: 25.0MB P46 (BATTERY) [0x38a900000 0xa00000] Size: 10.0MB P47 (APPPRELOAD) [0x38b300000 0x12200000] Size: 290.0MB P48 (COTA) [0x39d500000 0x3c00000] Size: 60.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0021000000 (4.0GB) Unable to read prop.plist , code 2 --------------------------------------------- Done. |
