04-14-2019, 04:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | EMMC Permanent Write Protection?????help me!!! EMMC Permanent Write Protection: Yes Z3X EasyJtag Software ver. 3.5.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1705mV pin connected ok command: 1711mV pin connected ok data0: 1713mV pin connected ok data1: 1706mV pin connected ok data2: 1711mV pin connected ok data3: 1711mV pin connected ok data4: 1712mV pin connected ok data5: 1708mV pin connected ok data6: 1711mV pin connected ok data7: 1710mV pin connected ok Box S/N: xxxxxxxxxxxx, ,FW Ver.: 02.38 Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:8bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100524331344D4207D6D7CC0A53D1 eMMC CSD : D02701320F5903FFF6DBFFEF8E406069 eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2016 Rev.0x7 eMMC NAME: RC14MB , S/N: 3604466698 eMMC NAME (HEX): 524331344D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 93 times EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RC14MB_3604466698_20190414_1107.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 First usable sector: 34 Last usable sector: 122142686 Partition info successfully found Found Data areas (firmware parts) count is: 33 --------------------------------------------- P0 (RECOVERY) [0x8000 0x1000000] Size: 16.0MB P1 (PARA) [0x1008000 0x80000] Size: 512.0KB P2 (RESERVE1) [0x1088000 0x200000] Size: 2.0MB P3 (RESERVE2) [0x1288000 0x1000000] Size: 16.0MB P4 (RESERVE3) [0x2288000 0x200000] Size: 2.0MB P5 (RESERVE4) [0x2488000 0x1000000] Size: 16.0MB P6 (OPPO_CUSTOM) [0x3488000 0x100000] Size: 1.0MB P7 (EXPDB) [0x3588000 0xa00000] Size: 10.0MB P8 (FRP) [0x3f88000 0x100000] Size: 1.0MB P9 (NVDATA) [0x4088000 0x2000000] Size: 32.0MB P10 (METADATA) [0x6088000 0x2000000] Size: 32.0MB P11 (PROTECT1) [0x8088000 0x800000] Size: 8.0MB P12 (PROTECT2) [0x8888000 0xf78000] Size: 15.468MB P13 (SECCFG) [0x9800000 0x800000] Size: 8.0MB P14 (OEMKEYSTORE) [0xa000000 0x800000] Size: 8.0MB P15 (PROINFO) [0xa800000 0x300000] Size: 3.0MB P16 (MD1IMG) [0xab00000 0x1800000] Size: 24.0MB P17 (MD1DSP) [0xc300000 0x400000] Size: 4.0MB P18 (MD1ARM7) [0xc700000 0x300000] Size: 3.0MB P19 (MD3IMG) [0xca00000 0x500000] Size: 5.0MB P20 (NVRAM) [0xcf00000 0x500000] Size: 5.0MB P21 (LK) [0xd400000 0x100000] Size: 1.0MB P22 (LK2) [0xd500000 0x100000] Size: 1.0MB P23 (BOOT) [0xd600000 0x1000000] Size: 16.0MB P24 (LOGO) [0xe600000 0x800000] Size: 8.0MB P25 (TEE1) [0xee00000 0x500000] Size: 5.0MB P26 (TEE2) [0xf300000 0x500000] Size: 5.0MB P27 (SECRO) [0xf800000 0x600000] Size: 6.0MB P28 (KEYSTORE) [0xfe00000 0xa00000] Size: 10.0MB P29 (SYSTEM) [0x10800000 0x80000000] Size: 2.0GB P30 (CACHE) [0x90800000 0x7000000] Size: 112.0MB P31 (USERDATA) [0x97800000 0xdf6ffbe00] Size: 55.858GB P32 (FLASHINFO) [0xe8e7fbe00 0x1000000] Size: 16.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0010800000 (2.0GB) Device Model: OPPO R9t Device Name: R9t Product ID: oppo6755_15111 Display Build ID: R9t_11_A.01_160227 Build ID: LMY47I Release Incremental ID: 1468897487 Release Base ID: 5.1 Architecture ABI: arm64-v8a Device manufacturer: OPPO Device Platform: mt6755 Build Description: full_oppo6755_15111-user 5.1 LMY47I 1468897487 dev-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0097800000 (55.858GB) Gesture HASH :2169DE4FE65BC246780D726AE1C25C5BFC515A5D Done. Selected eMMC Interface |
