Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 01-14-2017, 14:17   #1 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 553
htc m8 after writting 1gb rom same phone qcom mode
EMMC CID : 90014A484147346404050C854347517C
EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 05/2014 Rev.0x5
EMMC NAME: HAG4d , S/N: 210060103
EMMC NAME (HEX): 48414734642000
EMMC ROM1 (Main User Data) Capacity: 15032 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HAG4d _ 210060103_20170114_1754.extcsd
Done.
Checking NAND Image : G:\Devices\Z3x\Easy Jtag\m8\HTC-M8_ROM1_00000000_40000000.bin
File successefuly loaded!
Processing file...G:\Devices\Z3x\Easy Jtag\m8\HTC-M8_ROM1_00000000_40000000.bin
Z3X EasyJtag Software ver. 2.5.0.4
Skip loading eMMC Addon Firmware
CMD Pullup Level:2691 mV
CMD Active Level:2753 mV
Input file : G:\Devices\Z3x\Easy Jtag\m8\HTC-M8_ROM1_00000000_40000000.bin
Writing 0040000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 1103 kB/s
Old 03-16-2017, 18:46   #2 (permalink)
Member: 310822
Sonork: ALIAS: POLITEHNICA_1921
Thanks Meter: 9
Thumbs up same here
phone history
phone was phone is american 0pb70000 wanted to change to 0pb10000
found out later that that is not possible
too late for normal flashing recovery
because now at getvar i got MID 0pb10000 and can't change by fastboot
phone state before jtag emmc - only fastboot
phone state after jtag emmc - dead only qualcomm hs-usb
here is log
Z3X EasyJtag Software ver. 2.5.0.8
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 161610055F56B5ED, ,FW Ver.: 01.58
CMD Pullup Level:1732 mV
CMD Active Level:2340 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is off!
---------- eMMC Device Information ----------
EMMC CID : 90014A4842473465050101E63FE75132
EMMC Date: 05/2014 Rev.0x1
EMMC NAME: HBG4e , S/N: 31866855
EMMC NAME (HEX): 48424734652000
EMMC ROM1 (Main User Data) Capacity: 29824 MB
Backup saved: HBG4e _ 31866855_20170316_1735.extcsd
Done.
Input file : D:\z3x\jtag\HTC-M8_ROM1_1Gb\HTC-M8_ROM1_00000000_40000000.bin
Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM)
Done. Write Speed: 1296 kB/s
maybe rom1 file is bad
can you guys provide full dump ?
rom 2 , 3 ?
or what is the solution
thanks in advance
Old 03-16-2017, 19:00   #3 (permalink)
ProcyOne's Avatar
Member: 523318
Thanks Meter: 246
Mtc m8_ul 0p6b100
The Following User Says Thank You to ProcyOne For This Useful Post:
Old 03-20-2017, 17:29   #4 (permalink)
Member: 310822
Thanks Meter: 9
Originally Posted by ProcyOne View Post
this file doesn't work for me.
my phone is 0p6b700000
with your file when i try to load it i get
Caution: invalid backup GPT header, but valid main header!
Loading Partitions List...
Setting Metadata 0 length are 22
Checking EFI Table CRC fields.
Warning! Main and backup partition tables differ! Use the 'c' and 'e' options
on the recovery & transformation menu to examine the two tables.
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
can anyone else help ?
guys from support ?
are you in holiday or something ?
Old 11-09-2017, 15:25   #5 (permalink)
Member: 693376
Thanks Meter: 4
Have you solved? i ALSO NEED dump HTC M8s 0P6B70000
1giga file from support is not working
Page generated in 0.27450 seconds with 7 queries
