10-19-2017, 08:38 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | HTC M8 emmc repair done ( HTC_M8_UL_0P6B100 ) log:- Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.60 CMD Pullup Level:1784 mV CMD Active Level:2413 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A4841473464040508293582216A EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2014 Rev.0x5 EMMC NAME: HAG4d , S/N: 136918402 EMMC NAME (HEX): 48414734642000 EMMC ROM1 (Main User Data) Capacity: 15032 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HAG4d _ 136918402_20171018_1558.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5C000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1CFFFDD sectors 14.5 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30408703 Found Data areas (firmware parts) count is: 47 Partition info successfully found --------------------------------------------- P0 (SBL1) [0x4400 0x100000] Size: 1.0MB P1 (PG1FS) [0x104400 0x76f7c00] Size: 118.967MB P2 (BOARD_INFO) [0x77fc000 0x4000] Size: 16.0KB P3 (RESERVE_1) [0x7800000 0x800000] Size: 8.0MB P4 (MFG) [0x8000000 0x40000] Size: 256.0KB P5 (PG2FS) [0x8040000 0x17afc00] Size: 23.686MB P6 (SBL1_UPDATE) [0x97efc00 0x40000] Size: 256.0KB P7 (RPM) [0x982fc00 0x40000] Size: 256.0KB P8 (TZ) [0x986fc00 0x200000] Size: 2.0MB P9 (SDI) [0x9a6fc00 0x8000] Size: 32.0KB P10 (HBOOT) [0x9a77c00 0x400000] Size: 4.0MB P11 (SP1) [0x9e77c00 0x500000] Size: 5.0MB P12 (WIFI) [0xa377c00 0x100000] Size: 1.0MB P13 (DDR) [0xa477c00 0x8000] Size: 32.0KB P14 (DSPS) [0xa47fc00 0x100000] Size: 1.0MB P15 (ADSP) [0xa57fc00 0x3c00400] Size: 60.0MB P16 (WCNSS) [0xe180000 0x500000] Size: 5.0MB P17 (RADIO_CONFIG) [0xe680000 0x800000] Size: 8.0MB P18 (FSG) [0xee80000 0x180000] Size: 1.500MB P19 (RADIO) [0xf000000 0x4b00400] Size: 75.0MB P20 (TOOL_DIAG) [0x13b00400 0x400000] Size: 4.0MB P21 (CUSTDATA) [0x13f00400 0x3200000] Size: 50.0MB P22 (RESERVE_2) [0x17100400 0xeffc00] Size: 14.999MB P23 (MISC) [0x18000000 0x100000] Size: 1.0MB P24 (MODEM_ST1) [0x18100000 0x180000] Size: 1.500MB P25 (MODEM_ST2) [0x18280000 0x180000] Size: 1.500MB P26 (FATALDEVLOG) [0x18400000 0x1400000] Size: 20.0MB P27 (DEBUG_CONFIG) [0x19800000 0x1000] Size: 4.0KB P28 (PDATA) [0x19801000 0x40000] Size: 256.0KB P29 (CONTROL) [0x19841000 0x4000] Size: 16.0KB P30 (LOCAL) [0x19845000 0x140400] Size: 1.250MB P31 (EXTRA) [0x19985400 0x10000] Size: 64.0KB P32 (CDMA_RECORD) [0x19995400 0x100000] Size: 1.0MB P33 (FSC) [0x19a95400 0x400] Size: 1.0KB P34 (SSD) [0x19a95800 0x2000] Size: 8.0KB P35 (SKYLINK) [0x19a97800 0x40000] Size: 256.0KB P36 (CARRIER) [0x19ad7800 0x1900000] Size: 25.0MB P37 (SENSOR_HUB) [0x1b3d7800 0x40000] Size: 256.0KB P38 (DEVLOG) [0x1b417800 0x1e00000] Size: 30.0MB P39 (CIR_IMG) [0x1d217800 0x2800] Size: 10.0KB P40 (RESERVE) [0x1d21a000 0x2de6000] Size: 45.898MB P41 (BOOT) [0x20000000 0x1000000] Size: 16.0MB P42 (RECOVERY) [0x21000000 0x1800000] Size: 24.0MB P43 (RESERVE_3) [0x22800000 0x5800000] Size: 88.0MB P44 (SYSTEM) [0x28000000 0xa8000000] Size: 2.625GB P45 (CACHE) [0xd0000000 0x18000000] Size: 384.0MB P46 (USERDATA) [0xe8000000 0x2b8000000] Size: 10.875GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0028000000 (2.625GB) Device Model: HTC One_M8 Build ID: LRX22C Display Build ID: LRX22C release-keys Release ID: 5.0.1 Device Name: htc_europe Architecture ABI: armeabi-v7a Device manufacturer: HTC Device Platform: msm8974 Product ID: htc_m8 Build Description: 4.16.401.13 CL448934 release-keys Build Description: 4.16.401.13 CL448934 release-keys Build Description: 4.16.401.13 CL448934 release-keys --------------------------------------------- Done. |
The Following 3 Users Say Thank You to ALI_MAFIA For This Useful Post: |
