02-19-2018, 09:49 | #1 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1079917 Status: Offline Sonork: 100.1663316 Thanks Meter: 49 | Asus T00P invalid Boot image Repair Done eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = 1029261B332297B3 Card Serial = AA0C-E794 EasyJTAG Box Firmware = 2.21 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2049 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_124731.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000005000 - 000008005000], size: 000008000000 Partition: panic, [000008005000 - 000008805000], size: 000000800000 Partition: factory, [000008805000 - 00000A805000], size: 000002000000 Partition: spare, [00000A805000 - 00000B005000], size: 000000800000 Partition: config, [00000B005000 - 00000D005000], size: 000002000000 Partition: cache, [00000D005000 - 00002D005000], size: 000020000000 Partition: APD, [00002D005000 - 000039005000], size: 00000C000000 Partition: ADF, [000039005000 - 00003B005000], size: 000002000000 Partition: system, [00003B005000 - 00008C405000], size: 000051400000 Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000 GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_124827.extcsd EMMC Init completed. Operation: Write Dump Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Input file: D:\Easy Jtag\Dump\Asus- T00P\Zenfone 5 By repair Az\EMMC_H8G2d_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 808.96 KB/s All done time: [00:00:05:383] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2053 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_124901.extcsd EMMC Init completed. Operation: Write Dump The size has been corrected for the file size Writing to: GP1 , start: 0x000000000000 , size: 0x000000800000 Input file: D:\Easy Jtag\Dump\Asus- T00P\Zenfone 5 By repair Az\EMMC_H8G2d_GP1_000000000000_000000800000.bin eMMC switching to GP1 Writing partition... Done writing partition. Write speed: 757.88 KB/s All done time: [00:00:11:078] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2049 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_124943.extcsd EMMC Init completed. Operation: Write Dump Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000 Input file: D:\Easy Jtag\Dump\Asus- T00P\Zenfone 5 By repair Az\EMMC_H8G2d_ROM1_000000000000_000020000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 2007.16 KB/s All done time: [00:04:22:082] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2049 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125414.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000005000 - 000008005000], size: 000008000000 Partition: panic, [000008005000 - 000008805000], size: 000000800000 Partition: factory, [000008805000 - 00000A805000], size: 000002000000 Partition: spare, [00000A805000 - 00000B005000], size: 000000800000 Partition: config, [00000B005000 - 00000D005000], size: 000002000000 Partition: cache, [00000D005000 - 00002D005000], size: 000020000000 Partition: APD, [00002D005000 - 000039005000], size: 00000C000000 Partition: ADF, [000039005000 - 00003B005000], size: 000002000000 Partition: system, [00003B005000 - 00008C405000], size: 000051400000 Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000 GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 108 mV CMD Active Level: 2397 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2048 mV CMD Active Level: 2471 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125844.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000005000 - 000008005000], size: 000008000000 Partition: panic, [000008005000 - 000008805000], size: 000000800000 Partition: factory, [000008805000 - 00000A805000], size: 000002000000 Partition: spare, [00000A805000 - 00000B005000], size: 000000800000 Partition: config, [00000B005000 - 00000D005000], size: 000002000000 Partition: cache, [00000D005000 - 00002D005000], size: 000020000000 Partition: APD, [00002D005000 - 000039005000], size: 00000C000000 Partition: ADF, [000039005000 - 00003B005000], size: 000002000000 Partition: system, [00003B005000 - 00008C405000], size: 000051400000 Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000 GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125854.extcsd EMMC Init completed. This operation is only performed for the Samsung eMMC Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125911.extcsd EMMC Init completed. This operation is only performed for the Samsung eMMC Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2471 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125919.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Error: CARD Lock/Unlock Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2052 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125927.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000005000 - 000008005000], size: 000008000000 Partition: panic, [000008005000 - 000008805000], size: 000000800000 Partition: factory, [000008805000 - 00000A805000], size: 000002000000 Partition: spare, [00000A805000 - 00000B005000], size: 000000800000 Partition: config, [00000B005000 - 00000D005000], size: 000002000000 Partition: cache, [00000D005000 - 00002D005000], size: 000020000000 Partition: APD, [00002D005000 - 000039005000], size: 00000C000000 Partition: ADF, [000039005000 - 00003B005000], size: 000002000000 Partition: system, [00003B005000 - 00008C405000], size: 000051400000 Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000 GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2052 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125932.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Error: CARD Lock/Unlock Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125948.extcsd EMMC Init completed. Operation: Changing GP sizes (final write) ... GP1 size: 8 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 HW_PART error. Reason: Card already partitioned Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_125958.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000005000 - 000008005000], size: 000008000000 Partition: panic, [000008005000 - 000008805000], size: 000000800000 Partition: factory, [000008805000 - 00000A805000], size: 000002000000 Partition: spare, [00000A805000 - 00000B005000], size: 000000800000 Partition: config, [00000B005000 - 00000D005000], size: 000002000000 Partition: cache, [00000D005000 - 00002D005000], size: 000020000000 Partition: APD, [00002D005000 - 000039005000], size: 00000C000000 Partition: ADF, [000039005000 - 00003B005000], size: 000002000000 Partition: system, [00003B005000 - 00008C405000], size: 000051400000 Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000 GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_130012.extcsd EMMC Init completed. Operation: Changing GP sizes (final write) ... GP1 size: 40 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 HW_PART error. Reason: Card already partitioned Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2048 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_130022.extcsd EMMC Init completed. Operation: Changing GP sizes (final write) ... GP1 size: 8 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 HW_PART error. Reason: Card already partitioned Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2052 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_130028.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000005000 - 000008005000], size: 000008000000 Partition: panic, [000008005000 - 000008805000], size: 000000800000 Partition: factory, [000008805000 - 00000A805000], size: 000002000000 Partition: spare, [00000A805000 - 00000B005000], size: 000000800000 Partition: config, [00000B005000 - 00000D005000], size: 000002000000 Partition: cache, [00000D005000 - 00002D005000], size: 000020000000 Partition: APD, [00002D005000 - 000039005000], size: 00000C000000 Partition: ADF, [000039005000 - 00003B005000], size: 000002000000 Partition: system, [00003B005000 - 00008C405000], size: 000051400000 Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000 GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2053 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_130102.extcsd EMMC Init completed. This operation is only performed for the Samsung eMMC Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2052 mV CMD Active Level: 2471 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_130114.extcsd EMMC Init completed. Filename: H8G2d_02A67B81_20170529_144502.extcsd Writing BootConfig ... Reg: 179 Value: 0x00 Reg: 177 Value: 0x06 Reg: 162 Value: 0x01 Done All done Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2473 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_130138.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000005000 - 000008005000], size: 000008000000 Partition: panic, [000008005000 - 000008805000], size: 000000800000 Partition: factory, [000008805000 - 00000A805000], size: 000002000000 Partition: spare, [00000A805000 - 00000B005000], size: 000000800000 Partition: config, [00000B005000 - 00000D005000], size: 000002000000 Partition: cache, [00000D005000 - 00002D005000], size: 000020000000 Partition: APD, [00002D005000 - 000039005000], size: 00000C000000 Partition: ADF, [000039005000 - 00003B005000], size: 000002000000 Partition: system, [00003B005000 - 00008C405000], size: 000051400000 Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000 GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_130206.extcsd EMMC Init completed. Operation: Write Dump Writing to: ROM1 , start: 0x000000000000 , size: 0x0001D2000000 Input file: D:\Easy Jtag\Dump\Asus- T00P\ASUS_T00P-A500KL_V11.3.1.14_M1.4.12_F\userarea.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 2014.28 KB/s All done time: [01:03:10:855] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 2050 mV CMD Active Level: 2474 mV EMMC Device Information : EMMC CID: 90014A484147326505030087C0E0617D EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014 EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG2e_0087C0E0_20180219_140826.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000044400], size: 000000040000 Partition: sdi, [000000044400 - 00000004C400], size: 000000008000 Partition: rpm, [00000004C400 - 0000000C9400], size: 00000007D000 Partition: tz, [0000000C9400 - 000000146400], size: 00000007D000 Partition: aboot, [000000146400 - 000000646400], size: 000000500000 Partition: ddr, [000001000000 - 000001008000], size: 000000008000 Partition: boot, [000001008000 - 000002008000], size: 000001000000 Partition: modem, [000002008000 - 000006008000], size: 000004000000 Partition: pad, [000007000000 - 000007100000], size: 000000100000 Partition: modemst1, [000007100000 - 000007280000], size: 000000180000 Partition: modemst2, [000007280000 - 000007400000], size: 000000180000 Partition: fsg, [000008000000 - 000008180000], size: 000000180000 Partition: asusdata, [000009000000 - 000009100000], size: 000000100000 Partition: asusdata2, [000009100000 - 000009200000], size: 000000100000 Partition: asuskey, [000009200000 - 000009300000], size: 000000100000 Partition: asuskey2, [000009300000 - 000009400000], size: 000000100000 Partition: asuskey3, [000009400000 - 000009500000], size: 000000100000 Partition: asuskey4, [000009500000 - 000009900000], size: 000000400000 Partition: asuskey5, [000009900000 - 000009D00000], size: 000000400000 Partition: asusfw, [000009D00000 - 000011D00000], size: 000008000000 Partition: sysconf, [000011D00000 - 000012100000], size: 000000400000 Partition: asusgpt, [000012100000 - 000012400000], size: 000000300000 Partition: fsc, [000012400000 - 000012400400], size: 000000000400 Partition: ssd, [000012400400 - 000012402400], size: 000000002000 Partition: misc, [000012402400 - 000012502400], size: 000000100000 Partition: persist, [000013000000 - 000015000000], size: 000002000000 Partition: recovery, [000015000000 - 000016000000], size: 000001000000 Partition: tombstones, [000016000000 - 00001A000000], size: 000004000000 Partition: asusgpt1, [00001A000000 - 00001A100000], size: 000000100000 Partition: asusgpt2, [00001A100000 - 00001A200000], size: 000000100000 Partition: ADF, [00001B000000 - 00001D000000], size: 000002000000 Partition: sbl1bak, [00001D000000 - 00001D040000], size: 000000040000 Partition: rpmbak, [00001D040000 - 00001D0BD000], size: 00000007D000 Partition: tzbak, [00001D0BD000 - 00001D13A000], size: 00000007D000 Partition: abootbak, [00001D13A000 - 00001D63A000], size: 000000500000 Partition: cache, [00001E000000 - 00004C000000], size: 00002E000000 Partition: APD, [00004C000000 - 000065000000], size: 000019000000 Partition: system, [000065000000 - 0000CC000000], size: 000067000000 Partition: userdata, [0000CC000000 - 0001D1FFBE00], size: 000105FFBE00 GPT header successfully parsed Get firmware version Brand = asus Manufacturer = asus Model = ASUS_T00P Phone platform = msm8226 CPU Abi = armeabi-v7a Android release = 4.4.2 Firmware version = OPEN_Phone-userdebug 4.4.2 KOT49H OPEN_Phone-11.3.1.14-20140922-F test-keys Firmware date = Mon Sep 22 12:37:39 CST 2014 |
