01-16-2018, 22:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | Htc one PN07100 after write dump still dead customer said phone is dead after charging process. i wrote 640mb dump from support and restored 256mb backup rom1 but set still dead!!! please any solution ? this is log : EMMC CID : 90014A484247346504010413829B6066 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 06/2013 Rev.0x1 EMMC NAME: HBG4e , S/N: 68387483 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _ 68387483_20180116_2142.extcsd Partition table scan: GPT: not present Found invalid GPT and valid MBR; converting MBR to GPT format Detected 32 meta partitions : Meta partition 0 Meta partition 3FFDF Meta partition 40000 Meta partition 40201 Meta partition 47BB5 Meta partition 47DB6 Meta partition 485B7 Meta partition 487B8 Meta partition 497B9 Meta partition 4A7FB Meta partition 4CFFC Meta partition 4D7FD Meta partition 4DFFE Meta partition 6C001 Meta partition 6FFFF Meta partition 80000 Meta partition 807FE Meta partition 827FF Meta partition 84800 Meta partition 8E801 Meta partition 8E80A Meta partition 8EA0B Meta partition 8EA2C Meta partition 8F42E Meta partition 8F4AF Meta partition 8FCB0 Meta partition C0000 Meta partition DA7FE Meta partition 100000 Meta partition 12FFFF Meta partition 138000 Meta partition 140000 You will need to delete this partition or resize it in another utility. Real (Hardware) Disk/Image size: 3A40000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3FFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): CF319000-7A95-E559-D2BF-2CDBB5834D03 First usable sector: 34 Last usable sector: 61079518 Found Data areas (firmware parts) count is: 23 Partition info successfully found --------------------------------------------- P0 (PARTITION_P4D) [0x200 0x20000] Size: 128.0KB P1 (PARTITION_P51) [0x20200 0x40000] Size: 256.0KB P2 (PARTITION_P5D) [0x60200 0x7f9bc00] Size: 127.608MB P4 (PARTITION_P5A) [0x7ffc000 0x4000] Size: 16.0KB P5 (PARTITION_P73) [0x8000200 0x40000] Size: 256.0KB P6 (PARTITION_P5B) [0x8040400 0xf36600] Size: 15.211MB P7 (PARTITION_P5C) [0x8f76c00 0x40000] Size: 256.0KB P8 (PARTITION_P45) [0x8fb6e00 0x100000] Size: 1.0MB P9 (PARTITION_P47) [0x90b7000 0x40000] Size: 256.0KB P10 (PARTITION_P46) [0x90f7200 0x200000] Size: 2.0MB P11 (PARTITION_P4C) [0x92f7400 0x208200] Size: 2.31MB P12 (PARTITION_P34) [0x94ff800 0x500000] Size: 5.0MB P13 (PARTITION_P36) [0x99ffa00 0x100000] Size: 1.0MB P15 (PARTITION_P50) [0x9bffe00 0x3c00400] Size: 60.0MB P16 (PARTITION_P74) [0xd800400 0x7ffa00] Size: 7.998MB P18 (PARTITION_P76) [0x10000200 0xffa00] Size: 1022.500KB P19 (PARTITION_P4A) [0x100ffe00 0x400000] Size: 4.0MB P20 (PARTITION_P4B) [0x10500000 0x400000] Size: 4.0MB P21 (PARTITION_P19) [0x10900200 0x1400000] Size: 20.0MB ------ Android information ------ --------------------------------------------- Done. Checking NAND Image : D:\GSM-MAAMOURA\HTC\ONE_M7\PN07100\backup 256mb_rom1_khardouk\EMMC_ROM1_HBG4e_68387483_00000 000_00040000.bin Autodetected RAW data File successefuly loaded! Partition table scan: GPT: not present Processing file...D:\GSM-MAAMOURA\HTC\ONE_M7\PN07100\backup 256mb_rom1_khardouk\EMMC_ROM1_HBG4e_68387483_00000 000_00040000.bin Writing as RAW data Z3X EasyJtag Software ver. 2.9.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1742 mV CMD Active Level:2258 mV Input file : D:\GSM-MAAMOURA\HTC\ONE_M7\PN07100\backup 256mb_rom1_khardouk\EMMC_ROM1_HBG4e_68387483_00000 000_00040000.bin Writing 0010000000 bytes to 0000000000... ROM1 (USER ROM) Done, time taken: 53 sec. Average Write Speed: 5005 kB/s |
