02-05-2014, 19:17 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2008 Location: freedoom ...algeria
Member: 686535 Status: Offline Sonork: 1592667 Thanks Meter: 108 | HTC One X (endeavoru) TEGRA repair done but jammed in HBOOT repair log: Loading eMMC Addon Firmware... CMD Pullup Level:3176 mV CMD Active Level:2846 mV EMMC CID 1501004B325530304D00F9D476E53F25 EMMC CSD D02701320F5903FFF6DBFFFF8A404007 EMMC Manufacturer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 4191450853 EMMC NAME: K2U00M EMMC Capacity: 29820 MB (High Density Card) Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 132 kB/s Done !!! Writing file...C:\Documents and Settings\choklat\Mes documents\one x\Nouveau dossier\512MB_HTC_ONE_X_ROM1\512MB_HTC_ONE_X_ROM1. bin Successefuly connected to box on COM27 Box S/N: 04040919xxxxxxxxx, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:3145 mV CMD Active Level:2825 mV EMMC CID 1501004B325530304D00F9D476E53F25 EMMC CSD D02701320F5903FFF6DBFFFF8A404007 EMMC Manufacturer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 4191450853 EMMC NAME: K2U00M EMMC Capacity: 29820 MB (High Density Card) Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 163 kB/s Done !!! after repair my phone now in fastboot ...hboot but i cant unlock boot loader via dev my phone accept unlock code.bin but after restart always locked and s-on hboot 1.39.0000 s-on . lockedcid HTC__Y13 version-main: 3.20.401.1 plz help me and sorry for my bad eng |
02-05-2014, 19:41 | #3 (permalink) |
Member: 686535 Status: Offline Sonork: 1592667 Thanks Meter: 108 | D:\h\fastboot>fastboot getvar all < waiting for device > (bootloader) version: 0.5a (bootloader) version-bootloader: 1.39.0 (bootloader) version-baseband: 5.1204.1 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 3.20.401.1 (bootloader) serialno: SH26CW105349 (bootloader) imei: 353426056880966 (bootloader) product: endeavoru (bootloader) platform: HBOOT-T30S (bootloader) modelid: PJ4610000 (bootloader) cidnum: HTC__Y13 (bootloader) battery-status: good (bootloader) battery-voltage: 3609mV (bootloader) devpower: 22 (bootloader) partition-layout: None (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: None (bootloader) hbootpreupdate: 2 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.906s |
02-05-2014, 20:27 | #5 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | For making flasheable your HTC one X you need to do following procedure: 1. Connect pinout as described on support 2. Make moviNAND format operation , restore extSCD backup. ( Now device are emptyboard and all data erased from flash tnx sikander3786 for trick ) 3. Write corresponding dump into the ROM1 - 512MB_HTC_ONE_X_ROM1 4. Write HTC_ONE_X_ROM2.rar to ROM2 and ROM3 5. Download from here HTC_ONE_X_SOLUTION_TEST.rar Pass: "GPGEMMC ARE ****ED COPYPASTERS" 6. Write rawpt_16g.BIN or rawpt_32g.BIN at USER ROM1 area depeding of your eMMC size ( see in connection log ) 7. Check SHOW SOFTWARE PARTITIONS INFO checkbox and detect eMMC - you will see partition list if all OK and presets list will be updated 8. Write EMMC_00200000_BIF_HTC__Y13_353999999999999.BIN in BIF partition ( select partition in presets list , you may fix IMEI in any hex editor ) 9. Write EMMC_00400000_SIF_1.00.000.0_1.0000.0000.00.bin in SIF partition ( select partition in presets list , phone will be 1.00.000.000 ) 10. Download RUU_ENDEAVOR_U_JB_45_S_HTC_Europe_3.14.401.31_R_Ra dio_5.1204.162.29_release_302015_signed.exe 11. If you want another region you can edit CID in EMMC_00200000_BIF_HTC__Y13_353999999999999.BIN current HTC__Y13 12. Desolder wires and flash phone. Do not forget remove JUMPER from eMMC reset pin. If you need to upgdate boot - try this solution P.S. If this will not work we need another rooted device with lower HBOOT version to get correct downgrade data. P.P.S. GPGEMMC focusers , you may do all this things in sw or even put in ONE SUPER REPAIR button and call this world first but do not forget write credits from where you have copied data. Link: HTC_ONE_X_SOLUTION_TEST Last edited by NoName®; 04-30-2014 at 00:56. |
The Following 4 Users Say Thank You to NoName® For This Useful Post: |
02-10-2014, 18:10 | #7 (permalink) |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Lock at step 5. Word begins from FUC letters ;-) Last edited by NoName®; 04-30-2014 at 00:55. |
The Following User Says Thank You to NoName® For This Useful Post: |
02-22-2014, 10:26 | #8 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Egypt,portsaid
Member: 709437 Status: Offline Sonork: 100.1611201 Thanks Meter: 25 | Quote:
Is There Any Solutions | |
03-05-2014, 12:21 | #10 (permalink) |
Member: 686535 Status: Offline Sonork: 1592667 Thanks Meter: 108 | hi admin plz i need more info about solution htc one tegra not flashing from this poste: HTC One X (endeavoru) TEGRA repair done but jammed in HBOOT how to write bif and sif partition 6. Write EMMC_00200000_BIF_HTC__Y13_353999999999999.BIN in BIF partition ( you may fix IMEI in any hex editor ) 7. Write EMMC_00400000_SIF_1.00.000.0_1.0000.0000.00.bin in SIF partition ( phone will be 1.00.000.000 ) plz step step thx advenced |
03-05-2014, 13:01 | #11 (permalink) |
Member: 686535 Status: Offline Sonork: 1592667 Thanks Meter: 108 | NVIDIA TABLE detected... Boot RVA Correction : 400000 Header ID: A6C42320021249BE2BB05DE0C7A6D912 Warning: Header Size = 2240 Warning: Entries Count = 27 MMCBLK0P0 (BCT) Adress in BOOT1+BOOT2 0x0, Length: 0x400000 MMCBLK0P1 (PT) Adress in USER: 0x0, Length: 0x200000 MMCBLK0P2 (EBT) Adress in USER: 0x200000, Length: 0x400000 MMCBLK0P3 (DIA) Adress in USER: 0x600000, Length: 0x400000 MMCBLK0P4 (BIF) Adress in USER: 0xA00000, Length: 0x200000 MMCBLK0P5 (GP1) Adress in USER: 0xC00000, Length: 0x200000 MMCBLK0P6 (WLN) Adress in USER: 0xE00000, Length: 0x600000 MMCBLK0P7 (WDM) Adress in USER: 0x1400000, Length: 0x200000 MMCBLK0P8 (RCA) Adress in USER: 0x1600000, Length: 0x600000 MMCBLK0P9 (LNX) Adress in USER: 0x1C00000, Length: 0x800000 MMCBLK0P10 (SOS) Adress in USER: 0x2400000, Length: 0x800000 MMCBLK0P11 (PG1) Adress in USER: 0x2C00000, Length: 0x1000000 MMCBLK0P12 (PG2) Adress in USER: 0x3C00000, Length: 0x1000000 MMCBLK0P13 (PG3) Adress in USER: 0x4C00000, Length: 0x1000000 MMCBLK0P14 (SIF) Adress in USER: 0x5C00000, Length: 0x400000 MMCBLK0P15 (SP1) Adress in USER: 0x6000000, Length: 0x400000 MMCBLK0P16 (RV1) Adress in USER: 0x6400000, Length: 0x1C00000 MMCBLK0P17 (APP) Adress in USER: 0x8000000, Length: 0x50000000 MMCBLK0P18 (CAC) Adress in USER: 0x58000000, Length: 0x14000000 MMCBLK0P19 (ISD) Adress in USER: 0x6C000000, Length: 0x650000000 MMCBLK0P20 (UDA) Adress in USER: 0x6BC000000, Length: 0x89400000 MMCBLK0P21 (DUM) Adress in USER: 0x745400000, Length: 0x200000 MMCBLK0P22 (MSC) Adress in USER: 0x745600000, Length: 0x200000 MMCBLK0P23 (RFS) Adress in USER: 0x745800000, Length: 0x600000 MMCBLK0P24 (DLG) Adress in USER: 0x745E00000, Length: 0x1600000 MMCBLK0P25 (PDT) Adress in USER: 0x747400000, Length: 0x200000 MMCBLK0P26 (GPT) Adress in USER: 0x747600000, Length: 0x200000 Done...Presets has been updated... Done. |
03-06-2014, 09:36 | #12 (permalink) |
Registered User Join Date: Sep 2012 Location: Rawalpindi, Pakistan
Member: 1809208 Status: Offline Thanks Meter: 28 | Why everyone just missed the factory format and movinand erase functions? Did you erase the chip and write extCSD before writing dumps? In a similar case, I was able to unlock the bootloader after I erased the chip and re-writed it. |
The Following User Says Thank You to sikander3786 For This Useful Post: |
03-06-2014, 22:41 | #13 (permalink) | |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
I am updated GUIDE with format step. | |
05-03-2014, 11:59 | #15 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | plz help ! after finished 6. Write rawpt_16g.BIN or rawpt_32g.BIN at USER ROM1 area depeding of your eMMC size ( see in connection log ) i can't load partition list Quote:
