11-01-2018, 14:44 | #1 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2874213 Status: Offline Thanks Meter: 9 | nokia 2.1 ta-1084 emmc config 10/25/2018 2:17:42 PM> EasyJTAG API ver. 2100 10/25/2018 2:17:42 PM> Setting IO Levels to 2.8V 10/25/2018 2:17:42 PM> Setting frequence to 42 Mhz 10/25/2018 2:17:42 PM> EasyJTAG Box Serial = 8B600F51929A6640 10/25/2018 2:17:42 PM> EasyJTAG Box Firmware = 2.30 10/25/2018 2:17:42 PM> Setting interface to EasyJtag2/E-Socket 10/25/2018 2:17:42 PM> Setting bus width to 1 Bit 10/25/2018 2:17:42 PM> Setting frequence to 42 Mhz 10/25/2018 2:17:43 PM> eMMC Init returned = 0 10/25/2018 2:17:43 PM> EMMC Device Information : 10/25/2018 2:17:43 PM> EMMC CID: 150100464E36324D420319B9D3525587 10/25/2018 2:17:43 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 10/25/2018 2:17:43 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: FN62MB , HEX: 464E36324D42 , S/N: 19B9D352 , rev. 0x03 10/25/2018 2:17:43 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2018 10/25/2018 2:17:43 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 10/25/2018 2:17:43 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/25/2018 2:17:43 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) 10/25/2018 2:17:43 PM> EMMC Permanent Write Protection: No 10/25/2018 2:17:43 PM> EMMC Temporary Write Protection: No 10/25/2018 2:17:43 PM> Extended CSD Information : 10/25/2018 2:17:43 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/25/2018 2:17:43 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 10/25/2018 2:17:43 PM> Boot Bus Config: 0x00 , width 1bit 10/25/2018 2:17:43 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/25/2018 2:17:43 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/25/2018 2:17:43 PM> Device supports partitioning features 10/25/2018 2:17:43 PM> Device can have enhanced technological features in partitions and user data area 10/25/2018 2:17:43 PM> Device can have extended partitions attribute 10/25/2018 2:17:43 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/25/2018 2:17:43 PM> Backup saved: FN62MB_19B9D352_20181025_141743.extcsd 10/25/2018 2:17:43 PM> EMMC Init completed. 10/25/2018 2:17:43 PM> 10/25/2018 2:17:43 PM> Scanning soft partitions 10/25/2018 2:17:43 PM> GPT header is found and is valid 10/25/2018 2:17:43 PM> Partition: modem, [000000200000 - 000005600000], size: 000005400000 (84.0 MB) 10/25/2018 2:17:43 PM> Partition: DDR, [000005600000 - 000005608000], size: 000000008000 (32.0 KB) 10/25/2018 2:17:43 PM> Partition: fsg, [000005608000 - 000005788000], size: 000000180000 (1.50 MB) 10/25/2018 2:17:43 PM> Partition: sec, [000005788000 - 00000578C000], size: 000000004000 (16.0 KB) 10/25/2018 2:17:43 PM> Partition: aboot, [00000578C000 - 00000588C000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: abootbak, [00000588C000 - 00000598C000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: boot, [00000598C000 - 00000698C000], size: 000001000000 (16.0 MB) 10/25/2018 2:17:43 PM> Partition: recovery, [00000698C000 - 00000818C000], size: 000001800000 (24.0 MB) 10/25/2018 2:17:43 PM> Partition: devinfo, [00000818C000 - 00000828C000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: system, [00000828C000 - 00005B5BF000], size: 000053333000 (1.30 GB) 10/25/2018 2:17:43 PM> Partition: vendor, [00005B5BF000 - 00006F5BF000], size: 000014000000 (320. MB) 10/25/2018 2:17:43 PM> Partition: limits, [00006F5BF000 - 00006F5C7000], size: 000000008000 (32.0 KB) 10/25/2018 2:17:43 PM> Partition: cmnlib, [00006F5C7000 - 00006F6C7000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: cmnlibbak, [00006F6C7000 - 00006F7C7000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: cmnlib64, [00006F7C7000 - 00006F8C7000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: cmnlib64bak, [00006F8C7000 - 00006F9C7000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: keymaster, [00006F9C7000 - 00006FAC7000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: keymasterbak, [00006FAC7000 - 00006FBC7000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: fsc, [00006FC00000 - 00006FC00400], size: 000000000400 (1.00 KB) 10/25/2018 2:17:43 PM> Partition: ssd, [00006FC01000 - 00006FC03000], size: 000000002000 (8.00 KB) 10/25/2018 2:17:43 PM> Partition: splash, [00006FC03000 - 000070003000], size: 000000400000 (4.00 MB) 10/25/2018 2:17:43 PM> Partition: sbl1, [000070003000 - 000070083000], size: 000000080000 (512. KB) 10/25/2018 2:17:43 PM> Partition: sbl1bak, [000070083000 - 000070103000], size: 000000080000 (512. KB) 10/25/2018 2:17:43 PM> Partition: rpm, [000070103000 - 000070183000], size: 000000080000 (512. KB) 10/25/2018 2:17:43 PM> Partition: rpmbak, [000070183000 - 000070203000], size: 000000080000 (512. KB) 10/25/2018 2:17:43 PM> Partition: tz, [000070203000 - 000070403000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: tzbak, [000070403000 - 000070603000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: devcfg, [000070603000 - 000070643000], size: 000000040000 (256. KB) 10/25/2018 2:17:43 PM> Partition: devcfgbak, [000070643000 - 000070683000], size: 000000040000 (256. KB) 10/25/2018 2:17:43 PM> Partition: dsp, [000070683000 - 000071683000], size: 000001000000 (16.0 MB) 10/25/2018 2:17:43 PM> Partition: modemst1, [000071683000 - 000071803000], size: 000000180000 (1.50 MB) 10/25/2018 2:17:43 PM> Partition: modemst2, [000071803000 - 000071983000], size: 000000180000 (1.50 MB) 10/25/2018 2:17:43 PM> Partition: securefs, [000071983000 - 000071B83000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: rf_nv, [000071B83000 - 000071D83000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: reserved, [000071D83000 - 000071F83000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: ftmboot, [000071F83000 - 000072F83000], size: 000001000000 (16.0 MB) 10/25/2018 2:17:43 PM> Partition: cust_nv, [000072F83000 - 000073183000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: default_nv, [000073183000 - 000073383000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: hwcfg, [000073383000 - 000073483000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: sutinfo, [000073483000 - 000073483400], size: 000000000400 (1.00 KB) 10/25/2018 2:17:43 PM> Partition: systeminfo, [000073484000 - 0000734C4000], size: 000000040000 (256. KB) 10/25/2018 2:17:43 PM> Partition: ftmlog, [0000734C4000 - 0000754C4000], size: 000002000000 (32.0 MB) 10/25/2018 2:17:43 PM> Partition: box, [0000754C4000 - 000075CC4000], size: 000000800000 (8.00 MB) 10/25/2018 2:17:43 PM> Partition: multi_splash, [000075CC4000 - 0000764C4000], size: 000000800000 (8.00 MB) 10/25/2018 2:17:43 PM> Partition: hidden, [0000764C4000 - 000077EC4000], size: 000001A00000 (26.0 MB) 10/25/2018 2:17:43 PM> Partition: cda, [000077EC4000 - 0000786C4000], size: 000000800000 (8.00 MB) 10/25/2018 2:17:43 PM> Partition: reserved_bak, [0000786C4000 - 0000788C4000], size: 000000200000 (2.00 MB) 10/25/2018 2:17:43 PM> Partition: deviceinfo, [0000788C4000 - 0000789C4000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: elabel, [0000789C4000 - 000078DC4000], size: 000000400000 (4.00 MB) 10/25/2018 2:17:43 PM> Partition: cache, [000078DC4000 - 000080DC4000], size: 000008000000 (128. MB) 10/25/2018 2:17:43 PM> Partition: persist, [000080DC4000 - 0000829C4000], size: 000001C00000 (28.0 MB) 10/25/2018 2:17:43 PM> Partition: misc, [0000829C4000 - 000082AC4000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: keystore, [000082AC4000 - 000082B44000], size: 000000080000 (512. KB) 10/25/2018 2:17:43 PM> Partition: config, [000082B44000 - 000082B4C000], size: 000000008000 (32.0 KB) 10/25/2018 2:17:43 PM> Partition: mota, [000082B4C000 - 000082BCC000], size: 000000080000 (512. KB) 10/25/2018 2:17:43 PM> Partition: dip, [000082BCC000 - 000082CCC000], size: 000000100000 (1.00 MB) 10/25/2018 2:17:43 PM> Partition: mdtp, [000082CCC000 - 0000844CC000], size: 000001800000 (24.0 MB) 10/25/2018 2:17:43 PM> Partition: syscfg, [0000844CC000 - 00008454C000], size: 000000080000 (512. KB) 10/25/2018 2:17:43 PM> Partition: mcfg, [00008454C000 - 00008494C000], size: 000000400000 (4.00 MB) 10/25/2018 2:17:43 PM> Partition: apdp, [00008494C000 - 00008498C000], size: 000000040000 (256. KB) 10/25/2018 2:17:43 PM> Partition: msadp, [00008498C000 - 0000849CC000], size: 000000040000 (256. KB) 10/25/2018 2:17:43 PM> Partition: dpo, [0000849CC000 - 0000849CE000], size: 000000002000 (8.00 KB) 10/25/2018 2:17:43 PM> Partition: userdata, [0000849CE000 - 0001D1FFBE00], size: 00014D62DE00 (5.21 GB) 10/25/2018 2:17:43 PM> GPT header successfully parsed 10/25/2018 2:17:43 PM> 10/25/2018 2:17:43 PM> Get firmware version 10/25/2018 2:17:43 PM> 10/25/2018 2:17:44 PM> Brand = Nokia 10/25/2018 2:17:44 PM> Manufacturer = HMD Global 10/25/2018 2:17:44 PM> Model = Nokia 2.1 2.1 10/25/2018 2:17:44 PM> CPU Abi = armeabi-v7a 10/25/2018 2:17:44 PM> Android release = 8.1.0 10/25/2018 2:17:44 PM> Firmware version = 00WW_0_29G 10/25/2018 2:17:44 PM> Firmware date = Mon Aug 20 18:46:02 CST 2018 10/25/2018 2:17:54 PM> 10/25/2018 2:17:54 PM> Looking for EasyJTAG box... 10/25/2018 2:17:54 PM> EasyJTAG API ver. 2100 10/25/2018 2:17:54 PM> Setting IO Levels to 2.8V 10/25/2018 2:17:54 PM> Setting frequence to 42 Mhz 10/25/2018 2:17:54 PM> EasyJTAG Box Serial = 8B600F51929A6640 10/25/2018 2:17:54 PM> EasyJTAG Box Firmware = 2.30 10/25/2018 2:17:55 PM> Setting interface to EasyJtag2/E-Socket 10/25/2018 2:17:55 PM> Setting bus width to 1 Bit 10/25/2018 2:17:55 PM> Setting frequence to 42 Mhz 10/25/2018 2:17:55 PM> eMMC Init returned = 0 10/25/2018 2:17:55 PM> EMMC Device Information : 10/25/2018 2:17:55 PM> EMMC CID: 150100464E36324D420319B9D3525587 10/25/2018 2:17:55 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 10/25/2018 2:17:55 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: FN62MB , HEX: 464E36324D42 , S/N: 19B9D352 , rev. 0x03 10/25/2018 2:17:55 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2018 10/25/2018 2:17:55 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 10/25/2018 2:17:55 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/25/2018 2:17:55 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) 10/25/2018 2:17:55 PM> EMMC Permanent Write Protection: No 10/25/2018 2:17:56 PM> EMMC Temporary Write Protection: No 10/25/2018 2:17:56 PM> Extended CSD Information : 10/25/2018 2:17:56 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/25/2018 2:17:56 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 10/25/2018 2:17:56 PM> Boot Bus Config: 0x00 , width 1bit 10/25/2018 2:17:56 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/25/2018 2:17:56 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/25/2018 2:17:56 PM> Device supports partitioning features 10/25/2018 2:17:56 PM> Device can have enhanced technological features in partitions and user data area 10/25/2018 2:17:56 PM> Device can have extended partitions attribute 10/25/2018 2:17:56 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/25/2018 2:17:56 PM> Backup saved: FN62MB_19B9D352_20181025_141756.extcsd 10/25/2018 2:17:56 PM> EMMC Init completed. 10/25/2018 2:17:56 PM> 10/25/2018 2:17:56 PM> Operation 'Remove FRP' 10/25/2018 2:17:56 PM> 10/25/2018 2:17:56 PM> Searching GPT ... 10/25/2018 2:17:56 PM> GPT header is found and is valid 10/25/2018 2:17:56 PM> 10/25/2018 2:17:56 PM> FRP partition found (partname: config) 10/25/2018 2:17:56 PM> Erasing FRP partition ... 10/25/2018 2:17:56 PM> Done erasing partition. 10/25/2018 2:17:56 PM> 10/25/2018 2:17:56 PM> All done |
