10-11-2018, 09:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1723271 Status: Offline Thanks Meter: 51 | Software bug Easy jtag Plus? G532f and Oppo R831k not detected on Easy jtag plus Box Urgent needed solution Thank you! Last edited by jryanp; 10-11-2018 at 09:14. |
10-11-2018, 16:38 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Sometime need to add voltage to IO, up from 1.8 to 2.8v, or use HipowerCLK Mode (connect only CMD/CLK/Dat0/GND, and power from board via USB) |
The Following User Says Thank You to layder For This Useful Post: |
10-12-2018, 09:15 | #6 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
in the new box schematics the CLK signal has excessive current and becomes sensitive to interference. therefore, when connecting via ISP, the following rules must be observed: 1) the length of the wire CLK/CMD/Dat0 should not different more than 1-2cm. 2) GND wire should not be thin Last edited by layder; 10-12-2018 at 09:21. | |
