11-27-2019, 14:57 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | samsung j200g dead boot repair help Looking for EasyJTAG box... 11/27/2019 6:55:43 PM> EasyJTAG API ver. 3307 11/27/2019 6:55:43 PM> Setting IO Levels to 1.8V 11/27/2019 6:55:43 PM> Setting frequence to 6 MHz 11/27/2019 6:55:43 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/27/2019 6:55:43 PM> EasyJTAG Box Firmware = 2.48 11/27/2019 6:55:44 PM> Setting interface to EasyJtag2/ISP 11/27/2019 6:55:44 PM> Setting bus width to 1 Bit 11/27/2019 6:55:44 PM> Setting frequence to 6 MHz 11/27/2019 6:55:44 PM> CMD Pullup Level: 516 mV 11/27/2019 6:55:44 PM> CMD Active Level: 1688 mV 11/27/2019 6:55:44 PM> eMMC Init returned = 0 11/27/2019 6:55:44 PM> EMMC Device Information : 11/27/2019 6:55:44 PM> EMMC CID: 150100464E31324D4200BB25CCF7C23F 11/27/2019 6:55:44 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 11/27/2019 6:55:44 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: FN12MB , HEX: 464E31324D42 , S/N: BB25CCF7 , rev. 0x00 11/27/2019 6:55:44 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2015 11/27/2019 6:55:44 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/27/2019 6:55:44 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/27/2019 6:55:44 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Counter: 2 , Response: Not Clean 11/27/2019 6:55:44 PM> EMMC Permanent Write Protection: No 11/27/2019 6:55:44 PM> EMMC Temporary Write Protection: No 11/27/2019 6:55:44 PM> Extended CSD Information : 11/27/2019 6:55:44 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/27/2019 6:55:44 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 11/27/2019 6:55:44 PM> Boot Bus Config: 0x01 , width 4bit 11/27/2019 6:55:44 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/27/2019 6:55:44 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/27/2019 6:55:44 PM> Device supports partitioning features 11/27/2019 6:55:44 PM> Device can have enhanced technological features in partitions and user data area 11/27/2019 6:55:44 PM> Device can have extended partitions attribute 11/27/2019 6:55:44 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/27/2019 6:55:44 PM> Backup saved: FN12MB_BB25CCF7_20191127_185544.extcsd 11/27/2019 6:55:44 PM> EMMC Init completed. 11/27/2019 6:55:44 PM> 11/27/2019 6:55:44 PM> Operation: Write by vendor (Samsung) 11/27/2019 6:55:44 PM> 11/27/2019 6:55:44 PM> Creating GPT-partitioninig 11/27/2019 6:55:44 PM> Writing PrimaryGPT at address: 000000000000 11/27/2019 6:55:44 PM> Writing BackupGPT at address: 0001D1FFBE00 11/27/2019 6:55:44 PM> Writing PIT at address: 000000004400 11/27/2019 6:55:44 PM> GPT-partitioning done 11/27/2019 6:55:44 PM> 11/27/2019 6:55:44 PM> Unpacking file: sboot.bin 11/27/2019 6:55:44 PM> Unpacking file: boot.img 11/27/2019 6:55:44 PM> Unpacking file: recovery.img 11/27/2019 6:55:44 PM> Unpacking file: modem.bin 11/27/2019 6:55:44 PM> Unpacking file: hidden.img 11/27/2019 6:55:44 PM> 11/27/2019 6:55:44 PM> Partition name: BOOTLOADER 11/27/2019 6:55:44 PM> Filename: sboot.bin , Offset: 000000000000 , filesize: 1411344 bytes 11/27/2019 6:55:44 PM> eMMC switching to ROM2 11/27/2019 6:55:45 PM> Erasing partition... 11/27/2019 6:55:59 PM> Writing partition... 11/27/2019 6:56:04 PM> Done writing partition. Write speed: 289.89 KB/s 11/27/2019 6:56:04 PM> Partition name: BOOT 11/27/2019 6:56:04 PM> Filename: boot.img , Offset: 000004000000 , filesize: 7960864 bytes 11/27/2019 6:56:04 PM> eMMC switching to ROM1 11/27/2019 6:56:04 PM> Erasing partition... 11/27/2019 6:56:07 PM> Writing partition... 11/27/2019 6:56:18 PM> Done writing partition. Write speed: 673.49 KB/s 11/27/2019 6:56:18 PM> Partition name: RECOVERY 11/27/2019 6:56:18 PM> Filename: recovery.img , Offset: 000004D00000 , filesize: 8843552 bytes 11/27/2019 6:56:18 PM> eMMC switching to ROM1 11/27/2019 6:56:19 PM> Erasing partition... 11/27/2019 6:56:20 PM> Writing partition... 11/27/2019 6:56:33 PM> Done writing partition. Write speed: 684.38 KB/s 11/27/2019 6:56:33 PM> Partition name: RADIO 11/27/2019 6:56:33 PM> Filename: modem.bin , Offset: 000006800000 , filesize: 33252976 bytes 11/27/2019 6:56:33 PM> eMMC switching to ROM1 11/27/2019 6:56:33 PM> Erasing partition... 11/27/2019 6:56:37 PM> Writing partition... 11/27/2019 6:57:01 PM> Error writing at address: 0000078B0000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 11/27/2019 6:57:24 PM> Done writing partition. Write speed: 691.35 KB/s 11/27/2019 6:57:24 PM> Partition name: HIDDEN 11/27/2019 6:57:24 PM> Filename: hidden.img , Offset: 0000A7000000 , filesize: 8372464 bytes 11/27/2019 6:57:24 PM> eMMC switching to ROM1 11/27/2019 6:57:24 PM> Erasing partition... 11/27/2019 6:57:28 PM> Writing partition... 11/27/2019 6:57:28 PM> Sparse image found v.1.0 Total chunks: 13 11/27/2019 6:57:28 PM> Error writing at address: 0000A7001000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 11/27/2019 6:57:30 PM> Error writing at address: 0000A70D4000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 11/27/2019 6:57:30 PM> Error writing at address: 0000A70D4000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2 11/27/2019 6:57:33 PM> Error writing at address: 0000A72E4000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 11/27/2019 6:57:34 PM> Error writing at address: 0000A72E4000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2 11/27/2019 6:57:41 PM> Done writing partition. Write speed: 613.83 KB/s 11/27/2019 6:57:42 PM> 11/27/2019 6:57:42 PM> Check BootConfig for the selected vendor 11/27/2019 6:57:42 PM> 11/27/2019 6:57:42 PM> All done time: [00:01:57:484] Looking for EasyJTAG box... 11/27/2019 7:00:07 PM> EasyJTAG API ver. 3307 11/27/2019 7:00:07 PM> Setting IO Levels to 1.8V 11/27/2019 7:00:07 PM> Setting frequence to 6 MHz 11/27/2019 7:00:07 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/27/2019 7:00:07 PM> EasyJTAG Box Firmware = 2.48 11/27/2019 7:00:08 PM> Setting interface to EasyJtag2/ISP 11/27/2019 7:00:08 PM> Setting bus width to 1 Bit 11/27/2019 7:00:08 PM> Setting frequence to 6 MHz 11/27/2019 7:00:08 PM> CMD Pullup Level: 518 mV 11/27/2019 7:00:08 PM> CMD Active Level: 1687 mV 11/27/2019 7:00:08 PM> eMMC Init returned = 0 11/27/2019 7:00:08 PM> EMMC Device Information : 11/27/2019 7:00:08 PM> EMMC CID: 150100464E31324D4200BB25CCF7C23F 11/27/2019 7:00:08 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 11/27/2019 7:00:08 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: FN12MB , HEX: 464E31324D42 , S/N: BB25CCF7 , rev. 0x00 11/27/2019 7:00:08 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2015 11/27/2019 7:00:08 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/27/2019 7:00:08 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/27/2019 7:00:08 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Counter: 2 , Response: Not Clean 11/27/2019 7:00:08 PM> EMMC Permanent Write Protection: No 11/27/2019 7:00:08 PM> EMMC Temporary Write Protection: No 11/27/2019 7:00:08 PM> Extended CSD Information : 11/27/2019 7:00:08 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/27/2019 7:00:08 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 11/27/2019 7:00:08 PM> Boot Bus Config: 0x01 , width 4bit 11/27/2019 7:00:08 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/27/2019 7:00:08 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/27/2019 7:00:08 PM> Device supports partitioning features 11/27/2019 7:00:08 PM> Device can have enhanced technological features in partitions and user data area 11/27/2019 7:00:08 PM> Device can have extended partitions attribute 11/27/2019 7:00:08 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/27/2019 7:00:08 PM> Backup saved: FN12MB_BB25CCF7_20191127_190008.extcsd 11/27/2019 7:00:08 PM> EMMC Init completed. 11/27/2019 7:00:08 PM> 11/27/2019 7:00:09 PM> Scanning soft partitions 11/27/2019 7:00:09 PM> GPT header is found and is valid 11/27/2019 7:00:09 PM> Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) 11/27/2019 7:00:09 PM> Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) 11/27/2019 7:00:09 PM> Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: CARRIER, [000003400000 - 000003800000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: PARAM, [000003800000 - 000004000000], size: 000000800000 (8.00 MB) 11/27/2019 7:00:09 PM> Partition: BOOT, [000004000000 - 000004D00000], size: 000000D00000 (13.0 MB) 11/27/2019 7:00:09 PM> Partition: RECOVERY, [000004D00000 - 000005C00000], size: 000000F00000 (15.0 MB) 11/27/2019 7:00:09 PM> Partition: OTA, [000005C00000 - 000006400000], size: 000000800000 (8.00 MB) 11/27/2019 7:00:09 PM> Partition: CDMA-RADIO, [000006400000 - 000006800000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: RADIO, [000006800000 - 000009000000], size: 000002800000 (40.0 MB) 11/27/2019 7:00:09 PM> Partition: TOMBSTONES, [000009000000 - 000009400000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: TDATA, [000009400000 - 000009800000], size: 000000400000 (4.00 MB) 11/27/2019 7:00:09 PM> Partition: PERSISTENT, [000009800000 - 000009900000], size: 000000100000 (1.00 MB) 11/27/2019 7:00:09 PM> Partition: PERSDATA, [000009900000 - 00000A500000], size: 000000C00000 (12.0 MB) 11/27/2019 7:00:09 PM> Partition: RESERVED2, [00000A500000 - 00000A800000], size: 000000300000 (3.00 MB) 11/27/2019 7:00:09 PM> Partition: SYSTEM, [00000A800000 - 00009A800000], size: 000090000000 (2.25 GB) 11/27/2019 7:00:09 PM> Partition: CACHE, [00009A800000 - 0000A7000000], size: 00000C800000 (200. MB) 11/27/2019 7:00:09 PM> Partition: HIDDEN, [0000A7000000 - 0000A9800000], size: 000002800000 (40.0 MB) 11/27/2019 7:00:09 PM> Partition: USERDATA, [0000A9800000 - 0001D1FFBE00], size: 0001287FBE00 (4.63 GB) 11/27/2019 7:00:09 PM> GPT header successfully parsed 11/27/2019 7:00:09 PM> 11/27/2019 7:00:09 PM> Get firmware version 11/27/2019 7:00:09 PM> 11/27/2019 7:00:11 PM> Firmware info not found |
The Following User Says Thank You to Bhagat20 For This Useful Post: |
11-27-2019, 21:05 | #3 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Stream the same procedure for your J200G [Exynos 3475] but I had the J200H with [sc8830] so hope you will be succeed in my method. http://forum.gsmhosting.com/vbb/12908211-post4.html |
The Following 2 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
11-28-2019, 05:16 | #4 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
11-28-2019, 13:08 | #6 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote: | |
11-28-2019, 14:02 | #7 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | logs by classic suite Selected eMMC Interface Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.48 CMD Pullup Level:512 mV CMD Active Level:1680 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100464E31324D4200BB25CCF7C23F eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2015 Rev.0x0 eMMC NAME: FN12MB , S/N: 3139816695 eMMC NAME (HEX): 464E31324D42 IC Name: Samsung , KMFN10012M-B214/8GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 7440 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC RPMB is programmed and written 2 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: FN12MB_3139816695_20191128_1822.extcsd Warning! Disk size is smaller than the main header indicates! Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E88000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,15269854 Partition info successfully found ------ Detected 23 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x400000] Size: 4.0MB P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB P3 (CPEFS) [0x2000000 0x800000] Size: 8.0MB P4 (M9KEFS1) [0x2800000 0x400000] Size: 4.0MB P5 (M9KEFS2) [0x2c00000 0x400000] Size: 4.0MB P6 (M9KEFS3) [0x3000000 0x400000] Size: 4.0MB P7 (CARRIER) [0x3400000 0x400000] Size: 4.0MB P8 (PARAM) [0x3800000 0x800000] Size: 8.0MB P9 (BOOT) [0x4000000 0xd00000] Size: 13.0MB P10 (RECOVERY) [0x4d00000 0xf00000] Size: 15.0MB P11 (OTA) [0x5c00000 0x800000] Size: 8.0MB P12 (CDMA-RADIO) [0x6400000 0x400000] Size: 4.0MB P13 (RADIO) [0x6800000 0x2800000] Size: 40.0MB P14 (TOMBSTONES) [0x9000000 0x400000] Size: 4.0MB P15 (TDATA) [0x9400000 0x400000] Size: 4.0MB P16 (PERSISTENT) [0x9800000 0x100000] Size: 1.0MB P17 (PERSDATA) [0x9900000 0xc00000] Size: 12.0MB P18 (RESERVED2) [0xa500000 0x300000] Size: 3.0MB P19 (SYSTEM) [0xa800000 0x90000000] Size: 2.250GB P20 (CACHE) [0x9a800000 0xc800000] Size: 200.0MB P21 (HIDDEN) [0xa7000000 0x2800000] Size: 40.0MB P22 (USERDATA) [0xa9800000 0x128400000] Size: 4.628GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000A800000 (2.250GB) --------------------------------------------- Detected USERDATA USERDATA : 0x00A9800000 (4.628GB) Unable to read gesture.key , code 2 Done. Selected eMMC Interface |
11-28-2019, 15:24 | #8 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | 1) First. you need be sure, what problem is in software 2) Second, you need be knowm what you do 3) Third, you need know, how it work 4) adn Fourthly: You need expirence by work with devices translate the instructon and try repair you make money and I won’t work in your place. questions about the repair of these devices were discussed on the forum hundreds of times. read the following topics. http://forum.gsmhosting.com/vbb/f672...highlight=j200 The principles of writing a bootloader to a chip are the same for more than 90% of the Samsung devices (exclude old devices) If you have only destroyed boot, you device work after you write latest service firmware by vendor (without "Repartition") Also you may be have problem with PCB, not software |
05-26-2020, 07:47 | #10 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Phone is completely working now, but unable to repair imei, so no service problem, no network, this is another j200g, tried many j200g, everything works well after dead boot repair, but unable to repair imei, facing this problem with many j200g, unable to repair imei which is dead boot repaired, other j200g phones imei are easily repaired with z3x pro, that means some problem with only dead boot repaired j200g, please someone suggested what need to be done? |
