Old 05-01-2020, 09:39   #1 (permalink)
Member: 666414
Thanks Meter: 38
vivo y11 PD1930f format failed
first i tried for reset locks but no success. then try to format userdata also failed.
Z3X EasyJtag EMMC File Manager v 1.18 TEST at 04/04/2020 Started..
Box API Version: 3308
FS Driver Version: 11062019
SQLite Version: 3.30.1
FSCK Engine Version: 11062019
ESE DB Version: 11062019
System Util Version: 11062019
System: Windows NT 6.1 (Build 7601, Service Pack 1) / 32 BIT
CPU: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
!!FOR BETA-TESTERS ONLY!!
Z3X Card Serial: AA90CE73
EasyJtag Plus Box Found at: COM11
EasyJtag Plus Box Firmware: 2.50
Source: Qualcomm 9008 EMMC/UFS/AUTO
Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
Box Voltage set to: 2800 mV
Scanner Thread Created..
Config: 101111111110111
Setup HiPower CLK: OFF
Connecting To EasyJtag Plus Box: 2800mV/21MHz/8BIT
EasyJtag Plus Box Found! Result: 0/OK
EasyJtag Plus S/N: EE47C708F676D597
EasyJtag Plus Box FirmWare: 2.50
Box Bus Width = 8 BIT
Box Hardware = EasyJtag 2nd Generation
Use Qlm 9008 (EDL) Mode..
Please Connect Qlm Device in 9008 (EDL) Mode..
Selected Primary Memory Type: AUTO
Waiting For Device..
Found Device:
Path: \\?\usb#vid_05c6&pid_9008#5&32ab4e3b&0&7#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Desc: Qualcomm HS-USB QDLoader 9008
HWID: USB\VID_05C6&PID_9008&REV_0000
Name: Qualcomm HS-USB QDLoader 9008 (COM15)
Vendor: Lenovo Inc.
Trying Connect to Device..
Open Port OK
Sahara OK, Get Data..
Read Qualcomm CPU Info OK
S/N: 0xF55BF838
HW ID: 0x000BF0E100000000
HASH: 0x60BA997FEF6DA9F05885FA11F1DD6D2A90D052A257A09C20 75D7246CC73C0D43
SBL : 0x00000000
DEV HASH: 0x000000171561
CPU : SnapDragon 439 [SDM439]
Loader Automatically Selected..
Using Qlm Loader: 36AA2853000000171561.ldr
Sending Loader..
Loader Size: 390408 bytes
Loader CheckSum: 0x48C842C5
Loader Info:
HWID: 0x000BF0E100000000
SWID: 0x0000000000000003
CPU: MSM8937
CERT Cnt: 3
Wait..
Loader Sent, Run FireHose..
Get Memory Type.. [AUTO]
Detected Memory: EMMC
FireHose Config Info: MSM8937, Memory: eMMC, Ver: 1
Ext Info: 0x00002000/0x00100000/0x00001000/0x00001000
FireHose Configure OK
Get Protocol Type..
Detected Generic FireHose Type..
Reading EMMC ROM's Info..
EMMC ROM #1 -> 61071360 / 29.12 GB
EMMC ROM #2 -> 8192 / 4.00 MB
EMMC ROM #3 -> 8192 / 4.00 MB
Memory Type: EMMC
Physical Partitions: 3
Packet Size: 16384
Sector Size: 512
EMMC Vendor: 0x90 -> SKHYNIX
EMMC OEM ID: 0x4A
EMMC NAME: hB8aP>
BOOT OK, FireHose Ready..
Selected Primary Memory Type: EMMC
Run Main Engine..
Scanning GUID Partition Table from ROM1
GUID Partition Table is Found. Max Parts: 60
GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB
GPT: MODEM [000001000000 - 000008000000] Size: 128.00 MB
GPT: FSC [000009000000 - 000000000400] Size: 1.00 KB
GPT: SSD [000009001000 - 000000002000] Size: 8.00 KB
GPT: SBL1 [000009003000 - 000000080000] Size: 512.00 KB
GPT: SBL1BAK [000009083000 - 000000080000] Size: 512.00 KB
GPT: RPM [000009103000 - 000000080000] Size: 512.00 KB
GPT: RPMBAK [000009183000 - 000000080000] Size: 512.00 KB
GPT: TZ [000009203000 - 000000200000] Size: 2.00 MB
GPT: TZBAK [000009403000 - 000000200000] Size: 2.00 MB
GPT: DEVCFG [000009603000 - 000000040000] Size: 256.00 KB
GPT: DEVCFGBAK [000009643000 - 000000040000] Size: 256.00 KB
GPT: DSP [000009683000 - 000001000000] Size: 16.00 MB
GPT: DSPBAK [00000A683000 - 000001000000] Size: 16.00 MB
GPT: MODEMST1 [00000B683000 - 000000280000] Size: 2.50 MB
GPT: MODEMST2 [00000B903000 - 000000280000] Size: 2.50 MB
GPT: DDR [00000C000000 - 000000008000] Size: 32.00 KB
GPT: FSG [00000C008000 - 000000280000] Size: 2.50 MB
GPT: SEC [00000C288000 - 000000004000] Size: 16.00 KB
GPT: SPLASH [00000D000000 - 000000B00000] Size: 11.00 MB
GPT: ABOOT [00000E000000 - 000001000000] Size: 16.00 MB
GPT: ABOOTBAK [00000F000000 - 000001000000] Size: 16.00 MB
GPT: DTBO [000010000000 - 000000800000] Size: 8.00 MB
GPT: DTBOBAK [000010800000 - 000000800000] Size: 8.00 MB
GPT: VBMETA [000011000000 - 000000010000] Size: 64.00 KB
GPT: VBMETABAK [000011010000 - 000000010000] Size: 64.00 KB
GPT: BOOT [000011020000 - 000004000000] Size: 64.00 MB
GPT: RECOVERY [000015020000 - 000004000000] Size: 64.00 MB
GPT: DEVINFO [000019020000 - 000001000000] Size: 16.00 MB
GPT: SYSTEM [00001A020000 - 000100000000] Size: 4.00 GB
GPT: VENDOR [00011A020000 - 000040000000] Size: 1.00 GB
GPT: CACHE [00015B000000 - 000010000000] Size: 256.00 MB
GPT: PERSIST [00016B000000 - 000002000000] Size: 32.00 MB
GPT: MISC [00016D000000 - 000000100000] Size: 1.00 MB
GPT: KEYSTORE [00016D100000 - 000000080000] Size: 512.00 KB
GPT: CONFIG [00016D180000 - 000000008000] Size: 32.00 KB
GPT: OEM [00016D188000 - 000004000000] Size: 64.00 MB
GPT: LIMITS [000172000000 - 000000008000] Size: 32.00 KB
GPT: MOTA [000173000000 - 000000080000] Size: 512.00 KB
GPT: DIP [000173080000 - 000000100000] Size: 1.00 MB
GPT: MDTP [000173180000 - 000002000000] Size: 32.00 MB
GPT: MDTPBAK [000175180000 - 000002000000] Size: 32.00 MB
GPT: SYSCFG [000177180000 - 000000080000] Size: 512.00 KB
GPT: MCFG [000177200000 - 000000400000] Size: 4.00 MB
GPT: CMNLIB [000178000000 - 000000100000] Size: 1.00 MB
GPT: CMNLIBBAK [000178100000 - 000000100000] Size: 1.00 MB
GPT: CMNLIB64 [000178200000 - 000000100000] Size: 1.00 MB
GPT: CMNLIB64BAK [000178300000 - 000000100000] Size: 1.00 MB
GPT: KEYMASTER [000178400000 - 000000100000] Size: 1.00 MB
GPT: KEYMASTERBAK [000178500000 - 000000100000] Size: 1.00 MB
GPT: SURVIVAL [000178600000 - 000004000000] Size: 64.00 MB
GPT: APDP [00017D000000 - 000000040000] Size: 256.00 KB
GPT: MSADP [00017D040000 - 000000040000] Size: 256.00 KB
GPT: DPO [00017D080000 - 000000002000] Size: 8.00 KB
GPT: LOGDUMP [00017D082000 - 000004000000] Size: 64.00 MB
GPT: APANIC [000181082000 - 000000A00000] Size: 10.00 MB
GPT: BACKUP [000181A82000 - 000000A00000] Size: 10.00 MB
GPT: SEED [000182482000 - 000000400000] Size: 4.00 MB
GPT: RESERVED [000182882000 - 000000A00000] Size: 10.00 MB
GPT: USERDATA [000183282000 - 0005C4979E00] Size: 23.07 GB
GPT: BACKUP_GPT [000747BFBE00 - 000000004200] Size: 16.50 KB
Reading Table Completed
Scanning GUID Partition Table from ROM2
GPT Signature Not Found. Break..
Scanning GUID Partition Table from ROM3
Partition #5 mount as [/MODEM] -> 128.00 MB
Partition #16 mount as [/dev_16] -> 16.00 MB
Partition #17 mount as [/dev_17] -> 16.00 MB
Partition #33 mount as [/dev_33] -> 4.00 GB
Partition #34 mount as [/dev_34] -> 1.00 GB
Partition #35 mount as [/cache] -> 256.00 MB
Partition #36 mount as [/mnt/vendor/persist] -> 32.00 MB
Partition #40 mount as [/dev_40] -> 64.00 MB
Warning! Partition #63 -> 'USERDATA' is ENCRYPTED!
EmptyCheck:
EMPTY -> #22 - [SPLASH]
EMPTY -> #36 - [MISC]
EMPTY -> #37 - [KEYSTORE]
EMPTY -> #40 - [LIMITS]
EMPTY -> #41 - [MOTA]
EMPTY -> #42 - [DIP]
EMPTY -> #45 - [SYSCFG]
EMPTY -> #46 - [MCFG]
EMPTY -> #54 - [APDP]
EMPTY -> #55 - [MSADP]
EMPTY -> #56 - [DPO]
EMPTY -> #57 - [LOGDUMP]
EMPTY -> #58 - [APANIC]
EMPTY -> #60 - [SEED]
EMPTY -> #61 - [RESERVED]
EmptyCheck: Done
Warning! Device Blocked by FRP
For Reset FRP Try to Tools Tab
Press Reset FRP Button
Partition #39 -> CONFIG
Android Info:
Brand = vivo
Vendor = vivo
Device = PD1930F_EX
Model = vivo 1906
Product = msm8937_64
CPU ABI = arm64-v8a
Android Version = 9
Firm Version = PKQ1.190616.001 release-keys
Inc. Version = compiler02142116
Firm Date = Fri Feb 14 21:15:39 CST 2020
Security Patch = 2020-01-01
Android Info:
Platform = msm8937
Scanner Thread Terminated
Elapsed: 00:00:07:322
Found 64 Partition(s)..
Scan Done. Init Main Engine...
Use Qlm EMMC Device: Qualcomm HS-USB QDLoader 9008 (COM15)
Reader Engine Initialized.. 0/OK
Operation Done: [Init Engine], Elapsed: 00:00:00:030
Reset User Locks v 2.0
Partition UserData is Encrypted. Break..
Session is Closed..
Found Device:
Vendor: Lenovo Inc.
Open Port OK
S/N: 0xF55BF838
SBL : 0x00000000
Sending Loader..
Loader Info:
CPU: MSM8937
CERT Cnt: 3
Wait..
Get Protocol Type..
Memory Type: EMMC
Packet Size: 16384
Sector Size: 512
EMMC OEM ID: 0x4A
EMMC NAME: hB8aP>
Run Main Engine..
EmptyCheck:
EmptyCheck: Done
Android Info:
Brand = vivo
Vendor = vivo
Device = PD1930F_EX
Model = vivo 1906
CPU ABI = arm64-v8a
Android Version = 9
Android Info:
Platform = msm8937
Elapsed: 00:00:07:194
Wipe User Data v1.0
Wiping Misc Partition..
Partition #37 is '/misc'. Erasing..
Error Writing Sector: 11960320, Count: 1, Err: 13
Error While Writing Data. Exit. Code: -1
Operation Failure: [Wipe User Data], Code: -1, Elapsed: 00:00:00:030
Page generated in 0.19024 seconds with 8 queries
