08-01-2017, 09:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: GREENHILLS
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | Huawei U9200 Need help. Huawei U9200 hang logo and now dead not detected in USB but detected in eMMc card, Need help for this. Please see the logs below. Code: Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 180070044F0D2A28, ,FW Ver.: 01.60 CMD Pullup Level:1732 mV CMD Active Level:1794 mV Box IO Level:1850 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 02000053444D30333290FFFFFFFF29BC EMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AA EMMC Manufacturer ID: 0002 , OEM ID: 0000 EMMC Date: 02/2006 Rev.0x90 EMMC NAME: SDM032 , S/N: 4294967295 EMMC NAME (HEX): 53444D30333200 EMMC ROM1 (Main User Data) Capacity: 30 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x00 Device NOT support partitioning feature Device cannot have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SDM032_4294967295_20170801_1615.extcsd Done. Thank's BR. |
08-01-2017, 09:31 | #2 (permalink) | ||
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | I tried to read the eMMc and this is the result. Quote:
Br. Last edited by DEADBOOT; 08-01-2017 at 09:36. | ||
08-01-2017, 09:59 | #5 (permalink) |
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | Thanks for the fast reply bro, Do you have full dump of this device bro, so that i will try first to write full firmware first before i proceed to change this eMMC. and this eMMC is SanDisk Can i replace this with any eMMC? BR. |
