03-30-2016, 15:32 | #1 (permalink) |
Junior Member Join Date: Sep 2006 Location: Greece Age: 41
Member: 349413 Status: Offline Thanks Meter: 8 | Huawei Y530-U00 fails to write ROM1 I'm trying to revive a Huawei Y530_U00 but it fails to write ROM1. It can write ROM2 and ROM3 fine. I also tried to erase the EMMC card and it also completed fine. Has anyone else had the same problem. Could this be a faulty Flash IC? EasyJtag Suite ver.: 2.0.7.6 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows XP (build 2600, Service Pack 3). undefined Android Explorer ver.: 1.1.0.22 eMMC ODIN ver.: 1.0.11.3 Successfully connected to box on COM32 Box S/N: 1700E0028874****, ,FW Ver.: 01.52 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA91-1496 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : ACTIVATED, Upgrade it! Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.0.7.6 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 1700E0028874B844, ,FW Ver.: 01.52 CMD Pullup Level:1567 mV CMD Active Level:1577 mV HiPower™ mode is ON! eMMC Device Information EMMC CID : 90014A4834473164040309A56A2C31D8 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2014 Rev.0x3 EMMC NAME: H4G1d , S/N: 161835564 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: H4G1d _ 161835564_20160330_1727.extcsd Searching for partition tables... Partitioning not detected... Done. extCSD file...C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\004G90_2677974583_20151002_21 42.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1567 mV CMD Active Level:1577 mV Writing... Done. Checking NAND Image : C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM2_00000000_00400000.b in File successefuly loaded! Processing file...C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM2_00000000_00400000.b in Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1567 mV CMD Active Level:1577 mV Input file : C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM2_00000000_00400000.b in Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 758 kB/s Checking NAND Image : C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM3_00000000_00400000.b in File successefuly loaded! Processing file...C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM3_00000000_00400000.b in Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1567 mV CMD Active Level:1577 mV Input file : C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM3_00000000_00400000.b in Writing 0000200000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 789 kB/s Checking NAND Image : C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM1_00000000_100000000. bin File successefuly loaded! Processing file...C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM1_00000000_100000000. bin Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1567 mV CMD Active Level:1577 mV Input file : C:\Program Files\Z3X\9. Easy Jtag files\Huawei\ASCEND Y530_U00\Dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM1_00000000_100000000. bin Writing 00EC000000 bytes to 00000000 ...ROM1 (USER ROM) Write Length has been corrected to 0x00E9000000 bytes... Write Block Failed, Reason: Write Block Verify Error Done. |
03-30-2016, 16:13 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Swansea, UK Age: 41
Member: 523318 Status: Offline Thanks Meter: 268 | Look at the eMMC name H4G1d can't have small letters only capitals. Try to update firmware then format if it doesn't help replace eMMC. Sent from my iPhone using Tapatalk |
03-31-2016, 00:27 | #3 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Street line baby
Member: 695310 Status: Offline Thanks Meter: 144 | bad block emmc....must factory format first,this emmc other samsung,,easy jtag not support format factory emmc other brand,,,, try uf* box,,,or you can used tab misc ,,try options delay timing bad block set to longest delay..goodluck |
03-31-2016, 08:33 | #4 (permalink) |
Member: 349413 Status: Offline Thanks Meter: 8 | Unfortunately I can not format it because it is not Samsung, it is SKhynix and z3x does not support it. I will try to find a board that uses the same IC and charge it. Thanks for your help. |
03-31-2016, 15:33 | #5 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, You have to try use options "Disable Write Optimization" from "Misc" tap https://gyazo.com/9301956042244ac06f23f60f9f6b4800 If doesn't help, eMMC is faulty and needs to be replaced. Best Regard |
The Following 2 Users Say Thank You to vikboston For This Useful Post: |
03-31-2016, 16:50 | #6 (permalink) | |
Member: 349413 Status: Offline Thanks Meter: 8 | Quote:
Sent from my Elite 2 using Tapatalk | |
04-01-2016, 18:28 | #7 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Quote:
this is SKhynix eMMC, solution is is still not exist until today, for repair eMMC/Upgrade firmware. PS. only samsung brand eMMC/eMCP can be repair and do FFU | |
