Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-11-2018, 16:10   #1 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 377
Thumbs up huawei y550-l01 internal storage damaged and is now unavailable repair done
change emmc sandisk 4gb to skhynix 8gb
8/11/2018 6:22:20 PM> EasyJTAG Box Firmware = 2.21
8/11/2018 6:22:21 PM> Setting interface to EasyJtag2/E-Socket
8/11/2018 6:22:21 PM> Setting bus width to 1 Bit
8/11/2018 6:22:21 PM> Setting frequence to 42 Mhz
8/11/2018 6:22:21 PM> eMMC Init returned = 0
8/11/2018 6:22:21 PM> EMMC Device Information :
8/11/2018 6:22:21 PM> EMMC CID: 90014A4838473165050724802E2142BF
8/11/2018 6:22:21 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3
8/11/2018 6:22:21 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: 24802E21 , rev. 0x07
8/11/2018 6:22:21 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015
8/11/2018 6:22:21 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
8/11/2018 6:22:21 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
8/11/2018 6:22:21 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
8/11/2018 6:22:21 PM> EMMC Permanent Write Protection: No
8/11/2018 6:22:21 PM> EMMC Temporary Write Protection: No
8/11/2018 6:22:21 PM> Extended CSD Information :
8/11/2018 6:22:21 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
8/11/2018 6:22:21 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
8/11/2018 6:22:21 PM> Boot Bus Config: 0x00 , width 1bit
8/11/2018 6:22:21 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
8/11/2018 6:22:21 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
8/11/2018 6:22:21 PM> Device supports partitioning features
8/11/2018 6:22:21 PM> Device can have enhanced technological features in partitions and user data area
8/11/2018 6:22:21 PM> Device can have extended partitions attribute
8/11/2018 6:22:21 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
8/11/2018 6:22:21 PM> Backup saved: H8G1e_24802E21_20180811_182221.extcsd
8/11/2018 6:22:21 PM> EMMC Init completed.
8/11/2018 6:22:22 PM> Operation: Write by vendor (Qualcomm/HiSilicon)
8/11/2018 6:22:22 PM> Creating GPT-partitioninig
8/11/2018 6:22:22 PM> GPT-partitioning done
8/11/2018 6:22:22 PM> Partition name: sbl1
8/11/2018 6:22:22 PM> Filename: sbl1.bin , Offset: 000000004400 , filesize: 524288 bytes
8/11/2018 6:22:22 PM> eMMC switching to ROM1
8/11/2018 6:22:22 PM> Erasing partition...
8/11/2018 6:22:23 PM> Writing partition...
8/11/2018 6:22:23 PM> Done writing partition. Write speed: 2407.06 KB/s
8/11/2018 6:22:23 PM> Partition name: hyp
8/11/2018 6:22:23 PM> Filename: hyp.bin , Offset: 000000084400 , filesize: 524288 bytes
8/11/2018 6:22:23 PM> eMMC switching to ROM1
8/11/2018 6:22:23 PM> Erasing partition...
8/11/2018 6:22:24 PM> Writing partition...
8/11/2018 6:22:24 PM> Done writing partition. Write speed: 4625.54 KB/s
8/11/2018 6:22:24 PM> Partition name: sec
8/11/2018 6:22:24 PM> Filename: sec.bin , Offset: 000000400000 , filesize: 32768 bytes
8/11/2018 6:22:24 PM> eMMC switching to ROM1
8/11/2018 6:22:24 PM> Erasing partition...
8/11/2018 6:22:25 PM> Writing partition...
8/11/2018 6:22:25 PM> Done writing partition. Write speed: 2406.53 KB/s
8/11/2018 6:22:25 PM> Partition name: DDR
8/11/2018 6:22:25 PM> Filename: DDR.bin , Offset: 000000408000 , filesize: 32768 bytes
8/11/2018 6:22:25 PM> eMMC switching to ROM1
8/11/2018 6:22:25 PM> Erasing partition...
8/11/2018 6:22:26 PM> Done writing partition. Write speed: 1880.37 KB/s
8/11/2018 6:22:26 PM> Partition name: rpm
8/11/2018 6:22:26 PM> Filename: rpm.bin , Offset: 000000800000 , filesize: 524288 bytes
8/11/2018 6:22:26 PM> eMMC switching to ROM1
8/11/2018 6:22:26 PM> Erasing partition...
8/11/2018 6:22:26 PM> Writing partition...
8/11/2018 6:22:26 PM> Done writing partition. Write speed: 3749.17 KB/s
8/11/2018 6:22:26 PM> Partition name: tz
8/11/2018 6:22:26 PM> Filename: tz.bin , Offset: 000000880000 , filesize: 524288 bytes
8/11/2018 6:22:27 PM> Erasing partition...
8/11/2018 6:22:27 PM> Writing partition...
8/11/2018 6:22:27 PM> Done writing partition. Write speed: 3921.20 KB/s
8/11/2018 6:22:27 PM> Partition name: aboot
8/11/2018 6:22:27 PM> Filename: aboot.bin , Offset: 000000900000 , filesize: 5177344 bytes
8/11/2018 6:22:27 PM> eMMC switching to ROM1
8/11/2018 6:22:28 PM> Erasing partition...
8/11/2018 6:22:28 PM> Writing partition...
8/11/2018 6:22:29 PM> Done writing partition. Write speed: 4576.03 KB/s
8/11/2018 6:22:29 PM> Partition name: pad
8/11/2018 6:22:29 PM> Filename: pad.bin , Offset: 000000DF0000 , filesize: 1048576 bytes
8/11/2018 6:22:29 PM> eMMC switching to ROM1
8/11/2018 6:22:30 PM> Erasing partition...
8/11/2018 6:22:30 PM> Writing partition...
8/11/2018 6:22:30 PM> Done writing partition. Write speed: 3741.66 KB/s
8/11/2018 6:22:30 PM> Partition name: oeminfo
8/11/2018 6:22:30 PM> Filename: oeminfo.bin , Offset: 000000EF0000 , filesize: 67108864 bytes
8/11/2018 6:22:30 PM> eMMC switching to ROM1
8/11/2018 6:22:31 PM> Erasing partition...
8/11/2018 6:22:31 PM> Writing partition...
8/11/2018 6:22:45 PM> Done writing partition. Write speed: 4722.43 KB/s
8/11/2018 6:22:45 PM> Partition name: modemst1
8/11/2018 6:22:45 PM> Filename: modemst1.bin , Offset: 000004EF0000 , filesize: 4194304 bytes
8/11/2018 6:22:45 PM> eMMC switching to ROM1
8/11/2018 6:22:45 PM> Erasing partition...
8/11/2018 6:22:46 PM> Writing partition...
8/11/2018 6:22:47 PM> Done writing partition. Write speed: 4581.12 KB/s
8/11/2018 6:22:47 PM> Partition name: modemst2
8/11/2018 6:22:47 PM> Filename: modemst2.bin , Offset: 0000052F0000 , filesize: 4194304 bytes
8/11/2018 6:22:47 PM> eMMC switching to ROM1
8/11/2018 6:22:47 PM> Erasing partition...
8/11/2018 6:22:48 PM> Writing partition...
8/11/2018 6:22:49 PM> Done writing partition. Write speed: 4386.86 KB/s
8/11/2018 6:22:49 PM> Partition name: modem
8/11/2018 6:22:49 PM> Filename: modem.bin , Offset: 000005800000 , filesize: 100663296 bytes
8/11/2018 6:22:49 PM> eMMC switching to ROM1
8/11/2018 6:22:49 PM> Erasing partition...
8/11/2018 6:22:50 PM> Writing partition...
8/11/2018 6:23:10 PM> Done writing partition. Write speed: 4741.71 KB/s
8/11/2018 6:23:10 PM> Partition name: fsg
8/11/2018 6:23:10 PM> Filename: fsg.bin , Offset: 00000B800000 , filesize: 4194304 bytes
8/11/2018 6:23:10 PM> eMMC switching to ROM1
8/11/2018 6:23:11 PM> Erasing partition...
8/11/2018 6:23:11 PM> Writing partition...
8/11/2018 6:23:12 PM> Done writing partition. Write speed: 4443.03 KB/s
8/11/2018 6:23:12 PM> Partition name: fsc
8/11/2018 6:23:12 PM> Filename: fsc.bin , Offset: 00000BC00000 , filesize: 2097152 bytes
8/11/2018 6:23:12 PM> eMMC switching to ROM1
8/11/2018 6:23:12 PM> Erasing partition...
8/11/2018 6:23:13 PM> Writing partition...
8/11/2018 6:23:13 PM> Done writing partition. Write speed: 4366.30 KB/s
8/11/2018 6:23:13 PM> Partition name: ssd
8/11/2018 6:23:13 PM> Filename: ssd.bin , Offset: 00000BE00000 , filesize: 2097152 bytes
8/11/2018 6:23:13 PM> eMMC switching to ROM1
8/11/2018 6:23:14 PM> Erasing partition...
8/11/2018 6:23:14 PM> Writing partition...
8/11/2018 6:23:15 PM> Done writing partition. Write speed: 4196.22 KB/s
8/11/2018 6:23:15 PM> Partition name: log
8/11/2018 6:23:15 PM> Filename: log.bin , Offset: 00000C000000 , filesize: 67108864 bytes
8/11/2018 6:23:15 PM> eMMC switching to ROM1
8/11/2018 6:23:15 PM> Erasing partition...
8/11/2018 6:23:16 PM> Writing partition...
8/11/2018 6:23:29 PM> Done writing partition. Write speed: 4730.22 KB/s
8/11/2018 6:23:29 PM> Partition name: persist
8/11/2018 6:23:30 PM> Filename: persist.bin , Offset: 000010000000 , filesize: 33554432 bytes
8/11/2018 6:23:30 PM> eMMC switching to ROM1
8/11/2018 6:23:30 PM> Erasing partition...
8/11/2018 6:23:30 PM> Writing partition...
8/11/2018 6:23:37 PM> Done writing partition. Write speed: 4679.62 KB/s
8/11/2018 6:23:37 PM> Partition name: boot
8/11/2018 6:23:37 PM> Filename: boot.bin , Offset: 000012000000 , filesize: 20971520 bytes
8/11/2018 6:23:37 PM> eMMC switching to ROM1
8/11/2018 6:23:38 PM> Erasing partition...
8/11/2018 6:23:39 PM> Writing partition...
8/11/2018 6:23:43 PM> Done writing partition. Write speed: 4710.29 KB/s
8/11/2018 6:23:43 PM> Partition name: recovery
8/11/2018 6:23:43 PM> Filename: recovery.bin , Offset: 000013400000 , filesize: 25165824 bytes
8/11/2018 6:23:43 PM> eMMC switching to ROM1
8/11/2018 6:23:43 PM> Erasing partition...
8/11/2018 6:23:44 PM> Writing partition...
8/11/2018 6:23:49 PM> Done writing partition. Write speed: 4704.06 KB/s
8/11/2018 6:23:49 PM> Partition name: cust
8/11/2018 6:23:49 PM> Filename: cust.bin , Offset: 000014C00000 , filesize: 268435456 bytes
8/11/2018 6:23:49 PM> eMMC switching to ROM1
8/11/2018 6:23:49 PM> Erasing partition...
8/11/2018 6:23:51 PM> Writing partition...
8/11/2018 6:24:46 PM> Done writing partition. Write speed: 4728.37 KB/s
8/11/2018 6:24:46 PM> Partition name: cache
8/11/2018 6:24:46 PM> Filename: cache.bin , Offset: 000024C00000 , filesize: 201326592 bytes
8/11/2018 6:24:46 PM> eMMC switching to ROM1
8/11/2018 6:24:46 PM> Erasing partition...
8/11/2018 6:24:48 PM> Writing partition...
8/11/2018 6:25:30 PM> Done writing partition. Write speed: 4723.04 KB/s
8/11/2018 6:25:30 PM> Partition name: misc
8/11/2018 6:25:30 PM> Filename: misc.bin , Offset: 000030C00000 , filesize: 4194304 bytes
8/11/2018 6:25:30 PM> eMMC switching to ROM1
8/11/2018 6:25:30 PM> Erasing partition...
8/11/2018 6:25:31 PM> Writing partition...
8/11/2018 6:25:31 PM> Done writing partition. Write speed: 4403.25 KB/s
8/11/2018 6:25:32 PM> All done time: [00:03:09:639]
8/11/2018 6:25:55 PM> Looking for EasyJTAG box...
8/11/2018 6:25:55 PM> EasyJTAG API ver. 2022
8/11/2018 6:25:55 PM> Setting IO Levels to 2.8V
8/11/2018 6:25:55 PM> Setting frequence to 42 Mhz
8/11/2018 6:25:55 PM> EasyJTAG Box Serial =
8/11/2018 6:25:55 PM> EasyJTAG Box Firmware = 2.21
8/11/2018 6:25:56 PM> Setting interface to EasyJtag2/E-Socket
8/11/2018 6:25:56 PM> Setting bus width to 1 Bit
8/11/2018 6:25:56 PM> Setting frequence to 42 Mhz
8/11/2018 6:25:56 PM> eMMC Init returned = 0
8/11/2018 6:25:56 PM> EMMC Device Information :
8/11/2018 6:25:56 PM> EMMC CID: 90014A4838473165050724802E2142BF
8/11/2018 6:25:56 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3
8/11/2018 6:25:56 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: 24802E21 , rev. 0x07
8/11/2018 6:25:56 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2015
8/11/2018 6:25:56 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
8/11/2018 6:25:56 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
8/11/2018 6:25:56 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
8/11/2018 6:25:56 PM> EMMC Permanent Write Protection: No
8/11/2018 6:25:56 PM> EMMC Temporary Write Protection: No
8/11/2018 6:25:56 PM> Extended CSD Information :
8/11/2018 6:25:56 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
8/11/2018 6:25:56 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
8/11/2018 6:25:56 PM> Boot Bus Config: 0x00 , width 1bit
8/11/2018 6:25:56 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
8/11/2018 6:25:56 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
8/11/2018 6:25:56 PM> Device supports partitioning features
8/11/2018 6:25:56 PM> Device can have enhanced technological features in partitions and user data area
8/11/2018 6:25:56 PM> Device can have extended partitions attribute
8/11/2018 6:25:56 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
8/11/2018 6:25:56 PM> Backup saved: H8G1e_24802E21_20180811_182556.extcsd
8/11/2018 6:25:56 PM> EMMC Init completed.
8/11/2018 6:25:57 PM> Scanning soft partitions
8/11/2018 6:25:57 PM> GPT header is found and is valid
8/11/2018 6:25:57 PM> Partition: sbl1, [000000004400 - 000000084400], size: 000000080000
8/11/2018 6:25:57 PM> Partition: hyp, [000000084400 - 000000104400], size: 000000080000
8/11/2018 6:25:57 PM> Partition: sec, [000000400000 - 000000408000], size: 000000008000
8/11/2018 6:25:57 PM> Partition: DDR, [000000408000 - 000000410000], size: 000000008000
8/11/2018 6:25:57 PM> Partition: rpm, [000000800000 - 000000880000], size: 000000080000
8/11/2018 6:25:57 PM> Partition: tz, [000000880000 - 000000900000], size: 000000080000
8/11/2018 6:25:57 PM> Partition: aboot, [000000900000 - 000000DF0000], size: 0000004F0000
8/11/2018 6:25:57 PM> Partition: pad, [000000DF0000 - 000000EF0000], size: 000000100000
8/11/2018 6:25:57 PM> Partition: oeminfo, [000000EF0000 - 000004EF0000], size: 000004000000
8/11/2018 6:25:57 PM> Partition: modemst1, [000004EF0000 - 0000052F0000], size: 000000400000
8/11/2018 6:25:57 PM> Partition: modemst2, [0000052F0000 - 0000056F0000], size: 000000400000
8/11/2018 6:25:57 PM> Partition: modem, [000005800000 - 00000B800000], size: 000006000000
8/11/2018 6:25:57 PM> Partition: fsg, [00000B800000 - 00000BC00000], size: 000000400000
8/11/2018 6:25:57 PM> Partition: fsc, [00000BC00000 - 00000BE00000], size: 000000200000
8/11/2018 6:25:57 PM> Partition: ssd, [00000BE00000 - 00000C000000], size: 000000200000
8/11/2018 6:25:57 PM> Partition: log, [00000C000000 - 000010000000], size: 000004000000
8/11/2018 6:25:57 PM> Partition: persist, [000010000000 - 000012000000], size: 000002000000
8/11/2018 6:25:57 PM> Partition: boot, [000012000000 - 000013400000], size: 000001400000
8/11/2018 6:25:57 PM> Partition: recovery, [000013400000 - 000014C00000], size: 000001800000
8/11/2018 6:25:57 PM> Partition: cust, [000014C00000 - 000024C00000], size: 000010000000
8/11/2018 6:25:57 PM> Partition: cache, [000024C00000 - 000030C00000], size: 00000C000000
8/11/2018 6:25:57 PM> Partition: misc, [000030C00000 - 000031000000], size: 000000400000
8/11/2018 6:25:57 PM> Partition: system, [000031000000 - 000081000000], size: 000050000000
8/11/2018 6:25:57 PM> Partition: userdata, [000081000000 - 0001D1FFBE00], size: 000150FFBE00
8/11/2018 6:25:57 PM> GPT header successfully parsed
8/11/2018 6:25:57 PM> Get firmware version
8/11/2018 6:25:57 PM> Firmware info not found
The Following 2 Users Say Thank You to royalnasim For This Useful Post:
Old 08-11-2018, 16:29   #2 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 430
how did you repair "The device ID has been altered" after changing eMMC, i have this problem after eMMC change
Old 08-11-2018, 19:12   #3 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 377
Its not true
Can you see log and image I am all ready done
Old 08-12-2018, 04:00   #4 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 430
Originally Posted by royalnasim View Post
Its not true
i've done same thing but after you insert SIM, "The device ID has been altered" will display and there is no signal
Old 08-12-2018, 04:12   #5 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 430
Old 08-13-2018, 00:29   #6 (permalink)
Member: 1073402
Thanks Meter: 35
Repair imei and unlock
Old 08-13-2018, 04:01   #7 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 430
IMEI is OK i've back-up file from original eMMC
Old 01-06-2019, 10:50   #8 (permalink)
Member: 2438408
Thanks Meter: 364
you have this model dump file
you have this model dump file ???
Page generated in 0.41444 seconds with 7 queries
