05-23-2020, 13:47 | #1 (permalink) |
Junior Member Join Date: Aug 2013 Location: oman
Member: 1999097 Status: Offline Sonork: arshadn05 Thanks Meter: 1 | sm-j400f can't enter to download mode or recovery after boot repair with jtag plus Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 489 mV CMD Active Level: 1708 mV EMMC Device Information : EMMC CID: 150100514536334D42007F8FDA683557 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 7F8FDA68 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_7F8FDA68_20200523_115029.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking Lz4: cm.bin.lz4 Unpacking file: sboot.bin Unpacking Lz4: sboot.bin.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: boot.img Unpacking Lz4: boot.img.lz4 Unpacking file: recovery.img Unpacking Lz4: recovery.img.lz4 Unpacking file: modem.bin Unpacking file: system.img Unpacking Lz4: system.img.lz4 Unpacking file: vendor.img Unpacking Lz4: vendor.img.lz4 Unpacking file: odm.img Unpacking Lz4: odm.img.lz4 Unpacking file: cache.img Unpacking Lz4: cache.img.lz4 Unpacking file: userdata.img Unpacking Lz4: userdata.img.lz4 Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2183696 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 664.10 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1602064 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 628.11 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003500000 , filesize: 962560 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1064.01 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003D00000 , filesize: 18825760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2012.31 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005D00000 , filesize: 22489632 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1999.65 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008300000 , filesize: 34070768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2009.58 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000E800000 , filesize: 2408398332 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 3368 Done writing partition. Write speed: 1959.85 KB/s Partition name: VENDOR Filename: vendor.img , Offset: 0000AB000000 , filesize: 162195816 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 881 Done writing partition. Write speed: 1892.96 KB/s Partition name: ODM Filename: odm.img , Offset: 0000B7800000 , filesize: 138631364 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 526 Done writing partition. Write speed: 1928.14 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000CA800000 , filesize: 5800084 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 2008.60 KB/s Partition name: USERDATA Filename: userdata.img , Offset: 0000D9D00000 , filesize: 1400033548 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1044 Done writing partition. Write speed: 2004.81 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x01 Reg: 162 Value: 0x00 Done All done time: [00:43:38:912] |
