-   Easy-Jtag (http://forum.gsmhosting.com/vbb/f672/)
-   -   i8190 (512mb_OK_locked bin file write error) (http://forum.gsmhosting.com/vbb/f672/i8190-512mb_ok_locked-bin-file-write-error-1851432/)
riajul1988 08-24-2014 17:45
EasyJtag Suite ver.: 1.6.1.1 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
For support and updates visit http://easy-jtag.com
Check security...OK
Initialising: SAMSUNG GT-I8190 Config ver.:1.01
I/O Level set to : 2600 mV
Box S/N: 0404111A58FD0E5F ,FW Ver.: 01.50
Connecting to Target...
U8500 USB BOOTROM : device 04CC:8500 opened
success: set configuration #1
success: claim_interface #0
Sending XLOADER...
success: bulk read 4 bytes
Done.
JTAG device: U8500
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
JTAG device: U8500
CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6
CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks
EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks
eMMC flash device(s) found, Device ID : 0x00450000
You must select flash file first!
Checking NAND Image : I:\all setup\Easy-Jtag\i8190\512mb_OK_locked.bin
File successefuly loaded!
Writing memory from file...I:\all setup\Easy-Jtag\i8190\512mb_OK_locked.bin
Timeout Error while reading approx : 0x00000100 bytes over DCC
Unknown DCC answer /PROTOCOL/
Failed writing file I:/all setup/Easy-Jtag/i8190/512mb_OK_locked.bin to eMMC flash 0 at offset 0x1FB70000
Done with error(s)...
http://dc669.4shared.com/download/Rf....bmp?lgfp=1000
riajul1988 08-24-2014 17:53
odin error
<ID:0/118> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> I8190XXALJL_I8190OJVALJ9_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/118> Odin v.3 engine (ID:118)..
<ID:0/118> File analysis..
<ID:0/118> SetupConnection..
<ID:0/118> Initialzation..
<ID:0/118> Get PIT for mapping..
<ID:0/118>
<ID:0/118> There is no PIT partition.
<OSM> All threads completed. (succeed 0 / failed 1)
<ID:0/118> Removed!!
Mansour Pakdel 08-25-2014 06:43
Originally Posted by riajul1988 (Post 10515005)
odin error
<ID:0/118> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/118>
try to use Odin_v3.07 and post result
blang 08-26-2014 00:42
looks like bad EMMC , don't want accept write command.
if you have working emmc you can solder into pcb and check.
and you will have 100% answer where the problem.
Page generated in 0.29072 seconds with 5 queries
