08-24-2014, 16:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | i8190 (512mb_OK_locked bin file write error) Operating system ver.: Windows 7 (build 7601, Service Pack 1). For support and updates visit http://easy-jtag.com Check security...OK Initialising: SAMSUNG GT-I8190 Config ver.:1.01 I/O Level set to : 2600 mV Box S/N: 0404111A58FD0E5F ,FW Ver.: 01.50 Connecting to Target... U8500 USB BOOTROM : device 04CC:8500 opened success: set configuration #1 success: claim_interface #0 Sending XLOADER... success: bulk read 4 bytes Done. JTAG device: U8500 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 JTAG device: U8500 CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6 CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00450000 You must select flash file first! Checking NAND Image : I:\all setup\Easy-Jtag\i8190\512mb_OK_locked.bin File successefuly loaded! Writing memory from file...I:\all setup\Easy-Jtag\i8190\512mb_OK_locked.bin Timeout Error while reading approx : 0x00000100 bytes over DCC Unknown DCC answer /PROTOCOL/ Failed writing file I:/all setup/Easy-Jtag/i8190/512mb_OK_locked.bin to eMMC flash 0 at offset 0x1FB70000 Done with error(s)... |
08-24-2014, 16:53 | #2 (permalink) |
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | odin error <ID:0/118> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I8190XXALJL_I8190OJVALJ9_HOME.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/118> Odin v.3 engine (ID:118).. <ID:0/118> File analysis.. <ID:0/118> SetupConnection.. <ID:0/118> Initialzation.. <ID:0/118> Get PIT for mapping.. <ID:0/118> <ID:0/118> There is no PIT partition. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/118> Removed!! |
08-25-2014, 05:43 | #3 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2186335 Status: Offline Thanks Meter: 44 | Quote:
08-25-2014, 23:42 | #4 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | looks like bad EMMC , don't want accept write command. if you have working emmc you can solder into pcb and check. and you will have 100% answer where the problem. |
