11-15-2016, 10:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | I8190 EMMC SANDISK cant write data. Code: EasyJtag Suite Classic ver.: 2.4.1.1 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 8 (build 9200), 64-bit edition. undefined Android Explorer ver.: 1.0.0.11 eMMC ODIN ver.: 1.0.11.11 Successfully connected to box on COM80 Box S/N: *************, ,FW Ver.: 01.55 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : ********** , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.4.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0101200521EF0684, ,FW Ver.: 01.55 CMD Pullup Level:2083 mV CMD Active Level:2340 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 45010053454D30384790201EE67BAFE8 EMMC CSD : D00F00320F5903FFFFFFFFFF92404010 EMMC Manufacturer ID: 0045 , OEM ID: 0100 EMMC Date: 10/2012 Rev.0x90 EMMC NAME: SEM08G , S/N: 538895995 EMMC NAME (HEX): 53454D30384700 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SEM08G_ 538895995_20161115_1214.extcsd ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x22] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x22] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x96] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x96] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x08] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x04] Sleep current (VCC) [S_C_VCC: 0x08] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00e90000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x0a] [MIN_PERF_R_8_52: 0x0a] [MIN_PERF_W_8_26_4_52: 0x0a] [MIN_PERF_R_8_26_4_52: 0x0a] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x0a] [MIN_PERF_R_4_26: 0x0a] Power classes registers: [PWR_CL_26_360: 0x22] [PWR_CL_52_360: 0x22] [PWR_CL_26_195: 0x22] [PWR_CL_52_195: 0x22] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x02] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x01 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x04 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e6 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (MBR,GPT) Range: [0,0X1FE00] ,Len: 20000 MMCBLK0P1 (MASTERTOC) Range: [0X20000,0X7FE00] ,Len: 60000 MMCBLK0P2 (PIT) Range: [0X80000,0X17FE00] ,Len: 100000 MMCBLK0P3 (MD5HDR) Range: [0X300000,0X3FFE00] ,Len: 100000 MMCBLK0P4 (STEBOOT1) Range: [0X400000,0X47FE00] ,Len: 80000 MMCBLK0P5 (STEBOOT2) Range: [0X480000,0X4FFE00] ,Len: 80000 MMCBLK0P6 (DNT) Range: [0X500000,0X57FE00] ,Len: 80000 MMCBLK0P7 (RESERVED) Range: [0X580000,0X5FFE00] ,Len: 80000 MMCBLK0P8 (CSPSAFS) Range: [0X800000,0X8FFE00] ,Len: 100000 MMCBLK0P9 (CSPSAFS2) Range: [0X900000,0X9FFE00] ,Len: 100000 MMCBLK0P10 (EFS) Range: [0XA00000,0X19FFE00] ,Len: 1000000 MMCBLK0P11 (MODEMFS) Range: [0X1A00000,0X29FFE00] ,Len: 1000000 MMCBLK0P12 (MODEMFS2) Range: [0X2A00000,0X39FFE00] ,Len: 1000000 MMCBLK0P13 (FOTA) Range: [0X3A00000,0X6BFFE00] ,Len: 3200000 MMCBLK0P14 (IPL MODEM) Range: [0XBA00000,0XBA0FE00] ,Len: 10000 MMCBLK0P15 (MODEM) Range: [0XBC00000,0XC9FFE00] ,Len: E00000 MMCBLK0P16 (LOKE4) Range: [0XCC00000,0XCDFFE00] ,Len: 200000 MMCBLK0P17 (2NDLOKE4) Range: [0XCE00000,0XCFFFE00] ,Len: 200000 MMCBLK0P18 (PARAM) Range: [0XD000000,0XDFFFE00] ,Len: 1000000 MMCBLK0P19 (KERNEL) Range: [0XE000000,0XEFFFE00] ,Len: 1000000 MMCBLK0P20 (KERNEL2) Range: [0XF000000,0XFFFFE00] ,Len: 1000000 MMCBLK0P21 (SYSTEM) Range: [0X10000000,0X5AFFFE00] ,Len: 4B000000 MMCBLK0P22 (CACHEFS) Range: [0X5B000000,0X8F7FFE00] ,Len: 34800000 MMCBLK0P23 (HIDDEN) Range: [0X8F800000,0XA37FFE00] ,Len: 14000000 MMCBLK0P24 (DATAFS) Range: [0XA3800000,0X1D15FFE00] ,Len: 12DE00000 Done...Presets has been updated... Done. Checking NAND Image : C:\Users\Akira\Desktop\8190\512mb_OK_locked.bin File successefuly loaded! Processing file...C:\Users\Akira\Desktop\8190\512mb_OK_locked.bin Z3X EasyJtag Software ver. 2.4.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2340 mV Input file : C:\Users\Akira\Desktop\8190\512mb_OK_locked.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Full Verify Enabled! Verify Block Failed , block #0x00001800 Verify Block Failed , block #0x00001E00 Verify Block Failed , block #0x00002000 Verify Block Failed , block #0x00002200 Verify Block Failed , block #0x00002400 Verify Block Failed , block #0x00002600 Verify Block Failed , block #0x00004000 Verify Block Failed , block #0x00004600 Verify Block Failed , block #0x00005000 Verify Block Failed , block #0x00005200 Verify Block Failed , block #0x00005400 Verify Block Failed , block #0x00005600 Verify Block Failed , block #0x00005800 Verify Block Failed , block #0x00005A00 Verify Block Failed , block #0x00005C00 Verify Block Failed , block #0x00005E00 Verify Block Failed , block #0x00006000 Verify Block Failed , block #0x00006200 Verify Block Failed , block #0x00006400 Writing flash page stopped by user request Done. |
