09-02-2013, 16:57 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | I9003 Boot Repair Done !! I9003 Boot Repair Done Hardware Connection : Solder TRST, TDI, TMS, TCK, TDO, SRST, GND Lines from Box port to phone PCB carefully. Insert phone battery and press Power On key after pressing "Connect Device" or "Run Easy Repair" software button, while progress bar is active. Hold phone Power On key during initial connection. In most cases insert Samsung GT-I9003 SD Boot Card in to phone's SD slot before resurection (SD Boot Card Image and Disk Image Tool can be downloaded from support) If everything soldered ok , phone is ready for JTAG operations. . Flashing Phone Firmware after boot repair : Press VOL DOWN + HOME + POWER for flash mode Use capable flasher software for firmware restore. BR, Dicle_Gsm |
The Following 4 Users Say Thank You to dicle_gsm For This Useful Post: |
09-03-2013, 07:10 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2012 Location: Arsh CellPhones Solutions Age: 29
Member: 1727681 Status: Offline Sonork: 100.1624662 Thanks Meter: 59 | Thanks Dicle GSM ......... For Test Reporting Z3x is Always Ahead....... Always Z3x is Giving Best Solution for Our User... Thanks Br. _-=KANPURGSM=-_ Last edited by _-=KANPURGSM=-_; 09-03-2013 at 07:16. |
