12-02-2015, 11:36 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2452660 Status: Offline Thanks Meter: 22 | I9060 boot repair done but no download mode Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0D01501BFF72D50C, ,FW Ver.: 01.52 Warning: CMD Pullup Level (268 mV) too low , check cables etc.! CMD Active Level:1103 mV Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 2.0.6.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0D01501BFF72D50C, ,FW Ver.: 01.52 CMD Pullup Level:2083 mV CMD Active Level:2413 mV eMMC Device Information EMMC CID : 1501004B375530304D0861EA70B180FA EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2013 Rev.0x8 EMMC NAME: K7U00M , S/N: 1642754225 EMMC NAME (HEX): 4B375530304D00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: K7U00M_1642754225_20151103_1511.extcsd Done. Z3X EasyJtag Software ver. 2.0.6.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0D01501BFF72D50C, ,FW Ver.: 01.52 CMD Pullup Level:2083 mV CMD Active Level:2402 mV eMMC Device Information EMMC CID : 1501004B375530304D0861EA70B180FA EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2013 Rev.0x8 EMMC NAME: K7U00M , S/N: 1642754225 EMMC NAME (HEX): 4B375530304D00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: K7U00M_1642754225_20151103_1511.extcsd Done. Checking NAND Image : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM1_00000000_20000000 .bin File successefuly loaded! Found ROM2 and automatically selected. Found EXT CSD and automatically selected. Checking NAND Image : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM2_00000000_00400000 .bin File successefuly loaded! Found EXT CSD and automatically selected. Checking NAND Image : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\K7XVMB_ 892425646_20150302_1442.extcsd File successefuly loaded! Found ROM2 and automatically selected. Found ROM1 and automatically selected. Processing file...D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM1_00000000_20000000 .bin Processing file...D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM2_00000000_00400000 .bin ROM3 Are not selected , skip writing ROM2 Processing file...D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\K7XVMB_ 892425646_20150302_1442.extcsd Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2402 mV Input file : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM1_00000000_20000000 .bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 2572 kB/s Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2402 mV Input file : D:\Easy Jtag\I9060\SAMSUNG_GT-I9060_emmc_direct_dump\EMMC_ROM2_00000000_00400000 .bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 896 kB/s Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2402 mV Writing... Done. |
12-04-2015, 15:49 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | Try to jack if download load mode not come and blue or black screen then insert usb cable and checked with Odin if detected then just flash even if download mod not showing but you can do flash the phone ... |
12-06-2015, 09:33 | #6 (permalink) | |
Member: 2452660 Status: Offline Thanks Meter: 22 | Quote:
BR | |
12-30-2017, 15:12 | #10 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1532909 Status: Offline Thanks Meter: 6 | Not work: EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Work: EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB And just write boot1,2,3 dumps Last edited by Typapbek; 12-30-2017 at 15:20. |
