12-18-2013, 15:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | i9070 u8500 usb drivers problem Please, install U8500 USB ROM driver, check power and USB connection !!! Done with error(s)... Last edited by \/\/imran; 12-18-2013 at 15:15. |
The Following User Says Thank You to \/\/imran For This Useful Post: |
12-18-2013, 15:34 | #2 (permalink) |
Banned Join Date: Apr 2008
Member: 762819 Status: Offline Thanks Meter: 232 | Dear. first things is to use fully charged battery, and then u can install U8500 drivers easily from JTAG folder. |
The Following User Says Thank You to farhannyb For This Useful Post: |
12-18-2013, 17:09 | #4 (permalink) |
Member: 762819 Status: Offline Thanks Meter: 232 | Dear, not by this way. just plug usb cable to ur phone when it asks for driver, manually select the location. When the driver is successfully installed then u r ready Jtag operation. |
12-19-2013, 05:29 | #5 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Bahawal Nagar
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | Blang Aanswerd about this problem i9070,i9070p,i8160,i8160p can be connected only after installed MCU usb driver. from your log i see you use custom config pinout. Are you sure you connected all pins correct? If you connect any pin wrong - you cant detect phone, usb device also cant be detected. If you not know how use pinfinder or how setup correct pinout - best way: 1. use standart pinout from manual, use default pinout settings in finder. 2. usb cable should be connected to pc. 3. after press connect or oneclick repair - after 1-2sec and pc will detect new device. 4. install drivers from u8500 folder. 5. if connecting losed, repeat again. If you cant repair - check your steps - you doing something wrong. If you have plastic gpg made box - please check this thread http://forum.gsmhosting.com/vbb/f672...odify-1691534/. In early boxes GND not solded correctly. need fix manualy. |
The Following User Says Thank You to gulzarjan For This Useful Post: |
12-19-2013, 05:42 | #6 (permalink) | |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Quote:
USB drivers to repair I9070 you have to manual install these drives for boot repair http://www.mediafire.com/download/cn...737f/U8500.zip if drivers installed perfectly then in device manager your phone will be shown like this ( libusb0 ) in modem then you will be able to repair it | |
The Following User Says Thank You to unlock phones For This Useful Post: |
12-19-2013, 11:05 | #7 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | easy jtag is sure solution of i9070 dead boot,try and post results |
The Following User Says Thank You to KE6SOLTI For This Useful Post: |
01-25-2014, 16:52 | #8 (permalink) |
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | i9070 again error u8500 drivers how i solve it ? here is pin find out log Start Z3X Jtag Pin Finder... Successefuly connected to box on COM120 Waiting for box reset... Box S/N: xxxxxxxxxxxxxxxxxxx Box Working Mode: JTAG Pin Finder. Start Z3X Jtag Pin Finder... Stage 1: Search TCK / TMS / TDI / TDO... Get IDCODE... JTAG Pinout Found: TCK: Pin 9 / TMS: Pin 7 / TDI: Pin 5 / TDO: Pin 13 CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6 CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC Stage 2: Search TRST... TRST Pin Found: TRST: Pin 4 Box S/N: xxxxxxxxxxxxxx, ,FW Ver.: 01.48 Box Working Mode: JTAG Box. here is repair log Warning , you are using custom pinout config make shure that NRST and GND on proper places! Checking repair data... EasyJtag Suite ver.: 1.0.99.0 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device. Initialising: SAMSUNG GT-I9070 Config ver.:1.01 I/O Level set to : 2600 mV Box S/N: xxxxxxxxxxxxxxxxx ,FW Ver.: 01.48 Connecting to Target... U8500 Connection Fail Please, install U8500 USB ROM driver, check power and USB connection !!! U8500 Connection Fail Please, install U8500 USB ROM driver, check power and USB connection !!! Done with error(s)... Where is problem ? |
01-25-2014, 17:09 | #9 (permalink) |
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | How to install u8500 usb drivers manually ? when i attach usb cable then not ask me u8500 driver install |
01-25-2014, 17:14 | #10 (permalink) |
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | I think its drivers problem , i am use window xp3.... Can i repair i9070 in sp3? |
01-29-2014, 12:43 | #13 (permalink) |
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | problem solve after install drivers (dpinst_x86) (C:\Program Files\Z3X\EASYJTAG\Drivers\NTU8500\dpinst_x86) boot repaired successfully and flash done. Drivers will work only window 7.... Not work win xp and sp3 |
08-18-2014, 16:23 | #14 (permalink) | |
Major Poster Join Date: Dec 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 410491 Status: Offline Thanks Meter: 7 | Quote:
This driver only work for u8500 driver This driver is signed and easy to inistall windows xp and seven away. just.... Last edited by nastaran662; 08-18-2014 at 16:29. | |
The Following 2 Users Say Thank You to nastaran662 For This Useful Post: |
04-27-2016, 10:21 | #15 (permalink) |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 2.0.8.1 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows XP (build 2600, Service Pack 3, v.3 For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: SAMSUNG GT-I8190 Config ver.:1.01 I/O Level set to : 2600 mV Box S/N:************,FW Ver.: 01.52 Connecting to Target... U8500 USB BOOTROM : device 04CC:8500 opened success: set configuration #1 success: claim_interface #0 Sending XLOADER... success: bulk read 4 bytes Done. U8500 USB BOOTROM : device 04CC:8500 opened success: set configuration #1 success: claim_interface #0 Sending XLOADER... success: bulk read 4 bytes Done. Done with error(s)... what is this?????????? |
