07-11-2014, 04:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: lebanon Age: 39
Member: 175671 Status: Offline Thanks Meter: 40 | i9082 jtag problem i already done rom2 by direct emmc , but failed to write rcp file by jtag Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 1.5.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7600). For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. - EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: SAMSUNG GT-I9082 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: xxxxxxxxxxxxxxx ,FW Ver.: 01.50 Connecting to Target... JTAG device: BCM28155 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x01000015 Name : AF2G8M Size : 7.2 G , (15106048) Blocks EMMC #1 : ID : 0x01000000 Name : AF2G8M Size : 512.0 K , (1024) Blocks eMMC flash device(s) found, Device ID : 0x00150000 NAND Writing BOOT, PIT, MD5... Failed writing file GPT.BIN to eMMC flash 0 at offset 0x00000000 NAND Writing CAL... Failed writing file CAL.BIN to eMMC flash 0 at offset 0x00E00000 NAND Writing SYSPARAM... Failed writing file SYSPARM.BIN to eMMC flash 0 at offset 0x00F00000 NAND Writing PARM_SPML... Failed writing file PARM_SPML.BIN to eMMC flash 0 at offset 0x00F40000 NAND Writing RF_CAL... Failed writing file RF_CAL.BIN to eMMC flash 0 at offset 0x00F80000 NAND Writing SBL1... Failed writing file SBL1.BIN to eMMC flash 0 at offset 0x05240000 NAND Writing PARAM... Failed writing file PARAM.BIN to eMMC flash 0 at offset 0x05640000 NAND Writing DTS... Failed writing file DTS.BIN to eMMC flash 0 at offset 0x05EC0000 All Done. |
07-11-2014, 07:43 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
or may be EMMC bad. | |
07-12-2014, 13:29 | #4 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Dharmapuri,Tamilnadu
Member: 1343981 Status: Offline Thanks Meter: 30 | tey with below steps just type on ur screen *#87976633# its now automatically restarted ur device incase device not restarted Go Nd See nd Solution > Againu Type On Ur DialPad *#87976633# u can restart ur mobile manually it will be removed frm ur screen |
