10-29-2018, 11:22 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i9100g android 4 cant remove pin lock cant delete export or decode gesture file not work on plus version cant remove pin lock or work with any code ----------- Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.2.0.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 1201401CBB19DC97, ,FW Ver.: 01.63 CMD Pullup Level:1113 mV CMD Active Level:1773 mV Box IO Level:3300 mV CLK Rate:21000 kHz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010056594C30304D19F14845CE9EBA EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2011 Rev.0x19 EMMC NAME: VYL00M , S/N: 4048045518 EMMC NAME (HEX): 56594C30304D EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59F9A sectors 14.7 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 30777276 Partition info successfully found ------ Android information ------ --------------------------------------------- Done. |
10-30-2018, 14:38 | #3 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | 28/10/2018 20:26:55> Brand = samsung 28/10/2018 20:26:55> Manufacturer = samsung 28/10/2018 20:26:55> Model = GT-I9100G 28/10/2018 20:26:55> Phone platform = omap4 28/10/2018 20:26:55> CPU Abi = armeabi-v7a 28/10/2018 20:26:55> Android release = 4.0.3 28/10/2018 20:26:55> Firmware version = IML74K.JPLP6 28/10/2018 20:26:55> Firmware date = Tue May 29 21:55:24 KST 2012 28/10/2018 20:27:07> 28/10/2018 20:27:07> Looking for EasyJTAG box... 28/10/2018 20:27:07> EasyJTAG API ver. 2100 28/10/2018 20:27:07> Setting IO Levels to 3.3V 28/10/2018 20:27:07> Setting frequence to 21 Mhz 28/10/2018 20:27:07> EasyJTAG Box Serial = 1201401CBB19DC97 28/10/2018 20:27:07> EasyJTAG Box Firmware = 1.63 28/10/2018 20:27:08> Setting frequence to 21 Mhz 28/10/2018 20:27:08> CMD Pullup Level: 1103 mV 28/10/2018 20:27:08> CMD Active Level: 1773 mV 28/10/2018 20:27:09> eMMC Init returned = 0 28/10/2018 20:27:09> EMMC Device Information : 28/10/2018 20:27:09> EMMC CID: 15010056594C30304D19F14845CE9EBA 28/10/2018 20:27:09> EMMC CSD: D02701320F5903FFF6DBFFEF8A404066 28/10/2018 20:27:09> EMMC Manufacture : SAMSUNG , EMMC NAME: VYL00M , HEX: 56594C30304D , S/N: F14845CE , rev. 0x19 28/10/2018 20:27:09> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2011 28/10/2018 20:27:09> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 28/10/2018 20:27:09> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 512 KB (000000080000) 28/10/2018 20:27:09> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) 28/10/2018 20:27:09> EMMC Permanent Write Protection: No 28/10/2018 20:27:09> EMMC Temporary Write Protection: No 28/10/2018 20:27:09> EMMC BootArea Write Protection: No 28/10/2018 20:27:09> Extended CSD Information : 28/10/2018 20:27:09> Extended CSD rev: 1.5 (MMC 4.41) 28/10/2018 20:27:09> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 28/10/2018 20:27:09> Boot Bus Config: 0x01 , width 4bit 28/10/2018 20:27:09> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 28/10/2018 20:27:09> Supported partition features [PARTITIONING_SUPPORT]: 0x03 28/10/2018 20:27:09> Device supports partitioning features 28/10/2018 20:27:09> Device can have enhanced technological features in partitions and user data area 28/10/2018 20:27:09> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 28/10/2018 20:27:09> Backup saved: VYL00M_F14845CE_20181028_202709.extcsd 28/10/2018 20:27:09> EMMC Init completed. 28/10/2018 20:27:09> 28/10/2018 20:27:09> Scan from: VYL00M 28/10/2018 20:27:09> 28/10/2018 20:27:09> Vendor: Samsung 28/10/2018 20:27:09> Searching GPT ... 28/10/2018 20:27:09> GPT header is found and is valid 28/10/2018 20:27:09> 28/10/2018 20:27:10> GPT header successfully parsed 28/10/2018 20:27:10> 28/10/2018 20:27:10> Scan done 28/10/2018 20:27:10> 28/10/2018 20:27:10> Mount [efs] successfully PartType: LINUX 28/10/2018 20:27:10> Mount [cache] successfully PartType: LINUX 28/10/2018 20:27:10> Mount [system] successfully PartType: LINUX 28/10/2018 20:27:10> Mount [data] successfully PartType: LINUX 28/10/2018 20:27:10> Mount [UMS] successfully PartType: FAT32 28/10/2018 20:27:10> Mount [HIDDEN] successfully PartType: LINUX 28/10/2018 20:27:10> 28/10/2018 20:29:34> Decode gesture.key 28/10/2018 20:29:34> 28/10/2018 20:29:34> Error: This is an incorrect file 28/10/2018 20:29:34> 28/10/2018 20:30:16> Decode gesture.key 28/10/2018 20:30:16> 28/10/2018 20:30:16> Error: This is an incorrect file 28/10/2018 20:30:16> 28/10/2018 20:30:37> Decode gesture.key 28/10/2018 20:30:37> 28/10/2018 20:30:37> Error: This is an incorrect file ========================================= |
11-02-2018, 18:08 | #8 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | one more not work =========== Brand = samsung Manufacturer = samsung Model = GT-N7100 Phone platform = exynos4 CPU Abi = armeabi-v7a Android release = 4.4.2 Firmware version = KOT49H.N7100XXUFNL1 Firmware date = Fri Dec 12 20:24:13 KST 2014 Setting frequence to 21 Mhz CMD Pullup Level: 2072 mV CMD Active Level: 2268 mV EMMC Device Information : EMMC CID: 15010056545530304DF77155171111C8 EMMC CSD: D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacture : SAMSUNG , EMMC NAME: VTU00M , HEX: 56545530304D , S/N: 71551711 , rev. 0xF7 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: Yes Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: VTU00M_71551711_20181102_195509.extcsd EMMC Init completed. Scan from: VTU00M Vendor: Samsung Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [efs] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [system] successfully PartType: LINUX Mount [preload] successfully PartType: LINUX Mount [data] successfully PartType: LINUX Decode gesture.key Error: This is an incorrect file =========== https://mega.nz/#!ZBtRXSSD!lRxmK9SsQ...AE5AAAAAAAAAAA ============ its export 0 kb size |
11-02-2018, 18:27 | #9 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
The Following User Says Thank You to layder For This Useful Post: |
