08-11-2014, 12:19 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Punjab Pakistan
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | I9100p unknown baseband Operating system ver.: Windows 7 (build 7601, Service Pack 1). Successefuly connected to box on COM41 Box S/N: 0808FD02>>>>>>>>, ,FW Ver.: 01.50 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA48-17F4 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Loading D:\Z3X\Jtag File\I9100\Samsung_GT-I9100_16gb_model_efs_v1_01.rcp Loading repair file: 'D:\Z3X\Jtag File\I9100\Samsung_GT-I9100_16gb_model_efs_v1_01.rcp' Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9100, Ver.: 1.00 Repair file options. : NONE Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 1.6.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). For support and updates visit http://easy-jtag.com Check security...OK Initialising: SAMSUNG GT-I9100 Config ver.:1.00 I/O Level set to : 2800 mV Box S/N: 0808FD02B5471585 ,FW Ver.: 01.50 Connecting to Target... JTAG device: S5PC210 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Init target ... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 14.7 G , (30777344) Blocks EMMC #1 : ID : 0x00010000 Name : VYL00M Size : 512.0 K , (1024) Blocks eMMC flash device(s) found, Device ID : 0x00150001 NAND Writing EFS... Timeout Error while reading approx : 0x00000100 bytes over DCC Unknown DCC answer /PROTOCOL/ Failed writing file EFS.BIN to eMMC flash 0 at offset 0x00400000 |
The Following User Says Thank You to gsmkiller173 For This Useful Post: |
08-12-2014, 10:03 | #2 (permalink) |
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | EasyJtag Suite ver.: 1.6.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. - EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: SAMSUNG GT-I9100 Config ver.:1.00 I/O Level set to : 2800 mV Box S/N: 0808FD02\........ ,FW Ver.: 01.50 Connecting to Target... JTAG device: S5PC210 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Init target ... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 14.7 G , (30777344) Blocks EMMC #1 : ID : 0x00010000 Name : VYL00M Size : 512.0 K , (1024) Blocks eMMC flash device(s) found, Device ID : 0x00150001 ------------------------------------------------------ Executing: C:\Program Files\Z3X\EASYJTAG\Scripts\Show_Partitions_EMMC_GP T.txt Searching for partition tables... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B MMCBLK0P0 (EFS) Range: [0X400000,0X17FFE00] ,Len: 1400000 MMCBLK0P1 (SBL1) Range: [0X1800000,0X193FE00] ,Len: 140000 MMCBLK0P2 (SBL2) Range: [0X1A00000,0X1B3FE00] ,Len: 140000 MMCBLK0P3 (PARAM) Range: [0X1C00000,0X23FFE00] ,Len: 800000 MMCBLK0P4 (KERNEL) Range: [0X2400000,0X2BFFE00] ,Len: 800000 MMCBLK0P5 (RECOVERY) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P6 (CACHE) Range: [0X3400000,0X97FFE00] ,Len: 6400000 MMCBLK0P7 (MODEM) Range: [0X9800000,0XA7FFE00] ,Len: 1000000 MMCBLK0P8 (FACTORYFS) Range: [0XA800000,0X2A7FFE00] ,Len: 20000000 MMCBLK0P9 (DATAFS) Range: [0X2A800000,0XAA7FFE00] ,Len: 80000000 MMCBLK0P10 (UMS) Range: [0XAA800000,0X38AFFFE00] ,Len: 2E0800000 MMCBLK0P11 (HIDDEN) Range: [0X38B000000,0X3AAFFFE00] ,Len: 20000000 Created helper script 'dump_gpt_partitions.txt' for dumping all regions in device Created helper script 'write_gpt_partitions.txt' for writing all regions in device Presets list on main window has been updated! OK Reading dump to file...C:\Users\imran\Desktop\SAMSUNG_GT-I9100_0x00400000_0x01400000.bin Reading 0x000001400000 bytes from emmc adress 0x000000400000 Dumped 20971520 bytes in 31.370279s (652.847 KiB/s) OK. Checking NAND Image : C:\Users\imran\Desktop\I9100 Good EFS\efs.bin File successefuly loaded! Writing memory from file...C:\Users\imran\Desktop\I9100 Good EFS\efs.bin eMMC Write OK! Elapsed time: 183.299408s (111.730 KiB/s) |
08-12-2014, 13:13 | #3 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Pakistan
Member: 1771086 Status: Offline Thanks Meter: 2,410 | try full flashing 100% ok your problem .................... if problem same then try flashing downgrade v |
The Following 2 Users Say Thank You to fahad ali khan For This Useful Post: |
08-12-2014, 13:34 | #4 (permalink) |
Member: 1771086 Status: Offline Thanks Meter: 2,410 | How Repair "EFS" "Null Imei" "Unknown BaseBand" "Low Signal" And All Related To EFS Guide: 1-Select "Speed" 2-Select "I9100" Model 3-Set "Start Address" "Data Length" Start Address : "0x0000 0040 0000" Lentgh : "0X0000 0140 0000" 4-Uncheck 3 option...Select "Rom1" 5-Open "I9100_EFS.bin" in "Main" Window 6-Select "Use Adress as Offset xxxxxx" 7-Press "write" |
The Following 3 Users Say Thank You to fahad ali khan For This Useful Post: |
08-13-2014, 06:50 | #5 (permalink) | |
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | Quote:
Reading dump to file...C:\Users\imran\Desktop\SAMSUNG_GT-I9100_0x00400000_0x01400000.bin Reading 0x000001400000 bytes from emmc adress 0x000000400000 Dumped 20971520 bytes in 31.370279s (652.847 KiB/s) OK. Checking NAND Image : C:\Users\imran\Desktop\I9100 Good EFS\efs.bin File successefuly loaded! Writing memory from file...C:\Users\imran\Desktop\I9100 Good EFS\efs.bin eMMC Write OK! Elapsed time: 183.299408s (111.730 KiB/s) | |
08-13-2014, 10:01 | #6 (permalink) |
Member: 1771086 Status: Offline Thanks Meter: 2,410 | Quote: Originally Posted by fahad ali khan How Repair "EFS" "Null Imei" "Unknown BaseBand" "Low Signal" And All Related To EFS Guide: 1-Select "Speed" 2-Select "I9100" Model 3-Set "Start Address" "Data Length" Start Address : "0x0000 0040 0000" Lentgh : "0X0000 0140 0000[IMG]resource://skype_ff_extension-at-jetpack/skype_ff_extension/data/call_skype_logo.png[/IMG]0140 0000" 4-Uncheck 3 option...Select "Rom1" 5-Open "I9100_EFS.bin" in "Main" Window 6-Select "Use Adress as Offset xxxxxx" 7-Press "write" Reading dump to file...C:\Users\imran\Desktop\SAMSUNG_GT-I9100_0x00400000_0x01400000.bin Reading 0x000001400000 bytes from emmc adress 0x000000400000 Dumped 20971520 bytes in 31.370279s (652.847 KiB/s) OK. Checking NAND Image : C:\Users\imran\Desktop\I9100 Good EFS\efs.bin File successefuly loaded! Writing memory from file...C:\Users\imran\Desktop\I9100 Good EFS\efs.bin eMMC Write OK! Elapsed time: 183.299408s (111.730 KiB/s) if this parass complete after write Dump file ok then this problem hardwaer |
The Following User Says Thank You to fahad ali khan For This Useful Post: |
