08-20-2019, 12:13 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: bacoor cavite Age: 42
Member: 375209 Status: Offline Thanks Meter: 14 | i9195 s4 mini need guide Failed to load partition eMMC CID : 45010053454D303847902856705D91C1 eMMC CSD : D00F00320F5903FFFFFFFFFF92404011 eMMC Manufacturer ID: 0045 , OEM ID: 0100 eMMC Date: 09/2014 Rev.0x90 eMMC NAME: SEM08G , S/N: 676753501 eMMC NAME (HEX): 53454D303847 Possible eMMC NAME Mismatch Possible IC Name[0]: SanDisk , iNAND_SDIN7DU2-8G @FBGA153 Possible IC Name[1]: SanDisk , iNAND_SDIN8DE1-8G @FBGA153 Possible IC Name[2]: SanDisk , iNAND_SDIN8DE2-8G @FBGA153 Possible IC Name[3]: SanDisk , iNAND_SD5D26B-8G @FBGA162 Possible IC Name[4]: SanDisk , iNAND_SD5D28B-8G @FBGA162 Possible IC Name[5]: SanDisk , iNAND_SDIN7DP2-8G @FBGA153 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00008000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: SEM08G_ 676753501_20190820_1456.extcsd Partition table scan: GPT: not present Partition info not found Done. Selected eMMC Interface Failed to load partition done do this 1 universal factory format 2 emmc hw partitions 3 done write damp file rom 1 and extcsd i try to write by vendor this file I9195IXXU1AOB1.1887753.GT-I9195I.MSM8916.REV0.1.I9195I this error GPT: not present Partition info not found Done. Selected eMMC Interface Failed to load partition any give damp file for rom2 or rom3????? |
