10-03-2013, 18:40 | #1 (permalink) |
Registered User Join Date: Sep 2007
Member: 581911 Status: Offline Thanks Meter: 1 | i9300 emmc detect ok.emmc name ok.but write problem EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 06/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 1486957604 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) Writing 20000000 bytes to 00000000 ...ROM1 eMMC ACK Error !!! |
10-04-2013, 09:29 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,550 | Quote:
read sticked FAQ about emmc direct connect. | |
10-04-2013, 10:55 | #4 (permalink) |
Member: 581911 Status: Offline Thanks Meter: 1 | N7100 Device freezes the box. TX LED is blinking Loading eMMC Addon Firmware... CMD Pullup Level:1804 mV CMD Active Level:2361 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! Successefuly connected to box on COM157 Box S/N: 13130C198F247C69, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1784 mV CMD Active Level:2371 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! Successefuly connected to box on COM157 Box S/N: 13130C198F247C69, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1773 mV CMD Active Level:2371 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! Successefuly connected to box on COM157 Box S/N: 13130C198F247C69, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1784 mV CMD Active Level:2361 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! Error. Please select init first. Successefuly connected to box on COM157 Box S/N: 13130C198F247C69, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1794 mV CMD Active Level:2361 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! Writing file...C:\Users\Furkii\Desktop\note 2\N7100_Rom1_Alive_Dump_BN\N7100_Rom1_Alive_Dump_B N.bin Successefuly connected to box on COM157 Box S/N: 13130C198F247C69, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1773 mV CMD Active Level:2371 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) error purging CDC device: 0 Successefuly connected to box on COM157 Box S/N: 13130C198F247C69, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1608 mV CMD Active Level:2258 mV EMMC CID 15010056545530304D0022C608459F5B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 09/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 583403589 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x04] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x50] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d5a000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] I/O Driver Strength [DRIVER_STRENGTH: 0x00] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000bb Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Writing file...C:\Users\Furkii\Desktop\note 2\N7100_Rom2_Alive_Boot_bad\N7100_Rom2_Alive_Boot_ BN.bin Successefuly connected to box on COM157 Box S/N: 13130C198F247C69, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1598 mV CMD Active Level:2248 mV EMMC CID 15010056545530304D0022C608459F5B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 09/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 583403589 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) Writing 00100000 bytes to 00000000 ...ROM1 |
10-04-2013, 11:39 | #5 (permalink) | |
10-05-2013, 08:31 | #9 (permalink) |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | HI MR.blang I have same problem Writing file...D:\GSM\Easy-Jtag\Repair Dosyaları\I9300\I9300 EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000_20000000.b in Successefuly connected to box on COM14 Box S/N: !!!!!!!!!!!!!!!!, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1196 mV CMD Active Level:1691 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) error purging CDC device: 0 I used Easy-Jtag emmc adapter but not connect. BR, Dicle_Gsm |
