07-19-2016, 19:21 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | i9300 emmc KMVTU000LM-B503 logs Code: Z3X EasyJtag Software ver. 2.2.0.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0101200521EF0684, ,FW Ver.: 01.55CMD Pullup Level:742 mV CMD Active Level:1598 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 15010056545530304DF151DD26A26F44 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 Rev.0xF1 EMMC NAME: VTU00M , S/N: 1373447842 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_1373447842_20160719_2114.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (PARAM) Range: [0X2000000,0X27FFE00] ,Len: 800000 MMCBLK0P4 (BOOT) Range: [0X2800000,0X2FFFE00] ,Len: 800000 MMCBLK0P5 (RECOVERY) Range: [0X3000000,0X37FFE00] ,Len: 800000 MMCBLK0P6 (RADIO) Range: [0X3800000,0X57FFE00] ,Len: 2000000 MMCBLK0P7 (CACHE) Range: [0X5800000,0X457FFE00] ,Len: 40000000 MMCBLK0P8 (SYSTEM) Range: [0X45800000,0XA57FFE00] ,Len: 60000000 MMCBLK0P9 (HIDDEN) Range: [0XA5800000,0XC87FFE00] ,Len: 23000000 MMCBLK0P10 (OTA) Range: [0XC8800000,0XC8FFFE00] ,Len: 800000 MMCBLK0P11 (USERDATA) Range: [0XC9000000,0X3AAFFFE00] ,Len: 2E2000000 Done...Presets has been updated... Code: Data partitions (firmware parts) count is 128 (dec) mmc_read_blocks(FFFFFE00 > AB400000 ), Read address is invalid mmc_read_blocks(AB3FBE00 > AB400000 ), Read address is invalid Meta partitions (partitions storing partition table) count is 1 (dec) Partitions list is successefuly loaded! Last edited by gencom; 07-19-2016 at 19:29. |
07-19-2016, 22:42 | #2 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, Your eMMC looks fine, read operation OK. But in some cases eMMC has random block data corrupt problem. So try to write something into eMMC with enabled Writy Verify option. Best Regards |
The Following User Says Thank You to vikboston For This Useful Post: |
07-20-2016, 04:26 | #3 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | u can use kmvtu for all square pin , p3100 9500 n7000 n7100 xiaomi zenfone etc . just made ffu and factory erase , then write the correct extcsd boot1 boot 2 then userarea ( 128 mb or 512mb or full dump depend on your phone target ) tested by me |
The Following User Says Thank You to bagus.dps For This Useful Post: |
