Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 02-14-2014, 19:53   #1 (permalink)
Member: 516790
Thanks Meter: 19
i9300 NO PRODUCT (S3) - successfully repair with easy jtag
Loading eMMC Addon Firmware...
Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!
CMD Active Level:1650 mV
EMMC CID 15010056545530304DF1985402D47FD7
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 07/2012 FW rev.0xf1
EMMC NAME: VTU00M , S/N: 2555642580
EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_2555642580_20140105_2045.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
Successfully connected to box on COM58
Box S/N: 0D01100B3AC50D82, ,FW Ver.: 01.48
Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!
CMD Active Level:1639 mV
Backup saved: VTU00M_2555642580_20140105_2047.extcsd
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
Please don't forget to repair extCSD from backup!!!
Running:SAMSUNG: MoviNAND Format...
CMD Pullup Level:1206 mV
Sending Internal Reconfiguration Request...
Waiting configuration Apply!!!
Restoring configuration...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_2555642580_20140 105_2045.extcsd
Running:Repair extCSD...
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Writing file...D:\SAMSUNG\z3x easy\i9300\EMMC_ROM2_00000000_00200000.bin
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 218 kB/s
Done !!!
Writing file...D:\SAMSUNG\z3x easy\i9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000 _20000000.bin
Writing 000020000000 bytes to 00000000 ...ROM1
Write Speed: 302 kB/s
Done !!!
The Following 2 Users Say Thank You to cangsm For This Useful Post:
Old 02-14-2014, 19:55   #2 (permalink)
Member: 335721
Thanks Meter: 12
well done .
Sent from my iPhone using Tapatalk 2
Old 02-15-2014, 06:34   #3 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 243
Bro wish windows you users w7 or windows xp 3
Old 02-15-2014, 07:53   #4 (permalink)
Member: 516790
Thanks Meter: 19
windows xp 3 use No problem
Old 02-15-2014, 09:25   #5 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 243
With windon 7 also problem rl100plb...........
Old 02-15-2014, 15:27   #6 (permalink)
Member: 1859706
Sonork: 100.1648492
Thanks Meter: 26
What the steps did you use?
Old 02-15-2014, 16:50   #7 (permalink)
Member: 516790
Thanks Meter: 19
Step 1: Smart Factory Reset + Format
Step 2: SAMSUNG: movinand Format
Step 3: Repair extcsd
Step 4: rom2 (Boot Partition 1) Select 2 MB Write
Step 5: ROM1 (Main user data), select 512 MB Write
work phone
The Following User Says Thank You to cangsm For This Useful Post:
Old 02-17-2014, 16:59   #8 (permalink)
Member: 1891212
i9300 no product name error
i have 24pcs i9300 without product name and i tried to flash emmc ic through easy jtag but every one showing this error
EasyJtag Suite ver.: 1.0.100.0 started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition.
Successefuly connected to box on COM90
Box S/N: 121202160D62CBA3, ,FW Ver.: 01.48
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AAA9-C0E9 , ver: 22
Successfully connected to box on COM90
Warning: CMD Pullup Level (1062 mV) too low , check cables etc.!!!
CMD Active Level:1515 mV
Can't Init EMMC !!! ( Ready Condition TIMEOUT! )
eMMC Card initialisation error!
i thing it may be bad emmc chip , am not sure
if anybody know about the error plz help
Old 02-17-2014, 18:10   #9 (permalink)
swechacnu's Avatar
Member: 115144
Sonork: 100.1590698
Thanks Meter: 498
Hi,
Give screenshot here when its download mode that screenshot,
in download mode if it showing custom binary NO
after that confirm EMMC damaged, but once again u need to check sold wires and power supply, if it will clear, replace emmc ic.
BR,
Srinivas Reddy.
Old 02-17-2014, 20:02   #10 (permalink)
Member: 516790
Thanks Meter: 19
Step 1 is your fault: Warning: CMD pullup Level (1062 mV) too low, check cables
Step 2 wire control
step 3 voltage control
Old 02-18-2014, 19:23   #11 (permalink)
Member: 1396837
Sonork: 100.1657369
Thanks Meter: 17
i9300 boot repair plase help!
Successfully connected to box on COM91
Box S/N: --------------, ,FW Ver.: 01.48
Warning: CMD Pullup Level (1082 mV) too low , check cables etc.!!!
CMD Active Level:1041 mV
Warning: CMD Active Level Low !!!
EMMC CID 15010056545530304DF1CC5C4F826FBF
EMMC Date: 06/2012 FW rev.0xf1
EMMC NAME: VTU00M , S/N: 3428601730
Retry writing adress 0x00000000
Old 02-18-2014, 19:27   #12 (permalink)
Member: 516790
Thanks Meter: 19
To program on the phone???
Old 02-18-2014, 22:10   #13 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 243
Step 2 wire control
bro you round because i have like 20 fone in hand is write this error
Old 02-20-2014, 17:56   #14 (permalink)
Member: 1859706
Sonork: 100.1648492
Thanks Meter: 26
I always get this error:
Warning: CMD Pullup Level (783 mV) too low , check cables etc.!!!
CMD Active Level:1258 mV
eMMC ACK Error ( Check Connection )
Old 02-20-2014, 18:14   #15 (permalink)
Member: 1396837
Sonork: 100.1657369
Thanks Meter: 17
plase help I9300 no product
Box S/N: -----------------, ,FW Ver.: 01.48
CMD Pullup Level:1670 mV
CMD Active Level:1134 mV
The Following User Says Thank You to Azacomseraa For This Useful Post:
Page generated in 0.42343 seconds with 7 queries
