01-22-2020, 02:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Icfriend ufs adaptor |
01-23-2020, 08:06 | #7 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | new firmware for box will increase speed max speed for PWM-G4 (66MHz) UFS mode is 8-10MB/s that's enough for boot repair procedure HS link for UFS need ~1500MHz speed PWM G5/G6/G7 (~90-120-150MHz) can't support by most UFS chips during the development of box 3 years ago, we did not know that most of the chips would refuse to work in these modes (PWM G5/G6/G7) Max Box hardware speed can be ~900-100MHz link Now eMMC work at 42MHz (we try use speed up to 56MHz, but eMMC was no work stability) Current UFS speed is 66MHz (PWM-G4 mode) Last edited by layder; 01-23-2020 at 08:16. |
01-23-2020, 08:36 | #8 (permalink) | |
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Icfriend ufs adaptor Quote:
For hs gear we need a new easy jtag box? Like medusa pro2 which can do 95mb/s on hs on new hardware , is there any eta for new firmware? Last edited by oktay50000; 01-23-2020 at 08:41. | |
01-23-2020, 08:49 | #9 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
But most operation, what can be do with UFS chips is not need big data transfer Userdata is crypted, system partition may be flashed via USB For boot repair speed 8-10MB/s is enough 95MB/s - HS link 1 (1500Mhz), our hardware can work only at 900-1000Mhz | |
The Following User Says Thank You to layder For This Useful Post: |
01-23-2020, 08:54 | #10 (permalink) | |
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Quote:
True,Thank you for your time and answer, one last question: where can i find easyjtag pinout for ufs ?? Is there anything like this for ufs? | |
