03-19-2018, 19:37 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Belgium Age: 49
Member: 212839 Status: Offline Thanks Meter: 11 | Imei repair G930F with Z3X I want to repair imei on my samsung SM-G930F with Z3X tried many things. but nothing works my Phone is now root and this failure i get want i try repair with Z3X. REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G930F Software version: 31.0 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 7.0 Product code: Phone version: PDA version: G930FXXU1DQBT CSC version: G930FVFG1DQBT CSC country code: Germany CSC sales code: VD2 HW version: Phone SN: R58H83KSGFW Chip name: EXYNOS8890 Modem board: Security patch: 2017-02-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Can not detected modem type Done with Samsung Tool PRO v.31.0 i want to downgraded to 6.01 but Always failure |
