08-30-2018, 14:14 | #1 (permalink) |
Insane Poster Join Date: Sep 2013
Member: 2035261 Status: Offline Sonork: alphatech Thanks Meter: 6 | error why reading data from emmc eMMC_tool Suite ver. 1.5.1.0 (release date: 25.04.2018) Microsoft Windows 10 (32 bit) build 16299 (10.0.16299.15) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = 674A25F12BBD12CB Card Serial = AA21DD03 EasyJTAG Box Firmware = 2.30 Changelog: 11.06.2018 (ver 1.5.1.0) Fix: Bugs that have been found through your crash report Add: Explorer NTFS Support (it will probably be slow on EasyJTAG V1) Add: Extracting contacts from store.vol (currently only from a file on disk) Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz Can't init device. Reason: Command Index Error Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz Can't init device. Reason: Command Index Error Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz Can't init device. Reason: Command Index Error Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz Can't init device. Reason: Command Index Error Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz Can't init device. Reason: Command Index Error Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz EMMC Device Information : EMMC CID: 150100514531334D420D2541CA22244B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE13MB , HEX: 514531334D42 , S/N: 2541CA22 , rev. 0x0D EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE13MB_2541CA22_20180830_054223.extcsd EMMC Init completed. Get firmware version Brand = TECNO Manufacturer = TECNO Model = TECNO L9 Plus Phone platform = mt6580 CPU Abi = armeabi-v7a Mediatek platform = MT6580 Android release = 7.0 Firmware version = L9Plus-H8011A1-N-170210V206 Firmware date = Fri Feb 10 23:33:34 CST 2017 Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz EMMC Device Information : EMMC CID: 150100514531334D420D2541CA22244B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE13MB , HEX: 514531334D42 , S/N: 2541CA22 , rev. 0x0D EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE13MB_2541CA22_20180830_054245.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Samsung Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is not blank GPT header successfully parsed EFS partition not found Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 1 Mhz EMMC Device Information : EMMC CID: 150100514531334D420D2541CA22244B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE13MB , HEX: 514531334D42 , S/N: 2541CA22 , rev. 0x0D EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE13MB_2541CA22_20180830_054307.extcsd EMMC Init completed. Scan from: QE13MB Vendor: Samsung Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [protect_f] successfully PartType: LINUX Mount [protect_s] successfully PartType: LINUX Mount [nvdata] successfully PartType: LINUX Mount [system] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [data] successfully PartType: LINUX Extract contacts from contacts2.db Init database engine (version: 3.23.0) Found 11 accounts Bad File: contacts2.db |
08-30-2018, 20:57 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | base is damaged, needs to open files at SQL viewer Last edited by layder; 08-30-2018 at 21:10. |
The Following User Says Thank You to layder For This Useful Post: |
08-31-2018, 09:42 | #9 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | SQL database contains several tables like Excel. With SQL viewer you can view the tables that are intact and transfer the data to other programs. If you database is seriously damaged, there will be much more work. Database (contacts2.db) is saved to folder, that you choise. |
09-02-2018, 08:24 | #10 (permalink) | |
Member: 2035261 Status: Offline Sonork: alphatech Thanks Meter: 6 | Yes bro I have contact.db in a folder, but don't know how to extract that Quote:
