Old 07-24-2013, 12:31   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
IMPORTANT: ALL CABLEs by GPG (Z3X-BOX PRO) need small modify
Please solder together 3 pins
The Following 12 Users Say Thank You to blang For This Useful Post:
Old 07-24-2013, 15:17   #2 (permalink)
Member: 276432
Thanks Meter: 65
thanks for good info dear because i use this cabel dear
The Following User Says Thank You to dvdaio For This Useful Post:
Old 07-24-2013, 18:21   #3 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
other JTAG use many pins ground.
easy-JTAG use only pin N20. So some problem exist.
I sure after fix jtag will work much better and pin finder will work much better also.
The Following 6 Users Say Thank You to blang For This Useful Post:
Old 08-27-2013, 20:38   #4 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
in box 16. pin ı see not empty 16. pin for find pinout?
in box can ı make this modifie 16-18-20 can ı make jumper ? Because ı see in box 16. pin go to xilinx chip
The Following 2 Users Say Thank You to BesTCooL For This Useful Post:
Old 09-23-2013, 16:22   #5 (permalink)
Gjakova's Avatar
Member: 189304
Sonork: 100.1614605
Thanks Meter: 40
bought new box-pro(gpg) but cable is not similar like in pic
The Following 2 Users Say Thank You to Gjakova For This Useful Post:
Old 09-23-2013, 19:07   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
show photo, i will tell what to do. i hope they have fixed this from factory.
The Following User Says Thank You to blang For This Useful Post:
Old 09-23-2013, 19:08   #7 (permalink)
Gjakova's Avatar
Member: 189304
Sonork: 100.1614605
Thanks Meter: 40
can be fixed 4 me working ok
Old 09-23-2013, 20:45   #8 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Hi,
I just ordered Easy JTAG with 35-in-1 Samsung adapter set from GSMServer. Is the adapter set compatible with this box?
Thanks!
The Following 2 Users Say Thank You to Jabbacks For This Useful Post:
Old 09-23-2013, 20:56   #9 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by Jabbacks View Post
Hi,
Thanks!
give me link i will tell you.
easy-jtag have 20pin standart jtag connector.
Old 09-23-2013, 21:00   #10 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Wow, you're showing here different adapter than those I ordered.
35 in 1 Samsung JTAG Adapter Set . Unlock software, repair and flash tools, service manuals, unlock codes, spare parts and cables for cell phones - JTAG Samsung Adapters - Cables for flash / unlock devices - Cables and Adapters - Flash and Unlock
Old 09-23-2013, 21:07   #11 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
yes. this will work. but i think you need also JPINS for nevest phones.
check JPINS by MOORC.
Old 09-23-2013, 21:11   #12 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Wow, thanks bro... Order already on it's way... Just saw your cable pinout and was shocked spending over $100USD for the adapters.... hehehehe...
Thanks again!
Old 09-23-2013, 21:54   #13 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
I have here dead boot GT-i9100 for a start. Is it possible to repair boot with this set of cables?
Phone was flashed with wrong PIT file with ODIN. It was working alright and owner tried to put custom firmware into it.
Thanks!
Old 10-02-2013, 08:08   #14 (permalink)
saif@cellplus's Avatar
Member: 26488
Sonork: 100.1581233
Thanks Meter: 151
hi
can I use riff jtag box cable to z3x pro instead?
Regards,
saif.
Old 10-02-2013, 09:54   #15 (permalink)
Gjakova's Avatar
Member: 189304
Sonork: 100.1614605
Thanks Meter: 40
Originally Posted by saif@cellplus View Post
hi
Regards,
saif.
yep working almost with all jtag cables
The Following User Says Thank You to Gjakova For This Useful Post:
Page generated in 0.24644 seconds with 9 queries
