IMPORTANT: ALL CABLEs by GPG (Z3X-BOX PRO) need small modify |
thanks for good info dear because i use this cabel dear |
easy-JTAG use only pin N20. So some problem exist. I sure after fix jtag will work much better and pin finder will work much better also. |
in box 16. pin ı see not empty 16. pin for find pinout? in box can ı make this modifie 16-18-20 can ı make jumper ? Because ı see in box 16. pin go to xilinx chip |
bought new box-pro(gpg) but cable is not similar like in pic |
Hi, I just ordered Easy JTAG with 35-in-1 Samsung adapter set from GSMServer. Is the adapter set compatible with this box? Thanks! |
easy-jtag have 20pin standart jtag connector. |
Wow, you're showing here different adapter than those I ordered. 35 in 1 Samsung JTAG Adapter Set . Unlock software, repair and flash tools, service manuals, unlock codes, spare parts and cables for cell phones - JTAG Samsung Adapters - Cables for flash / unlock devices - Cables and Adapters - Flash and Unlock |
check JPINS by MOORC. |
Wow, thanks bro... Order already on it's way... Just saw your cable pinout and was shocked spending over $100USD for the adapters.... hehehehe... Thanks again! |
I have here dead boot GT-i9100 for a start. Is it possible to repair boot with this set of cables? Phone was flashed with wrong PIT file with ODIN. It was working alright and owner tried to put custom firmware into it. Thanks! |
hi can I use riff jtag box cable to z3x pro instead? Regards, saif. |
