Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 02-11-2016, 18:31   #46 (permalink)
Member: 2349261
Sonork: 100.1662797
Thanks Meter: 2
Change solder wire 1.8 to 2.8
Old 02-23-2016, 22:44   #47 (permalink)
Member: 1306687
Sonork: ayman
Thanks Meter: 12
what do you mean bro please help me
Old 03-28-2016, 14:41   #48 (permalink)
Member: 1411141
Thanks Meter: 7
i can not post images what to do.. ?
The Following User Says Thank You to kevinsatani For This Useful Post:
Old 03-29-2016, 12:50   #49 (permalink)
Member: 174156
nice work
we need anthr good work
Old 04-06-2016, 14:00   #50 (permalink)
Member: 1411141
Thanks Meter: 7
my jtag point are in these sequence ,
GND,
VR CMD,
TR CLK,
DO TDI,
TMS,
TCK,
RTCK,
TDO,
SRST, AND S3 pinout shows DATO connection ..!!! what should i do ?
Old 06-18-2016, 09:46   #51 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 13,758
really strange still there is old stock comming really factory should fix this
Old 06-26-2016, 18:33   #52 (permalink)
Member: 924142
Thanks Meter: 12
Originally Posted by bruno rafael View Post
my cable is diferents connections..
Need modify?
my adapter same as u,need to jump or not
Old 07-14-2016, 22:14   #53 (permalink)
gencom's Avatar
Member: 1918391
Thanks Meter: 61
not worked for me check Gt-n7100 direct emmc fail
Old 02-27-2017, 15:48   #54 (permalink)
Member: 1812419
Thanks Meter: 105
hello
i am buy a new z3x jtag
and i connect samsung G531F dead set.
(it was working, flashing time error and dead)
and write all roms then showing this error
Processing file...D:\EMMC_direct_dump\SAMSUNG_SM-G531F_emmc_direct_dump\SAMSUNG_SM-G531F.extcsd
Processing file...D:\EMMC_direct_dump\SAMSUNG_SM-G531F_emmc_direct_dump\SAMSUNG_SM-G531F_ROM1.bin
Processing file...D:\EMMC_direct_dump\SAMSUNG_SM-G531F_emmc_direct_dump\SAMSUNG_SM-G531F_ROM2.bin
Processing file...D:\EMMC_direct_dump\SAMSUNG_SM-G531F_emmc_direct_dump\SAMSUNG_SM-G531F_ROM3.bin
Running:Repair extCSD...
Z3X EasyJtag Software ver. 2.5.0.7
Skip loading eMMC Addon Firmware
CMD Pullup Level:61 mV
CMD Active Level:1515 mV
Box IO Level:2800 mV
CLK Rate:7000 khz
Can't init device, Reason: CMD Timeout Error
Done.
plz help
The Following User Says Thank You to aaditigerhill For This Useful Post:
Old 05-03-2017, 22:48   #55 (permalink)
Member: 2553586
Z3X EasyJtag Software ver. 2.5.0.8
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: ---------------, ,FW Ver.: 01.58
CMD Pullup Level:2691 mV
CMD Active Level:2774 mV
CLK Rate:14000 khz
HiPower mode is off!
Can't init device, Reason: CMD Ready Timeout Error [Box Internal Failure]
Help!
Old 05-17-2017, 12:02   #56 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,245
Originally Posted by blang View Post
Please solder together 3 pins
this three pins its a gnd pin ?
Old 05-29-2017, 04:39   #57 (permalink)
Member: 2541061
other JTAG use many pins ground.
easy-JTAG use only pin N20. So some problem exist.
I sure after fix jtag will work much better and pin finder will work much better also.
Old 05-31-2017, 05:56   #58 (permalink)
Member: 1979644
Sonork: mk47
Thanks Meter: 25
Help mr.blang
I BUY THIS BOX [Z3X EASY JTAG]FROM GSM SAVER.
IM A NEW USER PLEASE HELP ME ,
WHICH MISSING THINGS I NEED TO BUY ,TOBE FULL USER!?
ADVISE ME ABOUT CABLES etc.
ibuy this one here;-https://gsmserver.com/item/boxes-and...dapter-5-in-1/
THANKS BLANG
Old 11-19-2017, 19:09   #59 (permalink)
Member: 2343170
Thanks Meter: 44
How modify this
http://img4host.net/viewer.php?img=1...45a11d81ace747
Old 12-16-2017, 03:32   #60 (permalink)
Member: 2789603
thank you for your information
The Following User Says Thank You to junaidhtc For This Useful Post:
Page generated in 0.35492 seconds with 8 queries
