Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-07-2015, 14:37   #1 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,120
Important notice for Windows 10 Users
Hello , all Users of new Microsoft OS. We have tested our box compliance via testing in the hardware in different modes. And seems everything are OK
Note. If your EasyJTAG suite ask for driver update reinstall EasyJTAG driver again by hands because windows Native PNP driver are did not work!
Comport in Device Manager should be like in picture:
If you still experience any problem installing driver - then :
Disabling Driver Signature Enforcement In Windows 8 Permanently
Step 1. Open the Windows command promt as “Run as Administrator”.
Step 2. Run “bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS” (without the “”).
Step 3. To finalize the process run “bcdedit -set TESTSIGNING ON” (without the “”).
Step 4. Reboot and you’re done. (source)
If you get "The value is protected by secure boot policy and cannot be modified or deleted"
Step 1. Open Charms bar (Win+C)-> Settings -> Change PC Settings (click on it)
Step 2. In PC Settings go to General->Advanced Start Up (at the far bottom)
Step 3. Select Troubleshoot -> Advanced Options -> UEFI Firmware Settings-> Restart
Once the computer restarts, it will go to the BIOS.
In some laptops on the SECURITY Tab you will not able to change the settings for Security Boot Policy. In that case
you have to set a SUPERVISOR password and then you will able to [DISABLE] the Security Boot Policy.
Now, Exit and Save Changes.
The Following 10 Users Say Thank You to NoName® For This Useful Post:
Old 08-18-2015, 00:25   #2 (permalink)
Member: 2205304
Thanks Meter: 52
Hi NoName,
which version of win10 ? 32 or 64 ? Unsigned drivers is OK ?
The Following User Says Thank You to Suraj#1 For This Useful Post:
Old 09-23-2015, 18:22   #3 (permalink)
djawir's Avatar
Member: 39539
Thanks Meter: 63
win 10 64 bit cant install box driver
The Following User Says Thank You to djawir For This Useful Post:
Old 09-23-2015, 20:39   #4 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,120
Read first post and. It has been updated!
The Following 2 Users Say Thank You to NoName® For This Useful Post:
Old 10-01-2015, 18:50   #5 (permalink)
Member: 2329289
Sonork: www.sonork.com
Thanks Meter: 3
He works well with me
Old 04-21-2016, 11:09   #6 (permalink)
Member: 2491556
Thanks Meter: 2
You can disable driver signing in Windows 10 by pressing shift and restart. It takes you into a menu which where you can disable it.
Will this work instead of above?
The Following User Says Thank You to DataMunched For This Useful Post:
Old 08-09-2016, 18:59   #7 (permalink)
Member: 1676491
Thanks Meter: 2
z3easy no recnoce driver en windows 10 64 bit
runs on Windows 10 bit 64 friends
Old 08-09-2016, 22:32   #8 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,284
Here Easy Procedure w/o enter in Bios and can use only when you need of "Disable Signature for one time"
how-to-disable-driver-signature-verification-on-64-bit-windows-10-so-that-you-can-install-unsigned-drivers
NOTE: when have installed Unsigned drivers at restart turn back with "Signature Drivers Enabled" BUT Not lost the Installed Drivers, tested for many Box/Dongle and all Full working
allumts
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 09-07-2016, 22:56   #9 (permalink)
Member: 2621951
Very useful, thanks!
Old 10-05-2016, 06:31   #10 (permalink)
Member: 2234521
Sonork: 100.1675402
Thanks Meter: 2
Disabling Driver Signature Enforcement In Windows 7 Permanently
Old 10-13-2016, 21:55   #11 (permalink)
Member: 2636533
comes in very handy and i finally got it figured out
Old 10-14-2016, 22:49   #12 (permalink)
Member: 2636950
It works well with me
Old 12-09-2016, 01:29   #13 (permalink)
Member: 2624908
works for me on 64 bit windows 10
The Following User Says Thank You to trebrob For This Useful Post:
Old 12-18-2016, 00:10   #14 (permalink)
Member: 2580976
this work for me, and can solve many problem
Old 12-27-2016, 02:01   #15 (permalink)
Member: 2447683
Sonork: dolirdo
work with meeeeeee win 10 box.s
Page generated in 0.43289 seconds with 8 queries
