02-14-2020, 19:47 | #1 (permalink) |
Major Poster Join Date: Jan 2015
Member: 2328327 Status: Offline Thanks Meter: 3 | ISP Xiaomi Mi play Z3X EasyJtag Software ver. 3.6.2.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0C00B0153CF1651A, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E036032ED9D263E eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 02/2019 Rev.0x3 eMMC NAME: hC8aP> , S/N: 1613950365 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP>_1613950365_20200213_1655.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Detected 40 partitions ------ P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB P2 (PARA) [0x2108000 0x80000] Size: 512.0KB P3 (EXPDB) [0x2188000 0x1400000] Size: 20.0MB P4 (FRP) [0x3588000 0x100000] Size: 1.0MB P5 (NVCFG) [0x3688000 0x2000000] Size: 32.0MB P6 (NVDATA) [0x5688000 0x4000000] Size: 64.0MB P7 (METADATA) [0x9688000 0x2000000] Size: 32.0MB P8 (PROTECT1) [0xb688000 0x800000] Size: 8.0MB P9 (PROTECT2) [0xbe88000 0x978000] Size: 9.468MB P10 (SECCFG) [0xc800000 0x800000] Size: 8.0MB P11 (PERSIST) [0xd000000 0x3000000] Size: 48.0MB P12 (SEC1) [0x10000000 0x200000] Size: 2.0MB P13 (PROINFO) [0x10200000 0x300000] Size: 3.0MB P14 (EFUSE) [0x10500000 0x80000] Size: 512.0KB P15 (MD1IMG) [0x10580000 0x6400000] Size: 100.0MB P16 (SPMFW) [0x16980000 0x100000] Size: 1.0MB P17 (SCP1) [0x16a80000 0x100000] Size: 1.0MB P18 (SCP2) [0x16b80000 0x100000] Size: 1.0MB P19 (SSPM_1) [0x16c80000 0x100000] Size: 1.0MB P20 (SSPM_2) [0x16d80000 0x100000] Size: 1.0MB P21 (GZ1) [0x16e80000 0x1000000] Size: 16.0MB P22 (GZ2) [0x17e80000 0x1000000] Size: 16.0MB P23 (NVRAM) [0x18e80000 0x4000000] Size: 64.0MB P24 (LK) [0x1ce80000 0x100000] Size: 1.0MB P25 (LK2) [0x1cf80000 0x100000] Size: 1.0MB P26 (BOOT) [0x1d080000 0x2000000] Size: 32.0MB P27 (LOGO) [0x1f080000 0x800000] Size: 8.0MB P28 (ODMDTBO) [0x1f880000 0x1000000] Size: 16.0MB P29 (TEE1) [0x20880000 0x500000] Size: 5.0MB P30 (TEE2) [0x20d80000 0xa80000] Size: 10.500MB P31 (VENDOR) [0x21800000 0x30000000] Size: 768.0MB P32 (CUST) [0x51800000 0x34000000] Size: 832.0MB P33 (SYSTEM) [0x85800000 0xc0000000] Size: 3.0GB P34 (DEVINFO) [0x145800000 0x800000] Size: 8.0MB P35 (VBMETA) [0x146000000 0x800000] Size: 8.0MB P36 (CACHE) [0x146800000 0x1b000000] Size: 432.0MB P37 (USERDATA) [0x161800000 0xd2a4fbe00] Size: 52.660GB P38 (OTP) [0xe8bcfbe00 0x2b00000] Size: 43.0MB P39 (FLASHINFO) [0xe8e7fbe00 0x1000000] Size: 16.0MB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0085800000 (3.0GB) Short EXT fs info: Size: 2.952GB Block size: 4.0KB Inode size: 256 Inodes: 193536 Short Android info: Backup saved: BuildProp_20200213_1656.txt Build ID: O11019 Display Build ID: ZAL1722-lotus-build-20190612172629 Release Incremental ID: V10.2.5.0.OFIMIXM Release Base ID: 8.1.0 Security Path: 2019-05-01 Device Model: MI PLAY Device Manufacturer: xiaomi Device Name A: lotus Device Name B: lotus Architecture ABI: arm64-v8a Product ID: lotus Build Description: lotus-user 8.1.0 O11019 V10.2.5.0.OFIMIXM release-keys Device manufacturer: Xiaomi --------------------------------------------- Detected USERDATA USERDATA : 0x0161800000 (52.660GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: F331F21F 3A39B58D EBB0099B 8054E98E 3160A8DB 08E21CC9 8FE385CC 2BFF87AF ó1ò.:9µ.ë° ›.TéŽ1`¨Û.â.É.ã…Ì+ÿ‡¯; 7D03164A 79314B82 30EFFC88 94BC4F04 588A27FC 29A3E413 5F9BC879 8552C66F }..Jy1K ‚0ïü.”¼O.XŠ'ü)£ä._›Èy…RÆo; 71678B66 C4B9FB5F 09B15306 CE8FFAF9 884364FE 51B1F760 A5995027 CDA09423 qg‹fĹû_ ±S.Î.úù.CdþQ±÷`¥.P'Í*”#; C78DEE19 3AB21304 8206A240 EB017EB6 85D355AA B142C97C 20DFC274 C8A3A8CC Ç.î.:².. ‚.¢@ë.~¶…ÓUª±BÉ| ßÂtÈ£¨Ì; 79886C7D 29F7FC03 17BEAC3E EE1BF663 E37B91F9 9EDBC234 0609334B BA5A867F y.l})÷ü..¾¬>î.öcã{‘ùžÛÂ4. 3KºZ†.; 566AA4AE B4099C23 7DEF120C 3A0B54F9 10B2AF1D B2B997B4 D61154E3 EBA86005 Vj¤®´ œ#}ï..:.Tù.²¯.²¹—´Ö.Tãë¨`.; FDE356FD 4047576A FB8493E7 FEFFFBC2 42195029 32BB85FC 774C2D29 FB0A5790 ýãVý@GWjû„“çþÿûÂB.P)2»…üwL-)û.W.; CD45F0A4 0D8BD5E4 E51424AA 393D5A70 AD6D6F8F A2D4121E 23F6503B 333DDD18 ÍEð ¤.‹Õäå.$ª9=Zp*mo.¢Ô..#öP;3=Ý.; Done. Selected eMMC Interface Selected eMMC Interface Wipe partitions content: Selected eMMC Interface Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:2052 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR Erasing 03000000 bytes from 0D000000 ...ROM1 Can't access partition #0 Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0C00B0153CF1651A, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E036032ED9D263E eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 02/2019 Rev.0x3 eMMC NAME: hC8aP> , S/N: 1613950365 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x0003588000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x0146800000 (432.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x0161800000 (52.660GB) , formatting... Done. Done. Done. |
02-14-2020, 21:19 | #3 (permalink) |
Member: 2328327 Status: Offline Thanks Meter: 3 | Sorry but I did not know what to put in the title, the problem is described there along with the logs is as follows: good afternoon, I have a problem that I do not understand and I would like help, I have a xiaomi MI play, I want to modify the persist partition, or rewrite, but it gives me an error Can't access partition # 0, the strange thing is that it tells me the same thing in FRP partition but I use the option of Android FRP clear of the advanced box if it DOES! It is incredible and I do not understand thanks for you help |
06-04-2020, 16:41 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | Quote:
