07-24-2019, 11:35 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Age: 39
Member: 681346 Status: Offline Thanks Meter: 14 | j100h dead boot repair error Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 1787 mV CMD Active Level: 1851 mV EMMC Device Information : EMMC CID: 90014A48344732621101F035A21B32A1 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: F035A21B , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_F035A21B_20190724_152107.extcsd EMMC Init completed. |
